LC401EM3F Emerson Inverter Issue
  • dcapper
    • Dec 2013
    • 496
    Re: LC401EM3F Emerson Inverter Issue
    Never thought of that. I'll test it this week. I'll follow the 3v pin back through the power supply to see if I have a weak cap.
      That 3V signal is routed through the power supply board for clean wiring, the power supply board is being used as the junction point, the signal is generated by the main board and is routed through the power supply board.
      • dcapper
        • Dec 2013
        • 496
        OK, There is two main boards on this tv. One is a signal board and one is like a tcon with hdmi outputs. I'll try the battery and see if the backlights come on. I get sound but no pic. When I turn it on, I get 3v at the inverter board but it's only for a second but no light flash from the backlights. I do get 3v for a second with the inverter board disconnected or connected.
        • dcapper
          • Dec 2013
          • 496
          After playing with this tv this evening, I decided to meter the other side of the power supply voltages. They are all good for about a second on power up then drop. I hear a funny noise from the lower part of the power supply. I am going to research it further. Maybe a faulty diode I missed.
          EDIT: It was just the sound of the relay losing power. I'm starting to think it's the MIP2F3 chip.
          • dcapper
            • Dec 2013
            • 496
            Changed the MIP chip. No change. Changed pretty much everything now. Power supply is too expensive to replace. Not worth it. Maybe a junker in the end.
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              🛠 Original Issue
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              by ugamazing
              12-17-2024, 07:05 PM
            • Dreadnought
              L40DIGB20 Logik 40" inverter/backlight issue.
              by Dreadnought
              Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
              Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
              02-08-2021, 12:28 PM
            • mitsu2k
              Power-One solar Inverter driving me NUTS!!!
              by mitsu2k
              Hello folks, this is a last ditch effort. I thought I would seek your expertise before giving up.. I have been working on this thing for over 2 months and have gotten nowhere. Here is the issue:
              Inverter powers on and immediately red GFI light comes on and inverter will not complete the initialization process.
              There is no error code on the screen. I have removed most of the Y capacitors and tested to no avail.
              All relays are good.
              I replaced the current transducer- same problem. Checked most of the transistors and diodes and all appear good. I wish I could get my hands...
              11-13-2023, 07:19 PM
