Samsung LE40A567 - Dim picture
  • Jooo
    • Oct 2011
    • 222
    • Finland
    I have a Samsung LE40A567 LCD TV with a very dim picture.
    I found that PWMDIM was low.
    I connected PWMDIM to 5V through 1K resistor, and that restored the backlights and the picture was normal.
    I could access all the menus etc, but I couldn't tune any channels.
    I assume the mainboard is faulty. What could cause the PWMDIM to go low (0,2V) ?
    The mainboard model is BN41-01022D, I can take pics tomorrow if needed.
    Re: Samsung LE40A567 - Dim picture
    It could be a corrupted EEPROM. Try doing a factory reset.
    While the TV is in standby, press Info, Menu, Mute followed by Power. When the TV turns on select the reset option and execute it.
    • Jooo
      • Oct 2011
      • 222
      • Finland
      Thanks,
      I removed the resistor before doing the factory reset, and now the backlights turned on even without the resistor.
      I still did the factory reset and now it found the channels too and everything seemed to work normally for a while (less than 5 minutes).
      Suddenly it lost signal, and only one channel continued to work.
      I restarted the TV and the backlights were flickering for a second or two after turning the TV back on.
      Then it was back to normal but only one channel works, no signal on the others.
      • selldoor
        Slow Learner
        • 7870
        Hi I am trying to follow this but there is not much information on the LE40A567
        One site does suggest that this is NOT a set with LED backlights.
        PWMDIM seems to be associated with LED backlights so can you confrim that
        your set has LED and not CCFL tube backlight.
        Perhaps pictures would help.
          With a few rare exceptions all "LE", "LN", " LA" Samsung TVs have ccfl backlights
          • Agent24
            I see dead caps
            • Oct 2007
            • 4951
            • New Zealand
            Could be whatever drives it is faulty, open pullup resistor (if any), or something shorted\low resistance to ground on the line. Or like tom66 said, a software issue - and that could be caused by many things...
            -David VanHorn
            • Jooo
              • Oct 2011
              • 222
              • Finland
              Heres a few pics.
              It has CCFL backlights.
              The backlights work all the time now, although when turning the TV on they flicker for a second or two.
              • sordids999
                SAMSUNG UE43AU7020K BACKLIGHTS BUT NO PICTURE
                by sordids999
                Hi
                Really stuck on this TV
                I'm thinking it's a bad screen ?
                Voltages all seems good
                Tcon 12v ok
                Remove one tcon cable at a time no half image on the screen just backlight and no picture
                even tried the tape trick still no luck
                Thanks...
                05-12-2025, 10:36 AM
                09-07-2024, 05:50 AM
              • TR103
                by TR103
                - it keeps rebooting
                01-22-2025, 04:12 PM
              • stinger
                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                by stinger
                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                04-17-2024, 03:06 PM
              • JJAAMM
                by JJAAMM
                Problem
                07-06-2023, 06:01 AM
