Sony remote control RM-GD007 glued?
  • snme
    • Feb 2016
    • 26
    • AU
    Have not found a manner to open this remote without a hammer or grinder.
    So far as I can tell, there is no manner to decently open it and remove oil from the contacts.
    Any secret technique would be welcome.
  • nomoresonys
    • 12328
    • U.S.
    Re: Sony remote control RM-GD007 glued?
    https://www.youtube.com/watch?v=K6PvNUfWOR8
    • snme
      • Feb 2016
      • 26
      • AU
      Thanks for that video link.
      Evidently it was a different build from the unit at hand.
      There were no screws, unlike in the video.
      But it gave me a clue as to which direction to spudger, in particular with the buttons facing bench.
      The fact of a separable shell was highly concealed by a raised strip along both sides of the front section.
      It was necessary to use a very sharp spudger with significant force to crack it.
      In the process, managed to cut my thumb.
      I almost gave up, with the notion to buy yet another replacement, or two!
      p.s. Increasingly, I will insist on remote controllers be within a plastic jacket!
      • nomoresonys
        • 12328
        • U.S.
        The one in the video has the same model number as yours but I would not be surprised if it was different, the chinese are always copying everything, maybe he had one of their knockoffs.
        • redwire
          • Dec 2010
          • 3912
          My quote:
          "To disassemble this Sony remote (RM-YD029), do not pry the silver side-trim out at all. It has interlocking fingers between the top+bottom pieces.
          You have to pry the top and bottom clamshell apart using a metal guitar pick. Start at the mini keypad end and work to the other end."
          For the repair, I had to glue on new keypad pads, and the electrolytic capacitor was in backwards polarity. Take that Japan! says china lol.
          edit: that post the repair failed with Velostat. Need replacement silicone rubbedr pads, later in that thread.
          • snme
            • Feb 2016
            • 26
            • AU
            Actually I was dealing with the originally issued item so far as I know.
            I could be wrong since it was from a relative that didn't want to pay and take the risk of a T-Con replacement.
            It was marked as made in Malaysia.
            • snme
              • Feb 2016
              • 26
              • AU
              Originally posted by redwire
              My quote:
              Yeah, I made a similar complaint some tens of years ago to a publication that has now ceased operation.
              The advice was that for tiny caps it doesn't much matter.
              We were dealing with liquid cans in those days, yet still they appear.
              • nomoresonys
                • 12328
                • U.S.
                Didn't look real hard at the video, my guess was maybe the guy in the video was dealing with a knockoff.
                • tmhobadcap
                  Pioneer VSX-522-K remote control not working???
                  by tmhobadcap
                  I have this receiver for at least 10 years. Usually, we just use the remote for turning on/off and adjusting the volume. Recently, the remote control started not able to turn the receiver on. Later, the volume also could not be adjusted by the remote control.
                  At first, I thought that it was the usual problem which can be fixed by cleaning the contacts on the switches and the pcb. I opened the remote and clean it with alcohol. The remote did work again after that. But after one day, it did not work again. I opened it again and clean with alcohol and contact cleaner. Again it worked...
                  12-24-2020, 01:44 AM
                • piipo
                  Old Privileg 5.1 speakers remote control question
                  by piipo
                  Hi, I have an old Privileg brand 5.1 speakers. I have lost the remote control. I have an universal Harmony remote but there is no Privileg brand in it's software to add. Does anybody have an idea what alternative brand for a remote can I try instead? I'm attaching an image of what the speakers looks like. The image shows 2 main speakers, they are 5 + 1 in total. Thank you very much
                  09-18-2024, 01:55 AM
                • hemant_2222
                  Schematic for Denon Remote Control RC1156
                  by hemant_2222
                  Hello Everyone,
                  Hope everyone is enjoying their repairs at hand!.
                  I am looking forward to get the schematic of Denon remote control RC1156. Actually long time no use of the remote leaked the battery thereby corroding few parts as well as the tracks.
                  I was able to join few of them but the remote is still not working, so i am looking forward for your help, in case anyone understand the schematic or the remote circuit diagram and could me assist me in repairing it.
                  Please refer to the attached picture, i think the voltage divider is missing...
                  10-06-2023, 02:05 AM
                • crackedprint
                  Sony HCD-HX80R Amplifier Volume Control Problem
                  by crackedprint
                  I have a strange fault on a Sony amplifier. The volume control varies the display from MIN, then 1 up to 30 and then MAX as expected. At MIN there is no sound. However, at 1 it is quite loud and increasing above 1 does not change the sound level.
                  I have tried a Cold Reset as per the service manual.
                  I have looked at the I2C clock and data to volume control chip IC501 (BD3499FV). Data is only sent to IC501 when the volume is set to MIN or 1. At any other setting no data is sent to IC501.
                  I have looked all the way through the service manual and tried many online...
                  01-21-2025, 12:18 PM
                • dfear
                  hitachi 75hl16t64u - not responding to remote control
                  by dfear
                  I have a hitachi 75hl16t64u tv in for repair and it is driving me crazy.
                  It came in for a power issue which I have finally resolved by replacing the power supply.
                  The current issue is that the TV does not respond to the remote control. I have replaced the IR sensor board with a used one but the fault persists.
                  Anyone have a clue how to fix TV?
                  FYI: I have checked the remote work s by pointing it at my camera on my phone....
                  09-02-2024, 12:15 PM
