Panasonic TH-P50VT20A vertical line
    Re: Panasonic TH-P50VT20A vertical line
    My Kuro - 12,700 hours
    Done a PZ80 with 15,000 hours
    No stuck lines
    Luck of the draw really, it's a lot rarer on some models (very rare on Kuros; infrequent on PZ80s; frequent on PZ70s & G10s, and Samsung A400 plasmas.)
    You're right, I've got a 46PZ800 as a ready reserve. I think 8500hrs
      Originally posted by itsa View Post
      which one ?? this current one has just the vertical line , I guess you can say it is made up of digital red and blue pixles, and white and black and green also, it does change a bit depending on the back ground of the rest of the screen
      my last tv was a P50VT10A , previous model but broke the screen due to falling over
      Oh, my bad. i assumed it was another VT20 you were going to salvage boards from this. You might get good money for the Sc board and buffers from the VT10 and this one too if anyone is after one.
        I was hoping the parts may be interchangeable incase i could swap some bits around ... but totally different i beleive
        all good , i will just have to put up with the line for a while and having the projector sitting on the coffee table when the line starts to annoy me or watching a movie..
          Definitely VT10, not V10? A G10 with a good panel could be a better thing to look out for if you really wanted to salvage a plasma with the old boards. You'd have to check what SC yours has or PZ80/800 series with 2 or 10 blink which can commonly be a simple cap replacement on the PSU.
          A V20 with 4 or 10 blink can be common Sc board short.
          Don't see a lot of good stuff on ebay now.
            Not exactly close to brisbane but this sounds like it will be infamous PSU issue.
            http://www.ebay.com.au/itm/Panasonic...item35d9186a8f
            This one, could be as simple as a poorly seated LVDS lead or dirty connector. May also end up with a PSU fault if it has not already had a fix.
            http://www.ebay.com.au/itm/Panasonic...item4623405249
            This one, most likely failed SC board and or buffers. Can be component repaired if able to do that sort of work.
            http://www.ebay.com.au/itm/PANASONIC...item43cbfb633f
              you are correct, it is a P50V10A not a P50VT10A
              I will keep an eye out for another g10 or v20 with a good panel in the mean time tho..
              i am hooked on the plasmas, you cant go past the deep blacks...
                V20 , if you score might be able to help out if it's just the SC required. The SC in the VT20 is a different version due to 3D.
                  that last one is also on gumtree... and cheaper than the current bid
                  http://www.gumtree.com.au/s-ad/maroo...-tv/1050956006
                    You'd have to quiz them and see if there is a blink code. A dead short can also cause a solid LED , no blinks. Not sure how reliable that model is long term. My experience stops at the 2010 models.
                    Should be a few posts though for 2011 models with failed SC or buffers.
