UN55MU8000 Power Supply Help!!
  • Storyteller12
    • Jun 2020
    • 624
    Have this power supply that is bad. Someone else messed with it prior and couldn’t fix it. I opened it up and right away there was a mosfet bad and a Diode on the heat sink.
    also a little blue cap was bad and so was the fuse.
    Bridge rectifier test good
    I replaced all bad parts and plugged in on my table. So nothing else connected.
    fuse does not blow but voltage fluctuates on primary side from 0-65v. No power on secondary obviously. I don’t see anything else that bad. I thought maybe the power ic was and removed it but same problem. I did not replace it though, just removed it
    any idea what it could be?
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4278
    • Italy - Milan
    i think you found bad QP801 and the right near diode yes? on the source of the qp801 there is a opened big resistor of low value maybe, the reason of fault are maybe the two big el.co. 500v..
    • Storyteller12
      • Jun 2020
      • 624
      Yes I found qp801 mosfet shorted and the diode right next to it. And the little blue cap right there also.
      are you talking about the 2 bigger green resistors right below all the way to the left (RP822)?
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4278
        • Italy - Milan
        yes, those 2.
        • EazyBone
          • Jun 2023
          • 1306
          • United states
          27.99 on eBay
          Let us know if you fix it, I love learning these new things
          • Storyteller12
            • Jun 2020
            • 624
            I did check those 2 resistors and they test good.
            not sure what else it could be.
            EazyBone, I already bought that board lol but was trying to fix this one as wel. Alsol because all those 50” Samsungs with all in 1 boards has same problem. Primary side voltage fluctuates just like this. I have 3 or 4 with same symptom
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4278
              • Italy - Milan
              This sounds very odd, how can the power mosfet burn without discharging at GND, but could have destroyed the oscillating IC to it connected icp801, could you check the big el.caps? Or at least paralleling other ones? Check the 2 smd diodes DP802 & 3, why there are cutted legs of power mosfet+ diodes? havent you replaced them before? checked both blue disk caps? Have you disconnected one leg of the resistors before checking them (there is a zener diode within)?
              • EazyBone
                • Jun 2023
                • 1306
                • United states
                Yes wtf is that. I can't figure it out on those Samsung all in one. Need to have Nick's TV do a video on it.
                I need to spend more time messing around with it.
                • Storyteller12
                  • Jun 2020
                  • 624
                  I was looking at that IC (icp801). I will test that one today and see if I have a replacement. I’ll double check the 2 diodes but I’m pretty sure I checked those and they tested good.
                  I did remove the big 500v caps and they test 68uf but I don’t have esr meter to test esr values. Would an lcr meter test the esr value?
                  also I did replace 1 of those blue disc caps right by the diode and mosfets that were bad.
                  funny thing, I just tested the diode that was all burned up and black and it tested good. So only the mosfet was bad, but replaced both anyway.
                  • Diah
                    • Feb 2013
                    • 6354
                    what about here the black !!
                    • Storyteller12
                      • Jun 2020
                      • 624
                      Diah, I just checked. I can’t make out exactly what it is but one side measures 12k ohms while the other side measure 2.2m ohms. I’m not to sure what that means though
                        • 12087
                        • U.S.
                        What is that, a burned out resistor? Looks like some of the solder joints are needing solder, the one right above the red box Diah outlined looks bare.
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4278
                          • Italy - Milan
                          about the green resistors and my question?
                          • Storyteller12
                            • Jun 2020
                            • 624
                            Sorry, resistors removed and both test good with same reading.
                            mad for the 2 diodes dp802-3 both test good as well.
                            I removed that ic also and still have same symptom
                            • Storyteller12
                              • Jun 2020
                              • 624
                              I don’t see burned resistor. I think it may look that way because of the silicone there. Most of that area is/ was covered in slicone
                                • 12087
                                • U.S.
                                I see, at first glance couldn't tell what it was, maybe touch up some solders and check the rest of those components related to that bad moset, did it take out ICP801?
                                • Davi.p
                                  Hobbist Tech
                                  • Sep 2009
                                  • 4278
                                  • Italy - Milan
                                  my suspicion is the PFC coil that has a burnt wire..
                                  • CapLeaker
                                    Leaking Member
                                    • 8040
                                    Should be easy to fix. Follow the AC from the input socket up going through the 2 filter inductors etc. See where you loose continuity.
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4278
                                      • Italy - Milan
                                      Removing the mosfet could be ok but removing also the power diode its not good cause the "positivized" ac line cannot flow through those two little smd diodes with the high load of the rest, the two big caps requires too much current for the small diodes and the caps do not fully charge so the voltage is dancing...i'm not sure if you ever fitted all parts also changed.ones..
                                      PS: i think i understad why the Captcha verify, the site has now few available band and the Captcha is to limit the users flow.. am i right?
                                      • Storyteller12
                                        • Jun 2020
                                        • 624
                                        Just to update and close the thread. New board came in and fixed the problem.
                                        but I did fine the short. It was a tiny transistor next to the 8pin ic. Unfortunately there so tiny and I can see any markings to identify it and replace. Didn’t want to remove new boards ic since it all covered in silicone to find out.
                                          by sam_sam_sam
                                          03-31-2024, 02:12 PM
                                          by sam_sam_sam
                                          07-01-2024, 06:34 AM
                                        • JimBanville
                                          Definitive technology SC 2000 subwoofer amp's power supply clicking and popping
                                          by JimBanville
                                          The sub developed a constant popping every couple seconds from woofer and power LED flickering with nothing but wall AC connected. Connecting an audio cable didn't change anything. It doesn't play but a second or two of audio in between the pops.
                                          Opened it up and discovered the power supply is making a faint clicking or ticking sound.
                                          I measured the amp's output to the woofer and it pulses up to 50mv DC to be driver. The pulses coincide with the power supply ticking/clicking.
                                          I measured the power supply output going to the amp board and it too has this pulsing. Voltage cycles...
                                          09-13-2023, 07:21 AM
                                        • CMCM
                                          Russound CA4 Power Supply Repair
                                          by CMCM
                                          Hello Everybody,
                                          Trying to repair a power supply from a Russound CA4 Multizone Controller (picture attached)
                                          Russound no longer supports it but were kind enough to provide a schematic of the power supply (pdf attached).
                                          The outputs marked 12v and 20v are all measuring only 1v.
                                          The board is clicking, which I think means it is in something called hiccup mode when the flyback transformers switches because of an internal problem or something else on the board Overloading it.
                                          The capacitors physically look clean (no bludgesor leaks) and...
                                          07-03-2025, 01:12 PM
