Just going to start off by saying I'm new to the forum, I'm here unfortunately due to an issue with my 47" LG TV. So this problem started about 2 months ago, where the image would looking like it was getting distorted with random lines with a greenish coloring. This would sometimes then lead to the TV being unresponsive at a white screen where only unplugging it for a few minutes would allow it to be useable again. I'm going to try to get a picture of what its doing I just never think of it due to me getting angry. Thanks for any help, I have never worked on TV's before so this is going to be a learning experience.
LG 47LN5400 Problems
Re: LG 47LN5400 Problems
i have the same tv lg 47ln5400 screen dont light up,, tv powers on i check all voltages from power suppy to the main board and everything looks right,,, my main concern is voltages from the power supply to the screen,, just in case i replaced 3 high voltage caps but still the same,,, anybody know the right voltages on connector p801 my measures are
led - 32v
led + 79v
led - 7.8v
led + 77v -
led - 32v
led + 79v
led - 7.8v
led + 77vNever stop learning
So you replaced those 4 caps by the LED connector, what DCV do you get measured right at the two legs of each when the TV is turned on each times? You have to measure one cap when TV is first turned on, then turn off the TV and move on to the next cap and measure the DCV, do that for all 4 caps.
Is this the exact matched of your board?
http://www.shopjimmy.com/lg-eay62810...upply-unit.htm
Provided by ShopJimmyLast edited by budm; 03-11-2015, 09:57 AM.Never stop learning
LED Driver board on PSU Faulty....
Common issue with LG sets....
Unfortunately the schematics are not available either for the PSU or the LED Driver, and neither is the LED Driver available separately, so you'll be looking at replacing the whole PSU
--Or modify the set to do away with that troublesome idiot LED Driver board!
See this thread where I did just that on a similar model--
https://www.badcaps.net/forum/showth...light=42le4500
Edit--Looks like you have a all-in-one PSU board without the sub-board, so implementing any modifications will be much more difficult....Last edited by Alastair E; 03-11-2015, 09:58 AM.TELEFIX
PLEASE DO NOT EMAIL ME PRIVATELY FOR REPAIR ADVICE. QUESTIONS BELONG ON THE FORUM!Comment
yes is exactly same board im working on,,, voltagages of 4 capacitors right next to connector are 77v each either tv on or off,,, thanks for quick answersComment
i bought a used power supply board even everything looks right because i found it cheap like $24.00 so at this point i think is gonna be the logic board grrrr....Comment
Usual culprit is the LED Supply. It has a controller that drives the two strings of LED's.
The + connections of the LED strings are both connected to the LED main supply rail generated by the PSU.
The Earthy end (-) is then connected to the controller transistors, where its PWM controlled for brightness, hence you see the two neg leads of the LED's at different voltages The LED strings (On a 42" set) need at least 65V Across the string to produce ANY light, so I'll guess a 47" set will need a couple of volts more....
Average running volts for a 42" I did recently was 83V, so guess your 47 will probably need say--89-95V average to give reasonable brightness picture.
Often the controller chip itself fails--and its a bit of an oddball--at least the one I had was....
--When the control-chip aint happy/faulty/fault detect, it will generate 'ERR' voltage, the main PSU then will go into 'low output' and supply 72V--Enough to make the circuit work and give a very low light on the LED's--but only if all is well--It will shut down completely after a short time.
--With fault condition, there's no light from LED's at all, even when the low-volts is presentTELEFIX
There's unfortunately no general rule on how many volts per inch - because manufacturers can use different LEDs and different levels of current to reach the required brightness. A 32" Vestel set I fixed recently used 57V; a 22" used 35V... and yet my 24" monitor had a single 100V strip...
The cathode end of the strips is balanced using a current regulator (PWM also used) to keep the current between each strip within some matched limit so the brightness is (relatively) even between strips.
If you have the panel sticker number, e.g. "LG Display LC47WXN"... I might have a datasheet with voltage/current specs.Last edited by tom66; 03-18-2015, 04:01 AM.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
For service manual, schematic, boardview (board view), datasheet, cad - use our search.Comment
anybody has the diagram or troubleshoot manual,, because i orderded the board and same thing,,, i will have to return itComment
Can you measure the voltage across the legs of the big main capacitor when the set is off and when it's "on".Comment
big fat capacitor voltage when is on is 397 VDC when is off keep going down from 397 VDC to 172 VDCComment
alfonsoreyesd,
I just repaired a 47LN5750 which has the exact same Power board and led system as yours. with the same issue and the same voltage drops.
