Philips 42PFL7422D/37 backlight shuts off in 2 seconds
  • brainiac88
    • Jun 2014
    • 21
    Noob to the forum. I've read dozens of threads on this unit and looking for some advice on repairing my TV. I've taken the entire TV apart, down to separating the LCD from the backlight.
    System Info:
    -LC420WU5
    -Master Inverter: 6632L-0470A PNEL-T707A REV-1.2
    -Slave Inverter: 6632L-0471A PNEL-T708A REV-1.2
    Symptoms:
    - Backlight goes off ~2 seconds after powering on
    Observations:
    - Blue LED on Master Inverter lights up when powering on, then fades to off, just as the backlight shuts off.
    - The area of the backlights toward the side of the Slave Inverter appear to be dimmer than the side toward the Master Inverter. But it is hard to be definitive on this observation because it shuts off too quickly.
    - Audio is OK even after backlight goes off. Test is using HDMI-2 input
    - LCD image OK. [I put a high-powered light behind LCD and image is just fine]
    - CCFL tubes all appear to not have any dark spots. All white, consistent across all tubes.
    - Both inverter boards are pristine. No bulging caps, fried ICs, traces, or any obvious burn marks on either side of both boards.
    - Power supply board does not appear to have any burn marks, bulging caps, fried traces, or other obvious damage on either the component or trace side.
    Questions:
    - What other tests should I perform, if any, to get a more precise diagnosis?
    I do have a DMM, fine-tip and standard soldering equipment. Also have access to scopes, desoldering equipment, etc. at work.
    Thanks for any advice. Hope this helps others as well.
  • selldoor
    Slow Learner
    • 7870
    Re: Philips 42PFL7422D/37 backlight shuts off in 2 seconds
    If you have read dozens of threads you will have seen we like pictures.
    Please post using add attachments jpg less than 2mb load quickly.
    Your problem seems to be just the inverter/bulbs section so there are a few tests you can do. Do you have a spare ccfl tube and a working cfl 13watt bulb
    • brainiac88
      • Jun 2014
      • 21
      I do not have a spare working CCFL tube of the same size. Can I use a smaller CCFL from a laptop panel?
      And yes, I do have working CFL bulbs, from 4W up to 23W.
      Images:
      • selldoor
        Slow Learner
        • 7870
        I forgot philips used these I will have to look back. In the meantime have you tested the two fuses White surface mount. Also tubes in panels are CCFL and bulbs are CFL if you want to edit your post.
        • brainiac88
          • Jun 2014
          • 21
          Thanks for the correction.
          No, I have not tested those. Will do when I get home. I assumed they would be okay because the bulbs did fire up for about 2 seconds.
          • brainiac88
            • Jun 2014
            • 21
            By the way *selldoor*, is the blue LED on the Master inverter supposed to be on when working properly? Or is it a fault indicator?
            • brainiac88
              • Jun 2014
              • 21
              Both fuses tested okay. Fractions of an ohm.
              What shall I test next?
              • selldoor
                Slow Learner
                • 7870
                Found it !
                See if your boards have been modified
                https://www.badcaps.net/forum/attach...4&d=1341620604
                as in this thread
                https://www.badcaps.net/forum/showthread.php?t=17561
                Yours may not have shorted but the mosfets may have gone.
                • Dgtech
                  E. Technician
                  • Apr 2009
                  • 1462
                  • Steeler
                  A few years back, I posted on a thread here how to check these inverters for a common failure.
                  https://www.badcaps.net/forum/showth...974#post129974
                  Also... If the caps on the inverters are not bulging, check them anyways with a cap meter.
                  • brainiac88
                    • Jun 2014
                    • 21
                    Okay here's what I've got so far:
                    - All 8 MOSFETs on both boards tested with ~8.5k across the two legs
                    - Tested DC resistance between transformer legs. See pic. All pairs (A-B, C-D, pairs on other side of transformer also) tested with zero ohms on both transformers of both boards EXCEPT for C-D on the Master board. Both transformers on the Master board between terminals C-D measured about 750k ohms.
                    Any tests I can do with a CFL bulb or a laptop CCFL tube?
                    • Ltank
                      • Jun 2013
                      • 776
                      When the backlight shuts off, is the BL-on cmmand still coming from the main board or does it shutt off killing the backlight?
                      • brainiac88
                        • Jun 2014
                        • 21
                        How do I test "BL-on command" ?
                        • selldoor
                          Slow Learner
                          • 7870
                          Unless you can find a pin on the connector between main board and power board that is labelled blon or someone replies who knows you are stuck with that pity Ltank didnt elaborate.
