LC401EM3F Emerson Inverter Issue
  • dcapper
    • Dec 2013
    • 496
    Re: LC401EM3F Emerson Inverter Issue
    Never thought of that. I'll test it this week. I'll follow the 3v pin back through the power supply to see if I have a weak cap.
      That 3V signal is routed through the power supply board for clean wiring, the power supply board is being used as the junction point, the signal is generated by the main board and is routed through the power supply board.
      • dcapper
        • Dec 2013
        • 496
        OK, There is two main boards on this tv. One is a signal board and one is like a tcon with hdmi outputs. I'll try the battery and see if the backlights come on. I get sound but no pic. When I turn it on, I get 3v at the inverter board but it's only for a second but no light flash from the backlights. I do get 3v for a second with the inverter board disconnected or connected.
        • dcapper
          • Dec 2013
          • 496
          After playing with this tv this evening, I decided to meter the other side of the power supply voltages. They are all good for about a second on power up then drop. I hear a funny noise from the lower part of the power supply. I am going to research it further. Maybe a faulty diode I missed.
          EDIT: It was just the sound of the relay losing power. I'm starting to think it's the MIP2F3 chip.
          • dcapper
            • Dec 2013
            • 496
            Changed the MIP chip. No change. Changed pretty much everything now. Power supply is too expensive to replace. Not worth it. Maybe a junker in the end.
            • Dvsr
              On M-Audio AV40 active studio speaker's two zener diodes get really hot.
              by Dvsr
              Hi. I need help from wiser guys. I am amateur in electronics and can't figure this out by myself.
              I bought faulty speakers, M-Audio AV40's. Other speaker has all the electronics in it and the other speaker is just passive one powered by the other speaker's amp. Original problem with the speakers was loud buzzing. I figured out that there is something wrong with the capacitors. I went ahead and replaced every electrolytic capacitor on the PCB. The caps are good quality and have the same values as the original ones.
              After replacing the caps I started testing out the speaker. It seemed...
              09-10-2025, 10:20 AM
            • caspian
              What Zener Diodes on a Linear Power Supply
              by caspian
              Dear members,
              I have a linear variable power supply with unknown brand name that I used for voltage injection.
              Then it failed. I discovered that its transistors (Q1 and Q2) are shorted.
              In addition, I discovered that its zener diodes are defective.
              I can replace the burned transistors.
              But I do not know the model of the zener diodes. the model number is not marked on the zener diodes.
              Therefore, I cannot replace the zener diodes.
              I do not want to test the zener diodes in a test circuit to discover their model or value.
              no schematics are available...
              05-26-2025, 12:38 PM
            • rounin
              MacBook Air A2337 (820-02016) USB-C Port Issue – Only Works in One Orientation (CC Line Problem?)
              by rounin
              I'm working on a MacBook Air 2020 (A2337, board 820-02016) and running into a strange USB-C issue. I've gone through quite a bit of testing and part replacement, but I'm stuck — hoping someone here can shed some light.
              🛠 Original Issue
              The machine initially wouldn't negotiate 20V over USB-C — stuck at 5V.
              ⚠️ New Problem: One USB-C Port Only Works in One Orientation...
              04-19-2025, 01:18 AM
            • ugamazing
              Three 820-01700 32GB Logic Boards Same Issue: Won't Wake From Hibernate
              by ugamazing
              I have three identical-spec 820-01700 boards (2.6/32/512), and ALL THREE boards came to us with the same fault, from different sources: The boards don't wake from hibernation with the keyboard or lid, they ONLY wake when you press the power button. I understand this is a very minor issue, but the boards must be fixed!
              We will of course begin with the obvious (checking lid signals), but I couldn't help but notice these three boards were all 32GB variants. Has anyone noticed an issue relating to these 32GB boards in particular? I of course don't think it's a RAM issue, but it's bizarre...
              12-17-2024, 07:05 PM
            • Dreadnought
              L40DIGB20 Logik 40" inverter/backlight issue.
              by Dreadnought
              Hi. Firstly I apologise if I break any forum unwritten rules, as I'm new here. I've used badcaps for advice in the past, but I've only just joined. I'm self taught, so I don't have anywhere near the knowledge that some of you guys have, but I can only hope to keep learning and get there one day.
              Anyway, I've been working on a TV recently. It's the one listed in the title. Logik L40DIGB20. It powers on fine, with the standby light turning blue as it should. The backlight turns on for a second, then goes off. Using a flashlight, I can see an image on the screen. The power supply is fine,...
              02-08-2021, 12:28 PM
