Hisense 58A6KV
  • Helikvar
    • Jul 2018
    • 68
    With D13 removed the pads are still reading shorted .D12 reads shorted as well.D13 reads infinity in both directions perhaps I overheated it removing it .
    . Strange thing is both the anode and cathode seem to be connected to the ground on both diodes which makes no sense.
    There doesn't seem to be separate tracks for each only the common ground.Pics are included to show this .
    • Helikvar
      • Jul 2018
      • 68
      Originally posted by lotas
      So it is soldered on both sides to ground... Plays the role of a limiter, a height support...
      Yes it is soldered to ground on both sides.Ok meaningless other than as a support.
      • Helikvar
        • Jul 2018
        • 68
        D22 anode to cathode .233v leads reversed infinit
        D16 anode to cathode .228v leads reversed infinit
        D20 anode to cathode .228v leads reversed 2.69v
        D18 anode to cathode .249v leads reversed 1.43v
        D15 anode to cathode. 233v leads reversed infinit
        Q3 drain to source .581v leads reversed infinit
        Q4 drain to source .580v leads reversed 1.99v
        Q5 drain to source 2.44v leads reversed .454v
        Q3,Q4 p-CHANNEL mosfet
        Q5 n-channel mosfet
        T4 npn transistor checks ok
        VGHF 28.1v
        VGL_GOA -10.25v
        VSS1 -8v
        ​VIN 12.06v
        R_VAA 15.28v
        • Diah
          • Feb 2013
          • 6565
          this measurements above in circuit or out side the circuit ?
          • Helikvar
            • Jul 2018
            • 68
            In circuit
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4539
              • Italy - Milan
              #26
              Please, read my sticky thread about photos, i'm unable to download them..
              • Helikvar
                • Jul 2018
                • 68
                Ok I've reduced one photo down to 2000 by 2000.Let me know if that is satisfactory and also any other photos you want me to reduce or retake at the requested resolution
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4539
                  • Italy - Milan
                  #28
                  on the post #23 all measures correct.. i don't know why before i could watch the separated tcon pic. now i don't, if you can reduce it..
                  • Helikvar
                    • Jul 2018
                    • 68
                    Is this the one you are referring to ?.I've reduced it .
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4539
                      • Italy - Milan
                      #30
                      this Hisense separated tcon + integrated tcon is creepy.. the measures of the post #5 , where are taken? i was meaning the separate tcon, but them are doubled also on the integrated tcon (shame on Hisense) and must be measured also there, i need also a broader view of the integrated tcon 'cause i need to find the HVAA circuit and also the rest..
                      • Helikvar
                        • Jul 2018
                        • 68
                        Sorry the last pic was cut off on the ends I resized it to see entire tcon board.
                        • Helikvar
                          • Jul 2018
                          • 68
                          The measurements on post 5 were taken from the tcon board which attaches to the mainboard/power supply..All other measurements taken from the integrated control board attached directly to the panel.
                          . The HVAA voltage reading is the same on both boards and the one causing the problem as it reads low at 3.3v as you pointed out.
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            #33
                            do you have to do the Captcha verify code each post? because is i do and is very annoying..
                            have you checked every 0 ohm resistor?
                            is c221 between HVAA testpoint and GND? (panel tcon, let's call tcon 2).
                            anyway i suspect that cap, if you can, replace it.. By the colour / size it seems low capacity, maybe 1-2 uF
                            • Helikvar
                              • Jul 2018
                              • 68
                              Yes captcha eveytime and I agree very annoying.Checked all 0 ohm resistors and all read 0 ohm .Yes C221 is between HVAA test point and ground .It reads infinity when multimeter is on ohms .You think I should replace it even though it doesn't show its shorted.?
                              . Now to do another @#$$%# captcha.
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4539
                                • Italy - Milan
                                #35
                                yes i think that getting another cap from an used board instead of throwing the entire tv it deserves a lilttle effort.. caps can short maybe under certain temperature.. i do not see a separate ps for HVAA voltage, so in many sets it is obtained by a capacitor voltage divider, i do not see the other one..
