Vizio VP42 Plasma (No Picture)
  • Venomhatch
    Disney Employee
    • 44
    Ok so I was given this Vizio VP42 HD Plasma and I was convinced I could fix this cost effectively. Has no video.
    Plugged it in and press power (nothing unplugged yet) and I hear the relays on the PCB click and I see LEDs on the lower main board top three light green and stay on. The last one D15 doesn't light at all.
    All fuses are good. I checked them for breaks with continuity and again for voltage at both ends, they are fine.
    I am at a stop at the moment looking to you fine folks for help.
  • capkid
    • Oct 2010
    • 1339
    Re: Vizio VP42 Plasma (No Picture)
    Does it have sound? If the internals are LG, you may have a bad IPM on the Y-Sustain. Check the white ceramic fuses for continuity.
    LG Plasma Mal-Discharge Correction Service
    • Venomhatch
      Disney Employee
      • 44
      I forgot to add:
      All LG internals, I dont know if I have sound because I dont know what input it is on. I keep pressing input with a bluray hooked up and nothing so far.
      • Venomhatch
        Disney Employee
        • 44
        They are LG, How do I figure out if it is the IPM. Is there a way to check? Also I cant figure out if I do still have sound because I dont know what input its on and I do keep cycling but never seem to find the HDMI with the bluray player on it.
        • capkid
          • Oct 2010
          • 1339
          To change inputs, I believe you have to hit the down or up arrow after pressing the Input button. Also, check your PSU output voltages; VS and VA are the most important for no picture issues.
          • Venomhatch
            Disney Employee
            • 44
            Ill post voltage here in a minute and go check the input here in a few minutes.
            • KYBOSH
              Hitachi 55HDS69 55" Plasma TV - No Picture But Sound
              by KYBOSH
              Picked up a bahemoth plasma TV not too long ago and just now getting around to looking at it.
              No picture but you hear the TV static (white noise) playing loud and clear.
              The back was already taken off (and no screws were provided) as the previous owner had already taken a look.
              But it seems they didn't get too far and just left it.
              When I first took a look I was amazed at how pristine the inside looked.
              Its as if the TV had been in a time capsule.
              Caps looked like they were just pulled off the self.
              Copper coils had no sign of corrosion on...
              02-01-2023, 11:10 PM
            • gavric
              Vizio M70-C3 Half picture is bad, main board on its last leg?
              by gavric
              Hello, i am working on Vizio M70-C3. It can hardly power on, it takes 15 power button presses or remote. Seems like eeprom problem that I seen before but all reading online says that this tv has power board or main board problem.
              When tv powers on vizio V logo shows nice on whole screen. picture 1
              When it goes into tv mode it only shows good picture on left side of screen, right is all scrabbled up. pic 2
              When i start youtube picture shows on left side fine, right is all scrambled. pic 2
              When i click video to start playing picture goes black(like when you change...
              09-02-2021, 08:55 PM
            • KYBOSH
              Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
              by KYBOSH
              Saved this beast from the landfill this weekend.
              Manfactured July 2013 in Mexico.
              I love working on plasma TVs.
              Its been a while but I was lucky enough to find 2 this week.
              The TV powers on and stays on but no picture. Havent checked for sound yet.
              No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
              Will start troubleshooting tonight.
              10-17-2024, 01:17 PM
            • ggil44
              Vizio M65-E0 No Picture, No Sound
              by ggil44
              Hi I inherited a Vizio M65-E0 that isn't working. It must have been dropped on the corner because I found that the infrared circuit had a capacitor with one end broken off of the board and some green corrosion around the plug to the main board. I re-soldered the capacitor and cleaned the corrosion well and tried turning the M65-E0 on and I was successful. My problem is that while the back lights come on and appear to perform local dimming there is no picture or sound. It kind of looks like you are looking at the TV through a very dense fog, where changing the input on the remote will change bright...
              09-03-2024, 08:30 PM
            • maricm
              Vizio m65-c1 picture flashing on and off on the screen
              by maricm
              HI all,
              hope someone point to the possible issue before I start buying replacement parts.
              Tv starts normal and responds to remote fine, PSU voltages mesured fine 19v was 18.9V under load and 19V with main board disconnected.
              Backlight stays on all the time,
              Sound works fine.
              screen keeps changing form black to full picture in about 1sec intervals.
              Picture looks fine with no visible artifacts.
              I have disconnected backlights and flashlight test confirmed that picture is still doing the same.
              Disconnecting left and right ribbons on...
              11-25-2023, 06:32 PM