It was a bad LED strip. I replaced it and the tv fired up perfect. I tried the PSU first and that was not it. If you pull the panel out you will find a led strip that looks a little blackened on one of the leds. probably in the L1 bank as it seems common.Comment
Silscreen mistake or some one put in the wrong Diode, but looking at the bottom side, that diode should be common Cathode so the part is correct but the silkscreen is wrong.Last edited by budm; 04-15-2015, 12:45 PM.Never stop learning
i opened the panel and yes l1 and r1 strips are kind of dusty and looks like overheated ,, but how do i test them,, if are only diodes (leds) i shouldnt have any problem test them but if i use ohms or diode any strip i test looks like open circuitComment
Can you post pictures. In my case when the L1 strip was bad in one of the L1/L2 banks one of the diodes had a distinct yellow/brown burn mark inside of it and looked different then the others. i was able to identify it with out even testing. However i moved the strips in the bad bank to the bank that was lighting momentarily to test the rest of them.
But you can power the tv with out the panel in it the back-lights should flicker on for a couple of seconds and you will be able to identify the bank with the offending strip in it. If your getting no back lights at all that means both banks of 4 strips has a bad led(s) in it.
Visually you will be able to identify them as its quite clear what one has shorted. As for them being dusty there should be no dust in there. What you are seeing cannot be dust unless some one has opened and left that unit open before exposing the screen innards and what not. the chassis diffuser and panel seal that off pretty well.
Since they are in series 1 bad strip will shut down all 4 strips in the bank.Last edited by JeffJ; 04-15-2015, 01:38 PM.Comment
on this laptop hp g72 b52sf i have screen problems as you can see with the photo joined in attachments.
the used graphic card is "intel hd graphics" and the id of the integrated screen is : "monitor/SEC3354".
i verified the driver of the pΓ©ripherals and they are ok. i verified the definition and settings of the graphic card and of the screen : definition 1600x900 and refreshment frequency :60hz. (they are the sames for the graphic card and the screen).
i don't understand the reasons of the white stripe at the bottom of the screen below the task... -
by HondamanRecently I discovered my SSD died (OCZ/Toshiba 240 GB). It was in a USB enclosure, attached to the Linksys WRT-AC1200 router. Since then I removed the USB enclosure and attached it to my Win7 PC (AMD 8150 CPU, 970 chipset, 64 GB RAM). I also gathered one or two other USB enclosures to figure out what is going on.
(I suspect that I lost quite a few MP3 and FLAC files I recently ripped from my audio CDs, I think I lost very little un-replaceable stuff.)
I think it is IMPOSSIBLE for Win7 to have any problems with a USB enclosure as long as Win7 knows how to speak to the...-
by clabrNeed help to solve some problems with this laptop.
After working in bed with it one night and heating up too much (probably the cause of this problems) the sata HDD OS windows froze
After restart the original Sata HDD was not recognized anymore (but works fine in other laptops or PCs)
Tried connecting other good Sata 2.5 HDDs but not one is working in this laptop anymore (not the original nor others)
Before this had happened I observed some other problems:
When I tried replacing original mecanical HDD with a SSD HDD could not get them... -
by rumpumpel1I have a Lenovo X13-Yoga Gen 1 that has problems with hibernation mode. When the laptop goes to hibernation mode - either via the start menu or after a time-out - after a short period of activity where the power-on LED flashes, the power consumption should go down to almost 0 and the LED should go out. Most of the time, however, the power consumption indicates further CPU activity and the power LED remains on, but there is no image. Sometimes the CPU activity stops after a few minutes, sometimes not at all. If the laptop enters this state, it can only be brought back to life by a long press on...11-03-2024, 12:31 AM
by howardc64Failure Symptom
No Display. Just random blocks of grouped vertical red lines.
Disconnect right 1/2 panel (rear view), left 1/2 displays properly
Masking T-Con Signal Diagnostic
Reduced masking to 5 signals on right 1/2 panel and get perfect picture
Pins are
1 GND
2 VGHD
3 XON
4 VSSQ
5 LC2
6 LC1
VGHD and LC1 masking is absolutely necessary to get working panel. Didn't unmask 3-5 individually.
Pictures and Schematic
XON, LC2, LC1 are on AUO s302-21 32pin QFN... - Loading...