                          Going back to the resistance tests on the inverter transformers you said the pairs of pins on the other end tested at zero. Can you test them again I think each close pair may be connected and the test should be across the two pairs. Resistance should be quite high I believe 3-5 kohms. So please test A to B A to C A to D then B to C and Bto D (just copying the letters used on the other end)
                          • brainiac88
                            • Jun 2014
                            • 21
                            Hi guys,
                            Sorry, been out on vacation.
                            Anyhow, here's what I've got for the tests on the inverter transformers. MTs are the ones on the Master board, and STs are the ones on the Slave board. See photo...
                            • brainiac88
                              • Jun 2014
                              • 21
                              So because no one replied, I ordered replacement inverters off of eBay. I installed them last night and they work perfectly. Hopefully, they last.
                              Lesson here is that if the backlight goes off after 1-2 seconds, AND if the CCFL tubes do not have black spots or bands, the inverters are bad. So either replace them both, or try to do component-level troubleshooting.
                              • selldoor
                                Slow Learner
                                • 7870
                                Good fix
                                The other thing you could do to be helpful would have been to measure the resistances on the new ones and compare with the old ones. The list you have given is not really much use at all as the test is to look for differences of more than 3%
                                • brainiac88
                                  • Jun 2014
                                  • 21
                                  Right, I thought of that too. However, the new inverters were of a different design - see phot. Cost was under US$40 shipped.
                                  • riko 656
                                    Lenovo Legion Slim 5 16APH8 (RTX 4070) - Turns on for a few seconds then shuts off. BIOS issue.
                                    by riko 656
                                    I need help with my Lenovo Legion laptop. It turns on for a few seconds and then immediately shuts down. I believe this is a BIOS corruption issue.
                                    Laptop Model:
                                    • Model: Lenovo Legion Slim 5 16APH8
                                    • GPU: NVIDIA GeForce RTX 4070
                                    • Main BIOS chip size: 32MB
                                    • VBIOS chip size: 16MB
                                    Problem Description: The laptop was working perfectly. Now, when I press the power button, the keyboard lights up and the laptop powers on for just a few seconds, then it shuts itself off completely. After researching, I am convinced it's a corrupt BIOS.
                                    What I Have Tried So Far:
                                    1. I
                                    11-04-2025, 05:14 AM
                                  • chaos-theory
                                    Asrock z97x starts then shuts off after 4 seconds, sometimes more, no post
                                    by chaos-theory
                                    I have a really weird problem, this motherboard was working normally, someday it just started and all fans were running but didn't want to post, tried resetting bios, checking CPU and it was getting warm tried external gpu, flashed bios with programmer, but same problem.
                                    Next day after several attempts the board goes into protection mode, no more staying on, I turn on the PSU fans starts directly turning, it used to not start until I press the pwr button, now it starts directly and fans spins, and shuts off after 3 seconds sometimes less, then won't start again unless I unplug the PSU and...
                                    03-14-2025, 05:37 PM
                                  • riki_22
                                    ASUS B5402CEA – Laptop powers on for a few seconds then shuts down
                                    by riki_22
                                    I’m working on an ASUS B5402CEA notebook.
                                    B5402CEA_MB_R2.2
                                    HA4YT LA-L861P
                                    REV:1B
                                    The board powers on, fan spins for a few seconds, then it shuts down by itself.
                                    I suspect the BIOS might be corrupted.
                                    Could someone please check and clean (repair) the attached BIOS dump?
                                    I’ve also attached a few photos of the motherboard for reference.
                                    Thanks in advance for your help!
                                    11-03-2025, 04:38 AM
                                  • APOPAP
                                    Panasonic National NV-M3 VHS Camera shuts down after some seconds
                                    by APOPAP
                                    Hello everybody,
                                    First post here. I have been reading posts here for some time now, but today I made my first account and post.
                                    The same question is also posted on another site, here it is:
                                    Just found an old Panasonic National NV-M3 VHS Camera without the original charger but with a special bag with a led, switch and fuse that is designed for a lead-acid 12v 6Ah battery. It has two cables coming off the bag that leads to the camera terminals (Only + and - ). Pretty sturdy design I think.
                                    I tried connecting it to a Computer PSU (12.7v) but I get battery error...
                                    08-25-2025, 10:12 AM
                                  • tec3000
                                    Sony LED 65X9005A shuts down after few seconds - looking for help
                                    by tec3000
                                    Hi community! Germany calling I am wondering if you guys can help me out. I have an issue with my Sony LED TV. I've been told this is a good place to ask. Thanks for anyone who will reply and offer advice. Appreciated!
                                    I have a KD-65X9005A Sony 4k LED TV. For a few weeks I've got this problem where I turn on the TV and within a few seconds the TV starts getting darker until it shuts itself off and I get the 4 blinking error code. HOWEVER there is one exception: Whenever I switch to the i-Manual, a full screen on-screen instruction manual, the TV never turns off. I tested for hours!...
                                    03-20-2024, 07:29 AM
