I have this LG and the story is basement flooded but no water got TV but when cleaning up water some splashed on Tv in right lower corner of the front. and now this is the picture displayed and sound works..Is it Tcon or panel?:
Lg 55lw5600
Re: Lg 55lw5600
Doesn't look like it has a tcon, if it does it's hidden by the stand.
I'd recon it doesn't because the mainboard has 2 ribbon cables coming from it rather than one.
Also you said the lower right got wet, in this tv the tab bondings to the panel are at the bottom of the tv, rather than the top.
Try unplugging the right hand ribbon cable, you might get an image on the left of the screen. If you do it's the panel. -
Re: Lg 55lw5600
tcon bottom
http://www.badcaps.net/forum/showthread.php?t=39740Comment
Re: Lg 55lw5600
The link I posted is the Samsung engineers training manual for that set.
Clearly shows the tcon at the bottom.
Maybe it frightened you off as it was the original google search link
Here is a shorter version.
by kcaHello all ~
I got the display to work by taping off several traces of the right-hand side ribbon cable on the TCON that leads from TCON to PANEL. However, despite dozens and dozens of attempts to find the right combination / range of traces taped... -
by sam_sam_samI got lucky that when I got home and was about to get some ice out of the ice dispenser I hear and see water running down the outside of the ice dispenser what the heck is going on here
At first I thought that the ice dispenser mold was cracked so I brought a new ice maker because this one has been in there for about 10 years now
Well I put the new one in and wait and I wait for the water valve to open and let water in no such luck well there is a way to check the function of the motor and the water valve on this ice maker just need a jumper wire “L” to... -
by advantThis thread is about trying to get an Universal Main Board to work with a Sharp TCON and panel.
I have a Sharp LC-46D85UN TV that has had a main board issue. Since this model is from 2009, I am not able to find an exact replacement of the main board. Instead, I decided to see if I can future proof this tv by getting a Universal Main Board (T53U21.2) from China to work with the Sharp TCON (CPWBX4291TPZA) and panel. The universal main board supports a 8 bit dual channel LVDS interface whereas the TCON requires a 10 bit dual channel LVDS input. I have modded the LVDS connector to match... -
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... -
Good day, I have a TCL TV: Model 43s423. After turning ON the TV, the ROKU TV logo appears with fine lines over the whole screen, then after a while there are vertical bands in the middle of the screen top to bottom and the TV tries to update its firmware but I do not have the remote to connect it to my new network connection. Also the Power ON light blinks 2 times in quick succession. When I remove the ribbon on the right of the tcon board the left side of the screen shows but with fine lines. If I remove the left side ribbon and connect the right side ribbon the whole screen is blank with...
- Loading...
