Have this power supply that is bad. Someone else messed with it prior and couldn’t fix it. I opened it up and right away there was a mosfet bad and a Diode on the heat sink.
also a little blue cap was bad and so was the fuse.
Bridge rectifier test good
I replaced all bad parts and plugged in on my table. So nothing else connected.
fuse does not blow but voltage fluctuates on primary side from 0-65v. No power on secondary obviously. I don’t see anything else that bad. I thought maybe the power ic was and removed it but same problem. I did not replace it though, just removed it
any idea what it could be?
