Sony kd-85x85j LED blinking red 6 times
  • NolesFan
    trying to learn
    • Jul 2024
    • 94
    I know the 6 blinks are a backlighting issue, but when I pulled off the back cover and turn it on, the is a white flash from with the panel then I hear what sounds like a relay trip and the TV goes into the 6 blinking light code. Before I pull all the electronics off and checking the individual strips, there is a on the power board, a harness with 4 wires that run thru the panel, which are what I believe are the LED lines, but Im not a tech so no clue. Wires read OUT 1 + & - and OUT 2 + & - My first inclination was to remove the power board and use my LED tester and go to each + & - wire and see if I get any lighting. But I also dont want to burn anything out, hence why Im back here. I cant really find info on this model on the NET. I dont know enough that when you get the 6 blinks, the only thing you can do is change out the strip or not. Thanks for any help.
  • EazyBone
    • Jun 2023
    • 1347
    • United states
    Yes your thoughts are fine. Remove it and use the tester. The relay on and off is defitan indication of BLs bad.. so test them as you said
    • NolesFan
      trying to learn
      • Jul 2024
      • 94
      I tested, one set of wires, no lighting no movement on the meter. On the other set, got lighting and voltage change. EazyBone with your comment "The relay on and off is defitan indication of BLs bad", with a bad set of LED strips, its tripping the relay causing the 6 blinks, so change out the LED strips and ( fingers xed ) should be good to go?
      • NolesFan
        trying to learn
        • Jul 2024
        • 94
        Also, any clue on how to remove the bottom aluminum frame away from panel? I got the top and both sides, but dont think the bottom comes off the same way.
        • EazyBone
          • Jun 2023
          • 1347
          • United states
          Each TV is different and each size is slightly different I haven't had this particular one. You should post pictures because we can't tell what it looks like. Sony generally uses screws though.
            • 12206
            • U.S.
            Looks like you have two threads on the same tv, that's a nono. If you keep it in the same thread it saves from having to go over the same things that were already done or tried.
            • NolesFan
              trying to learn
              • Jul 2024
              • 94
              Eazy, I was able to get it off, it had screws but also little clips on the underside.
              So after getting only one set ( seemingly ) to light last night, I took it completely apart to expose all the LED strips. I tested each strip individually and they ALL lite. I then tested the main connections again, and both sets of leads gave power to ALL the LEDs. In any of my testing with the LED tester ( this was my first time ) none of the LEDs got very bright. I dont know if thats normal or not?
              So if ALL the LEDs seem to be working now that it had been taken apart, what would be the next logical step to look at, the power board?
              • EazyBone
                • Jun 2023
                • 1347
                • United states
                Yes next logical is power board.. but when you originally did the whole line of LEDs at once you got a problem. So flip the chassis over again and try to light all of them up through that same connector and see what happens. Id still work on the lights if you had the error there in the first place. Recreate the error as I would of never recommended taking it apart if you didn't have that in the first place
                • NolesFan
                  trying to learn
                  • Jul 2024
                  • 94
                  Eazy, ok will work on tonight after work and let you know. Ill try to post a video or at least a photo of the LEDs brightness/dimness if thatll help also.
                  How bright should the LEDs get when using the tester? When individual strips tested on the + & - of the strip ( still all connected to all other strips with the wiring harness ), it read 10 and when using the harness, it was 173 on both leads ( meaning I have 2 reds and 2 blacks in the harness ). From watching videos though, the LEDs strip seem to get fairly bright compared to what I am personally seeing.
                  • EazyBone
                    • Jun 2023
                    • 1347
                    • United states
                    Each TV is different. When you have a lot of LEDs they generally aren't as bright. If they are all equally the same brightness I wouldn't worry. Sometimes led tester doesn't provide enough amperage.
                    If both lines were 173 I wouldn't of had you open it.. you said no lighting no movement
                    If they all good then you need to inspect the PSU. Take it off and look on the back it maybe something looks black around an area
                    • NolesFan
                      trying to learn
                      • Jul 2024
                      • 94
                      Ok so I retested everything just to make sure I wasnt messing up yesterday ( worked a 13 hour shift ). The very first time I tested with the boards and everything intact, Im 99% sure that I had one side reading 173 and the other read 300 ( no lights meter never changed ). When I did the test initially, the PSU was still connected to the LED harness and I used the pins off the PSU side ( it was the only way possible to test the strips as the way Sony has the harness, it clicks in and out with the board install or removal ). Maybe I didnt have good contact, but I will say before I took the TV apart and the problem started, the only flash of light I saw on screen before the relay tripped to 6 blinks, was the lower half of the TV.
                      You can see from the photos, the results now. Both halves are reading 173. I looked over the board both front and back and there is nothing that jumps out at me. I even took photos of it to be able to zoom in to see a bit better, and I couldnt find any oddness.
                      I suppose at this point its a safe bet to put the screen back in since it seems I have working backlights, or do you feel I should off for the moment?
                      • EazyBone
                        • Jun 2023
                        • 1347
                        • United states
                        Unless it's absolutely necessary they need to put the screen back on or you need the space I would leave it off for the moment. How try and figure a way to recreate turning the TV on while your LEDs are exposed. I would see if you can disconnect the ribbon going to the t-con from the main board and maybe try and get the tv to power on without the screen on and see if your able to recreate it (if it's possible) I don't see all your boards or what you took apart .. but I would try and get it to turn on with the plug. Make sure you do not short anything out .. if you disconnect the correct parts it won't happen. Maybe it won't even turn on though sonys are tricky. Maybe someone knows how to do it here, I haven't tried with sony
                        • NolesFan
                          trying to learn
                          • Jul 2024
                          • 94
                          Right now, nothing is on the casing of the TV other than the LEDs. I can try to get the PB and MB hooked back up.
