LG 65UQ7570PUJ screen flickers
  • blake.s
    • 123
    I turn the tv on and the screen flashes while its black with no sound or anything coming out of it. Acts like it is power cycling. Eventually the tv comes on after about 3-5 minutes of it doing that and works. Would this be a case of the panel going out, a board issues, or the backlights?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4462
    • Italy - Milan
    I think is more bad back lights.. to ensure this you must force backlights with no mainboard connected
    • blake.s
      • 123
      Will the backlights turn on without the mainboard connection? Or do i have to jump it to turn on?
      • EazyBone
        • Jun 2023
        • 1353
        • United states
        Disconnecting main board from PSU works on Samsungs but not all LGS.
        But yes likely backlights. Get a led tester for 15$ off Amazon and test them. Backlight repair isn't super easy if you are impatient
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4462
          • Italy - Milan
          Yes needs a jumper, post the image of the power board signals list near the output connector for the main board..
          • Diah
            • Feb 2013
            • 6437
            LG have LED BL protection circuit, if the issue at BL then was from start the protection take place.. but it sound its try to boot,, after 3-4Minutes started normal.
            you need after it started normal , put the tV in Standby , then turn on again.. if it go straight on.. then the issue with Caps warming up. use yours hair dryer to warm up the PSU or MB to see which area the TV start direct when its cool .
            • Ryan.man
              by Ryan.man
              02-04-2025, 12:23 PM
            • Chrissygizmo
              Panasonic TX-48CX350B backlights but white screen , blank screen
              by Chrissygizmo
              Hi all, I’ve got a problem I hope someone can help me fixi.
              I have a Panasonic TX-48CX350B tv , it powers up ok but the screen is blank, the backlights are working, there’s nothing else though, no picture or sound. I’m not sure what the fault is called whether it’s BLANK/ BLACK/ or WHITE SCREEN I’ve actually came across this before on a similar tv but just ended up scrapping it, I will upload pictures of the boards etc , if anyone could help me I would really appreciate it...
              01-11-2025, 03:18 PM
            • dicky96
              HP Elitebook Screen blank - backlights but no image
              by dicky96
              Hi guys
              I'm trying to fix this laptop screen
              Basically the owner is a computer shop and they brought it to me with two screens. They said the repair shop they use could not fix it, so I thought i would try to see if I am better than their current repairer!
              OK so I have the original screen which works but has lines across the bottom quarter of the screen
              I have the replacement screen, which they fitted and it worked. They then put the laptop on one side for a couple of weeks until they found a buyer. When they showed it to the buyer, the screen would...
              04-28-2021, 07:30 AM
            • reformatt
              by reformatt
              07-31-2025, 08:37 PM
            • smic717394
              by smic717394
              07-25-2024, 10:16 AM