                                • Helikvar
                                  • Jul 2018
                                  • 68
                                  Changed C221 and voltage on HVAA still drops down to 3.34v from 7.99v when powered on with remote after a few seconds.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4539
                                    • Italy - Milan
                                    #37
                                    Can you tell me the voltage of each term. of those resistor / caps respect to GND? I feel strange that HVAA is created by I5 on TCON 2 and returns to TCON 1 (see test points)...
                                    • Diah
                                      • Feb 2013
                                      • 6565
                                      disconnect the LVDS from T-CON. and apply 12V to T-CON F1 turn on if BL didn't light up use torch light to explorer the screen RGB Test, if u get it go head to replace the MB
                                      • Helikvar
                                        • Jul 2018
                                        • 68
                                        I already tried the 12v injection from main board to tcon board and rgb test begins but screen goes dark as soon as the HVAA voltage drops from 7.99v down to 3.34 v .I only see about 2 colors mostly yellow on entire screen but it quickly fades away .The backlights also come on and stay on.
                                        • Helikvar
                                          • Jul 2018
                                          • 68
                                          values are in this text file
                                          • NWArkGuy
                                            Samsung UN65TU8000 - Panel Issue [ hole in ribbon cable ]
                                            by NWArkGuy
                                            Well, I will be the first to admit that I screwed up...
                                            In attempting to replace the backlight in a UN65TU8000, I made a hole through one of the ribbon cables between the board that runs along the bottom of the back of the TV and the panel. This lead to a between a 1/4 to 1/2 inch vertical stripe running the full height of the image.
                                            I don't have the experience; personally, to solder a bridging wire for the paths that were cut. So, I have been on the hunt for other Samsung TV's of similar size.
                                            I have 2 that I have found and have in my possession. ...
                                            10-12-2023, 10:13 PM
                                          • mecha1166
                                            Reattaching new edge to edge LCD panel to tv frame - Hisense 55a6g and others
                                            by mecha1166
                                            Some new tvs have an LCD screen attached to the outside of the frame with foam tape. These are "edge to edge" as they are called. I am trying to figure out how to reattach an LCD panel back up to the frame. The manufacturer used 3/16 inch foam tape along the top and rh/lh edges. I used a razor blade to separate the panel from the metal frame. The metal frame that the panel is taped to is 1/4 inch wide along the 2 sides and top. I completely removed the residue from the metal frame. There is some residue on the panel itself along the 3 edges, I removed almost all of it using alcohol and...
                                            06-13-2024, 02:28 PM
                                          • howardc64
                                            by howardc64
                                            07-24-2025, 05:17 PM
                                          • AK_777
                                            Sony KD-65A1 Repair – 4 Red Blinks Error
                                            by AK_777
                                            Hi everyone!
                                            I have a Sony KD-65A1 TV with a fault – 4 red LED blinks. After disassembly and visual inspection, I found that the G76 power board and DKA board had been replaced. It is also possible that TCON was replaced, but I am not sure – there are a few marker marks that could be factory-made.
                                            Based on assumptions, the previous service attempted to solve the issue by replacing potentially faulty components. I decided to investigate further, found a service manual, and figured out a way to power up the power supply unit autonomously and put the OLED panel and...
                                            02-20-2025, 04:15 PM
                                          • ojmc
                                            Hisense 65H6570G - Color inverted after replacing LED backlight
                                            by ojmc
                                            Background:
                                            • Hisense 65H6570G stopped working and I root caused to a burnt out LED in the backlight. (For anyone interested the power light pattern when the backlight has gone is 1) two long flashes, 2) a very short third flash, then 3) back to solid red )
                                            • I replaced all 6 of the backlight LED strips with these replacements: amazon
                                            • The TV worked again perfectly for ~2 weeks.
                                            • After that 2 weeks the colors became "inverted". The TV powers on and shows the boot screen in correct colors initially (aqua hisense logo on black background, pic on the left) but a few seconds after boot
                                            10-17-2024, 02:29 PM
