Inexive (Vestel) TV constantly blinking after plugging in
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    Hello everyone, I have a constantly blinking Inexive LED TV.
    Display is: VES390UNVA-2D-N01
    Mainboard: 17MB97​
    PSU: 17IPS71
    The TV power led start blinking constantly right after plugging it in, I tried to update via USB but did not help.
  • unimatrix93
    • Oct 2021
    • 360
    • Magyarország
    I did some measurements on the PSU and C20 and the other two 400V filter caps has only 320V total.
    Also there is a rithmical clicking noise from the PSU, like it tries to turn on.
    I checked on PWM IC FAN6300A and VDD is only 5V, and HV goes from 0 to around 175V following the ticking noise pattern.
      • 12305
      • U.S.
      Check for bad solder joints on bottom of powerboard.
      • unimatrix93
        • Oct 2021
        • 360
        • Magyarország
        I already did with microscope.
        I measure the connector on the PSU:
        ST_BY: 0V
        BL: 0V
        PWM: 3.3V
        5V_STBY: 0V
        12VCC: 12V
        I measured these while the mainboard is connected.
        • unimatrix93
          • Oct 2021
          • 360
          • Magyarország
          ST_BY: 0V
          BL: 0V
          PWM: 3.3V
          5V_STBY: 0V
          12VCC: 12V
            • 12305
            • U.S.
            Unhook powerboard from mainboard and retest standby, need standby or tv will not work. Post at least some good clear pictures of the powerboard, front and back.
            • unimatrix93
              • Oct 2021
              • 360
              • Magyarország
              With the MB disconnected:
              STBY: 0V
              BL: 0V
              PWM: 1V
              5V: 0V
              12V: 11.7V
ID:	3602410 Click image for larger version
              • Diah
                • Feb 2013
                • 6460
                yours measurements had error how could you have VCC 12V and other 0 ?
                this PSU known problem with caps 560uf 35V
                • unimatrix93
                  • Oct 2021
                  • 360
                  • Magyarország
                  I rechecked the connector voltages and I get the same results. Negative probe on the ground pins of the connector.
                  I measure 520nf capacity for the cap and It has 25V when I plug in the PSU and slowly rising to 29V.
                  • unimatrix93
                    • Oct 2021
                    • 360
                    • Magyarország
                    PXL_20250328_101130849.mp4
                    This what I measre on the FAN6300 IC VDD and HV pin - negative probe on the filter cap's negative leg.
                    Last edited by unimatrix93; 03-28-2025, 04:18 AM. Reason: added onedrive link for video
                    • Diah
                      • Feb 2013
                      • 6460
                      we cant see any things.. dont use video photos enough.... change the 560 cap
                        • 12305
                        • U.S.
                        Is that a typo, 520nf is a lot different than 520uf. one uf equals 1000nf.
                        • unimatrix93
                          • Oct 2021
                          • 360
                          • Magyarország
                          Yes, it's a typo. Also, I removed the cap from the board and I measure 504uF on it. I ordered a replacement for it, hope that will be the culprit.
                          • unimatrix93
                            • Oct 2021
                            • 360
                            • Magyarország
                            Found something weird, based on the schematic R1 should be 4.7Mohm while I measure 7.9Mohm on it removed from the circuit.
                            • unimatrix93
                              • Oct 2021
                              • 360
                              • Magyarország
                              I replaced the cap with a new one, capacity is 560, low-ESR.
                              Same symptom, 5V in missing. only 12v and 3.3v PWM.
                              • cheeky2
                                by cheeky2
                                05-25-2024, 03:27 AM
                              • snimmits
                                Polaroid P43D300 (vestel 17MB97) issues (bluetooth & various sw bugs)
                                by snimmits
                                Good afternoon,
                                I have a Polaroid P43D300.
                                It shipped with WiFi and Bluetooth.
                                Two weeks ago, I ran through the first time installation.
                                This did a full reset and went through the first time setup.
                                Once complete, I went to settings > sound.
                                selected Audio Link, changed setting from disabled to enabled, pressed green button on remote and the tv does a search (discovery) for Bluetooth devices.
                                search completes and doesn't find any devices.
                                I have tried everything I can think of.
                                Can someone provide...
                                03-01-2024, 09:26 AM
                              • KevinWysocki
                                Aya A39FHD3901/2 - Vestel 17MB82 mainboard - LED blinking
                                by KevinWysocki
                                Hi there,
                                My mother in law gave me an Aya TV, to take a look if I could do something to repair it.
                                At startup, LED constantly blinks and no image is shown (even if I light the screen, broken backlight is not the problem), also +12V power rail is fine.
                                After some research, it seems that NOR flash often fails on this mainboard, I have found the procedure to force flash upgrading with a USB key connected to mainboard USB port, pressing "OK" button on the remote and plugging the TV power cord.
                                Flash upgrade didn't seem to work,...
                                08-20-2023, 09:45 AM
                              • Jaime Morillo
                                Hitachi 32HAE2351 Vestel 17MB171 - Rotate Image
                                by Jaime Morillo
                                Mainboard: VESTEL 17MB171 Chassis: VES315WNGB - 2D - N52
                                The TV was stuck on the logo and I couldn't access the update menu.
                                I couldn't find the firmware for the Hitachi 32HAE2351 and updated it with the Toshiba 32WA2063DG - Vestel 17MB171 firmware.
                                The image result was good, but the image is inverted.
                                The image rotation/mirror function doesn't exist in the Menu Server. I can't correct the image.
                                Do you have the firmware for the Hitachi 32HAE2351 - Vestel 17MB171 motherboard or a solution to rotate the image in...
                                08-18-2025, 11:38 AM
                              • unimatrix93
                                JVC lt-32hg35e (Vestel) blinking LED
                                by unimatrix93
                                Dear forum,
                                I'm stuck with this old TV unit.
                                PSU: 17PW04-1
                                MB: 17MB62-1
                                Symptoms:
                                - Blue LED constantly blinking when connected to AC.
                                - Only sigh of life is beeping when touching the capactive buttons on the front.
                                Diagnostics so far:
                                Checked the PSU output voltages:
                                12V present
                                5V present altought its only around 4.2V
                                3V is present measured 3.4V.
                                I check TP 202 which is for the short circuit protection: 0.606V on diode mode
                                Since I met with some vestel models before with similiar symptoms...
                                05-03-2024, 03:18 AM
