Samsung QE 75 Q 7 FGMTZG Power Supply dead
  • kevin_allein
    • Dec 2023
    • 45
    Hi, have this Samsung QE 75 Q 7 FGMTZG TV with no function. First analysis shows the power supply board is dead and fuse blown. Power Supply has the number BN94-11439A. I did short circuit test transistor and diodes and those do not appear to have shorts. I must admit I did not look at every single data sheet.
    In the TV was some black dust residue, so probably one of the electrolytic caps blew, but they do not show short either.
    Does anyone have schematics for that board ?
    Any good tip, what could be the issue ?
  • Diah
    • Feb 2013
    • 6376
    BN94-11439A suffer always from crack soldering at the Transformers Primary side.
    • kevin_allein
      • Dec 2023
      • 45
      I found in the meantime two N-Channel MOSFETs are dead. Those two I could not measure before, since they were completely covered in that white goop.
      How sensitive are the Samsung power supplies if I replace them with some other N-Channel MOSFET with different parameters ?
      • EazyBone
        • Jun 2023
        • 1344
        • United states
        You need to change the 2-3 blue caps there also. We have no pics so couldn't tell you. Very common death for Samsung PSU.
        I've changed different n channel parameters but not too significant and it works fine
        • kevin_allein
          • Dec 2023
          • 45
          You are talking about the ceramic capacitors visible in those pictures ?
          Two more questions: the MOSFETs were blown, but the Diode next to them measures OK. Should that be replaced ?
          There are two large electrolytic capacitors 500 V 100 µF. I took them out and they measured within tolerance 9x µF and ~0.4 Ohm ESR, so I soldered them back in. Should those be replaced anyway ?
          • EazyBone
            • Jun 2023
            • 1344
            • United states
            R221 2kv caps yes they need replacing. Even if they test good. You can obviously always take the chance not to but every repair kit I've ever seen comes with them. Generally one of them explodes, it's rare that one didn't.
            Up to you
            • kevin_allein
              • Dec 2023
              • 45
              I am having trouble to find 220 pF ceramic capacitors with 2 kV. 500 V are easy to find. As the voltage there is probably max 325V, shouldn't 500 V capacitors be good enough ?
              • lotas
                • Jan 2016
                • 4620
                • Russia
                Don’t forget about the pulse voltage, power supplies are also often set to 1kV, they very often burn and take a bunch of components with them....
                  by sam_sam_sam
                  03-31-2024, 02:12 PM
                  by sam_sam_sam
                  07-01-2024, 06:34 AM
                • cheeky2
                  Samsung BN44-00262A H37F1-9SS power supply help finding blown value components!
                  by cheeky2
                  This Samsung combined power supply and inverter was replaced a while ago from a Samsung 37inch LE37B530P7W TV. However I would like to repair this one.
                  I have replaced the Mosfets Q1820 and Q1821 ( FDPF7N50U) which were both blown and the fuse FM802S. The schematic for this power supply that is attached doesn't relate to this power supply as the driving transistors and diodes are D1830, D1831, D1832, D1833, Q1811 & Q1810 are nowhere on the schematic!
                  Does anyone know what the components for D1830, D1831, D1832, D1833, Q1811 & Q1810 should be? I ask as I did change the Mosfets...
                  06-15-2025, 05:12 AM
                • Cookybaby
                  Samsung UN60ES6500FXZA Power Supply Issue
                  by Cookybaby
                  Hello Everyone, this is my first post and I am excited to be a part of such a great community. I've been reading these forums for awhile and there really is some good friendly people here. No bashing and being rude like 90% of other forums Ive been to. Lets get to the good stuff.
                  I have two years of college in Electronics Engineering Technology. Ive been tinkering with electronics sine about 1990. I know enough just to be dangerous, so be gentle.
                  Make: Samsung
                  Model: UN60ES6500FXZA
                  Power Supply P/N: BN44-00525A
                  Symptoms: The TV was...
                  08-20-2023, 12:26 PM