                          • NolesFan
                            trying to learn
                            • Jul 2024
                            • 94
                            Eazy, by the first photo, you can see what I reinstalled. Second photo is the TV acting as it should. LEDs went thru the start up process ( dimming up and down ) and have settled in. Currently have now been on for approximately 15 minutes.
                            • NolesFan
                              trying to learn
                              • Jul 2024
                              • 94
                              So I left the TV on thru the night, about 11 hours and woke this morning and all the LEDs were still lit. Still have a few more pieces to attach ( TCON, wifi, and panel ) but Im hoping none of those send it back to error code. I dont think they should since none of those deal with the LEDs directly.
                              • EazyBone
                                • Jun 2023
                                • 1347
                                • United states
                                Bit of a mystery..
                                • lotas
                                  • Jan 2016
                                  • 4649
                                  • Russia
                                  Sony kd-85x85j - 6 code error
                                  • NolesFan
                                    trying to learn
                                    • Jul 2024
                                    • 94
                                    lotas Thanks for the diagram, appreciate it.
                                    • EazyBone
                                      • Jun 2023
                                      • 1347
                                      • United states
                                      Yea that's helpful. I was starting to think it could be panel
                                      • NolesFan
                                        trying to learn
                                        • Jul 2024
                                        • 94
                                        Now home, I can run some tests, but couple questions....
                                        With the backlights lit up and no blinking code happening, wont the tests all come out correct?
                                        The first step says Check BL_ERR CN3000 Pin #12 on my PB BL_ERR is CN6401 Pin #8. So am I to just find the names and be sure the tests read out correct?
                                        Thank you
                                        • SevenOFF
                                          Denon AVR-X4000 – Fast red blinking after 2nd relay
                                          by SevenOFF
                                          I’m working on a Denon AVR-X4000 that goes into protection mode (fast red blinking LED) shortly after the second relay click.
                                          According to the service manual, a fast red blinking LED indicates a DC detection (DC_DET) or ASO (abnormal current) fault, meaning the unit is detecting a potentially dangerous condition on the power amp or power supply side.
                                          Here’s what I’ve done so far:
                                          • Fully opened and cleaned the unit (a lot of dust inside)
                                          • Removed and visually inspected the AMP board → nothing visibly damaged or burned
                                          • Testing is done with
                                          06-18-2025, 09:54 PM
                                        • YasaCh
                                          Sony kdl 40p5500 red light keeps blinking 3 times
                                          by YasaCh
                                          Hello...
                                          my tv almost 2 years not powerd on and when i turned it on nothing happened and only 3 red light keeps blinking
                                          i opened the back cover no sign of damage on the powery suply or motherboard
                                          when i plug in the power i hear the reley sound like tik first and another tik..after that only red keep blinking..
                                          another thing is even after i unplugged the power, The tv keeps red blinking 3 times for 2 almost 2 munites
                                          07-07-2025, 11:53 AM
                                        • shahnld
                                          Sony kdl 65xg9505 green amber blinking
                                          by shahnld
                                          Good Day.
                                          I just replaced tcon on my sony kdl 65xg9505 and getting green amber leds blinking. all voltages are ok according to working sequence.
                                          i downloaded firmware from sony and there is no .pkg fike.. after extracting it gives another file which contains multiple files like inf, payload.bin and 3, 4 other files. i just did that usb but did not worked. anyone knows anything how to do it..?
                                          green amber blinking stops after while and then starts again. tv responds to remote control on off etc. before installing new tcon backlite was coming on without backlite...
                                          01-03-2024, 03:05 PM
                                        • jchon
                                          Sony A1e 5-blinks help
                                          by jchon
                                          Hi I'm new to trying to repair TVs, but I saw a broken OLED offered for a reasonable price and thought I'd try my hand at it.
                                          I found the service manual, which was critical to know where to probe.
                                          https://www.manualslib.com/manual/20...1e-Series.html
                                          With it I was able to determine that my DKA board was bad, when P_ON#1/2 gets enabled REG_12 on the DKA board collapses. I'm assuming one of the downstream regulators has a short, but I couldn't work out which rail/component and replaced the DKA board entirely.
                                          Unfortunately the 5-blinks...
                                          06-28-2023, 11:52 AM
                                        • CSM123
                                          Sony KDL-55HX850 - Blinking 3x
                                          by CSM123
                                          Have KDL-55HX850 that seems to have been hit by power surge.
                                          Blinking red 3x - clicks on/off on the power supply board when power is held in.
                                          Replaced Power Supply G board - same response.
                                          Replaced main BAP - no response at all. Seems worse, maybe bad board.
                                          Replaced main BAP with a 2nd board - back to blinking 3x similar to original.
                                          Checked speaker impedances ok 8ohms each.
                                          Where are JL6002, JL6005 test points?
                                          Ideas for what next to troubleshoot?
                                          Could it be T-Conn or LED board? Seems that the troubleshooting...
                                          02-06-2024, 11:50 AM
