Vizio VX37L. Tv turns on no picture,no sounds.
  • jesselyons2002
    • Jul 2013
    • 82
    • usa
    Just got a vizio vx37l for $25 off someone off craigslist. Press the power button to turn it on. Front logo lights up. Backlights go out. Shows a white line and then screen goes black. But backlights are still on and tv won't turn off with remote or by power button.
    Check power supply. Got all the right voltages from the power board. Read on here that this vx37L have bad main boards. But I don't whats bad on the board my self. Need help diagnose it. Oh yeah got 5 volts and 12 volts at the main board fuse.
    Re: Vizio VX37L. Tv turns on no picture,no sounds.
    You need to test those 3-pin Voltage regulators on the main board.
    Please read this post and report the readings in format as requested.
    https://www.badcaps.net/forum/showth...999#post300999
    • SS454
      vizio e650i-a2 backlight flashes then turns off
      by SS454
      vizio e650i-a2 (LWJAOZBP Serial) led backlight flashes then turns off, has video (via flashlight) and audio.
      panel: au optronics T650HVN05.4
      72 led total on 12 strips, 6 led per strip wired in three groups of 24 (led driver board has three anode and three cathode pins)
      link to datasheet: https://datasheetspdf.com/pdf-file/8.../T650HVN05.4/1
      Vizio 56.04219.641G (liteon PA-3231-01WN-LF) Power Supply Unit
      https://www.shopjimmy.com/vizio-56-0...-power-supply/
      Vizio 55.75J01.001G (91.75J10.004G) Main Board...
      08-20-2020, 03:57 PM
    • Super360
      Vizio E701i-A3 Vizio logo flashing then turns off
      by Super360
      Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
      07-25-2024, 07:06 PM
    • Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable
      by Stephen
      MacBook Pro 14" M1 Pro Turns on functions then turns off when I plug in USB C cable to reset the computer. I disconnect the battery fully and then reconnect it and it won't turn back on. After letting it sit for a day I plug the battery back up, and the MagSafe 3 cable and it powers on and stays ons, once I plug in a USB C cable into the port closes to the MagSafe port it turns off and the Amber light turns off and won't turn on. No water damage, nothing, I want to do a DFU restore to wipe the computer since the customer stated they did an update and ever since it just decided to not work...
      03-15-2024, 09:37 AM
    • ossroy
      Vizio M60-C3 powers on, perfect logo, turns off
      by ossroy
      Vizio M60-C3 powers on, perfect logo, turns off. If you don't touch anything it will repeat this process by itself until it is unplugged. Not the "button board" since I disconnected the cables to the main board and the problem persisted. So I'm fairly positive something is going on with the main board, but want to know if there is a fix for this other than replacing the expensive mainboard, which may eventually have the same problem. Also, heat sink was hot as hell when this all started. Unplugged for a few days and same thing happens.
      My kids are getting antsy waiting...
      08-03-2022, 08:11 PM
