Strange LG TV issue : Image vertical lines in black screen
  • Ancient1
    • Dec 2019
    • 275
    • Israel
    Hi
    Asking for a friend.
    I'm used to black vertical line in otherwise good image - probable solution is a rubber to push and tighten the COFs bonding.
    but here its the opposite !
    TV has new T-con = same issue
    A missing panel voltage would have global effect
    So , what should one do ? how can I find where the fault is ?
    Thanks !
  • EazyBone
    • Jun 2023
    • 1362
    • United states
    Panel short it appears. I would say it's dead.
    • Ancient1
      • Dec 2019
      • 275
      • Israel
      Thx EazyBone
      Turns out the guy has 3 ( 3 ) of that Model with SAME issue. I asked him to note the production date , might be (emerging) known issue.
      For now , I sent him to look for fluctuating VGH VGL LCx..
      • Diah
        • Feb 2013
        • 6504
        this LG EBT64022702 Main Board with ONE SoC knowing issue with BGA at SoC
        • EazyBone
          • Jun 2023
          • 1362
          • United states
          It'll cause lines like that?
            • 12317
            • U.S.
            It can, many things can make strange lines, bad tcon, bad cap, tvs diode etc.
            • Diah
              • Feb 2013
              • 6504
              yes. exactly these lines at the middle are SoC BGA
                • 12317
                • U.S.
                Thanks Diah, I bet many tvs wound up thrown out only needing mainboard replace/repair. I remember SO many times that certain member, not Easybone but the one that always gives bad harmful advice telling everyone bad panel all the time.
                • Ancient1
                  • Dec 2019
                  • 275
                  • Israel
                  Thx ! it does make sense because these are image ( production lines ) lines and not no_image ( usually dark / black ) lines.
                  Does reflowing work ? or is it a faulty IC ?
                  I'll try to reflow and report here
                  • Ancient1
                    • Dec 2019
                    • 275
                    • Israel
                    test
                    • Ancient1
                      • Dec 2019
                      • 275
                      • Israel
                      LG 49SM5KB
                      Reflow = No change.
                      New T-con .
                      Could it be Firmware corruption issue ( Logo appears etc ofc )
                      • Stanley1843
                        by Stanley1843
                        06-29-2024, 11:54 AM
                      • x_orange90_x
                        TCL 50S535 bad tcon or panel issue?
                        by x_orange90_x
                        Just bought this for 10 bucks yesterday hoping to fix it. The guy said water dropped inside from a dehumidifier hose and it started showing black and white vertical bars then went blank. When I got it home and turned it on it came on fine and displayed correctly but I was noticing faint vertical bars in the image. After a little bit I turned it off and back on and it was a black screen again. I opened it up to check for water damage and corrosion but didn't find anything of the sort. I cleaned the ribbons anyway and reconnected them but still got a blank screen. If I disconnect the right side...
                        03-29-2025, 11:02 PM
                      • kca
                        by kca
                        Hello all ~
                        08-31-2025, 06:38 AM
                      • spice_disc
                        Vizio TV M50-C1 reboot cycle and static on screen
                        by spice_disc
                        I'm currently trying to diagnose and fix my Vizio TV (Model M50-C1). I've tried a number of different basic solutions, but I'm trying to determine if my issue is currently a failing panel, T-Con board, or main board (or something else entirely) and whether or not it is worth my time to fix it. Details of the issue and what I've tried are below as well as why I think it is either a bad panel, T-Con board, or main board.
                        The Issue: The TV will be on and working fine but after the TV is on for ~5-10 minutes the screen will freeze (with sound continuing) until the TV reboots itself. While...
                        09-08-2024, 02:37 PM
                      • wizard13
                        Dynabook Satellite Pro C50D-B-100 - BIOS Issue, Black Screen
                        by wizard13
                        I am experiencing a BIOS-related issue with my Dynabook Satellite Pro C50D-B-100. When I power on the laptop, the screen stays black, and there is no response from the system. I suspect a corrupted BIOS.
                        I have checked the forum and the available documentation but could not find a solution specific to my issue.
                        • Brand & Model: Dynabook Satellite Pro C50D-B-100
                        • Part Number (P/N): PYU13E-00C00PFR
                        • Serial Number (S/N): 22028896H
                        • System Configuration (SC): A1PYU13E1127
                        • Motherboard Model: IP3_ACN16_MB_V21_20211222A
                        • Power Input: DC 19V –
                        02-28-2025, 02:43 AM
