Sony no control with remote
    Hi- i'm working on sony tv model kdl 32l 5000 and everything seems to be working ok except remote. I tried different remotes. No luck. I pulled out sensor panel and checked for voltage on sensor and measured 3.28 volts on one side of infra-red det. But nothing happens when you press any of buttons on remote on any of pins of plug going to the board. I suspect the light detector. Has anyone had any problems with this?
    Re: Sony no control with remote
    Is the remote sending signal??
    Test by turning on an AM/FM radio to the AM band then bring the remote very close to the radio and press the power button and hear if you are betting a series of beeps. If not change the remote batteries and retry. If nothing then carefully open the remote and wipe the carbod contacts on the pad and board with isopropyl alcohol and do adiode check on the infrared diode.
      You can also check the IR is working with a webcam or digital camera.
      You may not see any change in voltage on the sensor with just a multimeter, you probably need an oscilloscope.
      -David VanHorn
        You need to watch this video
        http://www.youtube.com/watch?v=imF8_DHUPmU
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
          Thanks Martino--Looked at the video and followed diagram. Found shorted cap. right away. Thanks you saved me a lot of work. Having a diagram sure helps.--Sam
            Where was this shorted cap found.....Just in case I encounter the same issue... Thanks
              MLCC (failure mode for MLCC is shorted circuit) 10uF Filter caps (there are two of them, one of them failed) at the VCC pin of the IR receiver module. He removed MLCC and replaced them with electrolytics type.
                I think the cap. was 9013 located near IR rec. There was 2 10mfd parallel which made 20 mfd. I removed bad one which left 10mfd. worked very good on 10 mfd so I left it that way. I did"nt want to take chance on soldering on that small board.
                  It is an odd circuit with so many MLCC and resistors, I'm not sure why Sony did it like that.
                    Thanks for the feedback.....I'll jot that down in my 'tough dog' note book
