Sony no control with remote
  • tvtanner
    tvtanner
    • Feb 2014
    • 70
    • usa
    Hi- i'm working on sony tv model kdl 32l 5000 and everything seems to be working ok except remote. I tried different remotes. No luck. I pulled out sensor panel and checked for voltage on sensor and measured 3.28 volts on one side of infra-red det. But nothing happens when you press any of buttons on remote on any of pins of plug going to the board. I suspect the light detector. Has anyone had any problems with this?
  • Andrew F. Ali
    • Jan 2014
    • 2450
    • Trinidad & Tobago
    Re: Sony no control with remote
    Is the remote sending signal??
    Test by turning on an AM/FM radio to the AM band then bring the remote very close to the radio and press the power button and hear if you are betting a series of beeps. If not change the remote batteries and retry. If nothing then carefully open the remote and wipe the carbod contacts on the pad and board with isopropyl alcohol and do adiode check on the infrared diode.
    • Agent24
      I see dead caps
      • Oct 2007
      • 5035
      • New Zealand
      You can also check the IR is working with a webcam or digital camera.
      You may not see any change in voltage on the sensor with just a multimeter, you probably need an oscilloscope.
      -David VanHorn
      • martino
        Not so "senior"
        • Aug 2013
        • 997
        • canada
        You need to watch this video
        http://www.youtube.com/watch?v=imF8_DHUPmU
        Proud owner of dozens of broken TV's and many,many,many boards.
        Our website and passion:http://hollenhundshepherds.com/
        • tvtanner
          tvtanner
          • Feb 2014
          • 70
          • usa
          Thanks Martino--Looked at the video and followed diagram. Found shorted cap. right away. Thanks you saved me a lot of work. Having a diagram sure helps.--Sam
          • Andrew F. Ali
            • Jan 2014
            • 2450
            • Trinidad & Tobago
            Where was this shorted cap found.....Just in case I encounter the same issue... Thanks
              MLCC (failure mode for MLCC is shorted circuit) 10uF Filter caps (there are two of them, one of them failed) at the VCC pin of the IR receiver module. He removed MLCC and replaced them with electrolytics type.
              • tvtanner
                tvtanner
                • Feb 2014
                • 70
                • usa
                I think the cap. was 9013 located near IR rec. There was 2 10mfd parallel which made 20 mfd. I removed bad one which left 10mfd. worked very good on 10 mfd so I left it that way. I did"nt want to take chance on soldering on that small board.
                  It is an odd circuit with so many MLCC and resistors, I'm not sure why Sony did it like that.
                  • Andrew F. Ali
                    • Jan 2014
                    • 2450
                    • Trinidad & Tobago
                    Thanks for the feedback.....I'll jot that down in my 'tough dog' note book
                    • tmhobadcap
                      Pioneer VSX-522-K remote control not working???
                      by tmhobadcap
                      I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                      At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                      12-24-2020, 01:44 AM
                    • snme
                      Sony remote control RM-GD007 glued?
                      by snme
                      Have not found a manner to open this remote without a hammer or grinder.
                      So far as I can tell, there is no manner to decently open it and remove oil from the contacts.
                      Any secret technique would be welcome.
                      09-12-2023, 04:20 AM
                    • piipo
                      Old Privileg 5.1 speakers remote control question
                      by piipo
                      Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                      09-18-2024, 01:55 AM
                    • hemant_2222
                      Schematic for Denon Remote Control RC1156
                      by hemant_2222
                      Hello Everyone,
                      Hope everyone is enjoying their repairs at hand!.
                      I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                      I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                      Please refer to the attached picture, i think the voltage divider is missing...
                      10-06-2023, 02:05 AM
                    • crackedprint
                      Sony HCD-HX80R Amplifier Volume Control Problem
                      by crackedprint
                      I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                      I have tried a Cold Reset as per the service manual.
                      I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                      I have looked all the way through the service manual and tried many online...
                      01-21-2025, 12:18 PM
