Panasonic TH-P50VT20A vertical line
  • tw2005
    • Oct 2011
    • 6458
    Re: Panasonic TH-P50VT20A vertical line
    Originally posted by tom66
    My Kuro - 12,700 hours
    Done a PZ80 with 15,000 hours
    No stuck lines
    Luck of the draw really, it's a lot rarer on some models (very rare on Kuros; infrequent on PZ80s; frequent on PZ70s & G10s, and Samsung A400 plasmas.)
    You're right, I've got a 46PZ800 as a ready reserve. I think 8500hrs
    • tw2005
      • Oct 2011
      • 6458
      Originally posted by itsa
      which one ?? this current one has just the vertical line , I guess you can say it is made up of digital red and blue pixles, and white and black and green also, it does change a bit depending on the back ground of the rest of the screen
      my last tv was a P50VT10A , previous model but broke the screen due to falling over
      Oh, my bad. i assumed it was another VT20 you were going to salvage boards from this. You might get good money for the Sc board and buffers from the VT10 and this one too if anyone is after one.
      • itsa
        Paul
        • Jul 2014
        • 14
        I was hoping the parts may be interchangeable incase i could swap some bits around ... but totally different i beleive
        all good , i will just have to put up with the line for a while and having the projector sitting on the coffee table when the line starts to annoy me or watching a movie..
        • tw2005
          • Oct 2011
          • 6458
          Definitely VT10, not V10? A G10 with a good panel could be a better thing to look out for if you really wanted to salvage a plasma with the old boards. You'd have to check what SC yours has or PZ80/800 series with 2 or 10 blink which can commonly be a simple cap replacement on the PSU.
          A V20 with 4 or 10 blink can be common Sc board short.
          Don't see a lot of good stuff on ebay now.
          • tw2005
            • Oct 2011
            • 6458
            Not exactly close to brisbane but this sounds like it will be infamous PSU issue.
            http://www.ebay.com.au/itm/Panasonic...item35d9186a8f
            This one, could be as simple as a poorly seated LVDS lead or dirty connector. May also end up with a PSU fault if it has not already had a fix.
            http://www.ebay.com.au/itm/Panasonic...item4623405249
            This one, most likely failed SC board and or buffers. Can be component repaired if able to do that sort of work.
            http://www.ebay.com.au/itm/PANASONIC...item43cbfb633f
            • itsa
              Paul
              • Jul 2014
              • 14
              you are correct, it is a P50V10A not a P50VT10A
              I will keep an eye out for another g10 or v20 with a good panel in the mean time tho..
              i am hooked on the plasmas, you cant go past the deep blacks...
              • tw2005
                • Oct 2011
                • 6458
                V20 , if you score might be able to help out if it's just the SC required. The SC in the VT20 is a different version due to 3D.
                • itsa
                  Paul
                  • Jul 2014
                  • 14
                  that last one is also on gumtree... and cheaper than the current bid
                  http://www.gumtree.com.au/s-ad/maroo...-tv/1050956006
                  • tw2005
                    • Oct 2011
                    • 6458
                    You'd have to quiz them and see if there is a blink code. A dead short can also cause a solid LED , no blinks. Not sure how reliable that model is long term. My experience stops at the 2010 models.
                    Should be a few posts though for 2011 models with failed SC or buffers.
                    • otaku_nut
                      Vizio E701i-A3 fixed but now has red vertical line
                      by otaku_nut
                      Hi all, I tried searching the site for answers but I'm a bit over my head understanding some of what might apply and what doesn't, so please be patient with me. I used Freakaftr8's fix to remove the left driver board to restore picture to a black screen with sound Vizio E701i-A3. After doing so, I now have a large red vertical stripe down the center of the screen. The fix did require getting another t-con board from online, I ordered it before I knew about the mosfit fix for the old t-con board. I have tried cleaning the cable connections to the t-con board. I swapped the cables going from...
                      08-19-2025, 06:11 PM
                    • howardc64
                      Vizio M65Q7-H1 Red Vertical Strips fixed by tape blocking LC1 signal to half of the panel
                      by howardc64
                      Failure Symptom
                      No picture, just red vertical stripes. Google search shows quite common problem for these recent Vizio M series although red vertical stripe pattern may differ. Some call it "Netflix" boot screen haha.
                      Where is the short?
                      Panel has 4x buffer boards. Quickly found the 1/4 panel buffer board with the problem by selectively disconnecting buffer board flex cables.
                      Having recently fixed another Vizio with similar symptoms that was a shorted ESD diode array ( link ) Probed the ESD diode array but...
                      05-27-2025, 02:56 PM
                    • TrueSword88
                      Kogan - KALED65XU9220STB - Blue Vertical Line
                      by TrueSword88
                      Hi all.
                      I have a Kogan 65' LCD Panel with a thin blue vertical line (top to bottom) on left hand side of panel.
                      The line just happens to coincide with the end of COF and start of the next COF (attached).
                      The line is permanent no matter what I've tried. I've tried pressure testing the panel (top to bottom) and all over, I didn't notice any difference with the line, either temporary or semi-permanent.
                      Also tried unplugging all flex cables, cleaned with isopropyl then re-inserting to no avail - line remains.
                      Hoping to fix...
                      05-05-2023, 04:28 PM
                    • almarhum
                      To fix laptop screen vertical line by working on its EDP cable
                      by almarhum
                      Has one here really gone through fixing laptop screen vertical line(s) by repairing/replacing its Embedded DisplayPort (EDP) cable, so would recount and share the complete steps of the process here now?
                      As most, if not all, believe the laptop screen vertical line(s) caused by defective Embedded DisplayPort (EDP) cable which slipped and passed through either laptop screen hinge but post here is asking help to elaborate definitively the useful, real knowledge of repairing in the most complete, correct way, esp. can decide/determine whether the cable can still be fixed or must be re...
                      05-07-2024, 02:12 PM
                    • kca
                      by kca
                      Hello all ~
                      08-31-2025, 06:38 AM
