VIZIO VA26LHDTV10T has white vizio logo before pressing power on. no backlight.
  • triplefour
    • May 2014
    • 1747
    Re: VIZIO VA26LHDTV10T has white vizio logo before pressing power on. no backlight.
    its a capxcon GF series
    47uf
    50v
    hmm ok i took it out and put it on the meter but it seems like this capacitor is fine. 48uf and .33 ESR
    guess id better still look up the datasheet to be sure
    Don't fear the repair...
    • selldoor
      Slow Learner
      • Dec 2010
      • 7870
      #42
      For power supply capacitors irrespective of the "fine Print" on the existing capacitor which
      may well be over optimistic anyway, you can just use Panasonic FR FM or FC whichever you can get in the size that will fit - FR is the best.
      Re post29 That sheet is for an optocoupler so not an SMPS IC
      • triplefour
        • May 2014
        • 1747
        yeah according to
        the cap has a max impedance (ESR as i am now told) of .20
        so um.. .33 is actually no good? if its anything above 20, its bad? or is there some tolerance?
        • triplefour
          • May 2014
          • 1747
          selldoor, thanks i had a feeling that might not be the right sheet... can you help me find the correct one? i just kept coming up with that one
          • selldoor
            Slow Learner
            • Dec 2010
            • 7870
            #45
            SMPS may be IC902 part no?
            • triplefour
              • May 2014
              • 1747
              and well it looks like im going to have to buy at least 2 caps here.... should i just replace em all? that would be like 13 caps all together
              • triplefour
                • May 2014
                • 1747
                not sure what you mean but it says ET1103 on it and i could only find sheets for TCET1103
                • aaronwt6
                  • Apr 2013
                  • 855
                  • US
                  #48
                  No, what I'm saying is if you are sure the power supply is working and that the problem does indeed lie in the motherboard.
                  • triplefour
                    • May 2014
                    • 1747
                    took off another capacitor C931
                    elite EA(M)
                    100uf 50v
                    measures 93uf ESR .27
                    does the 7uf difference mean its bad already?
                    datasheet says should have a max impedence of .22
                    is .05 higher ESR a cause for failure?
                    • aaronwt6
                      • Apr 2013
                      • 855
                      • US
                      #50
                      And I just robbed some out of a bad board I had lying around. But you may not have that option.
                      • triplefour
                        • May 2014
                        • 1747
                        wait aaron im still confused then. were you originally talking about replacing a capacitor on the mainboard, or the power supply?
                        • triplefour
                          • May 2014
                          • 1747
                          i think we already diagnosed that at the very least i have a power supply problem in the 12v/24v section ..lets hope i dont have a mainboard problem as well
                          • selldoor
                            Slow Learner
                            • Dec 2010
                            • 7870
                            #53
                            I am saying you are looking at the wrong IC - I only skimmed the thread and missed it but you mention IC902 on the first page!!
                            Here is the datasheet http://pdf1.alldatasheet.com/datashe...TR-A6069H.html
                            It is also useful to look at Google images for the part.
                            I am a bit worried about the voltages you posted initially and where you took them maybe it has already been mentioned but you need to be aware that voltage up the the bridge rectifier is AC and after that is it DC. I think you may not have been changing the meter or perhaps it is autoranging but clearly "62" on the mains fuse has to be wrong.
                              it says ET1103 or FT1103 (this is the 4 legged IC in the 12/24v)
                              Post 27:
                              "Just want to be sure nothing changed. Post 11, please get the P/N as printed on top of that SMPS IC for the 12V/24V so we can get the spec sheet and do the resistance and voltage test. Also check C941."
                              Again, you are not helping. As I indicated for you to see pictures on POST 11, I circled the 12V/24V SMPS IC which has 8 legs.
                              I am sorry I cannot help you if you are not going to follow the instructions.
                              • triplefour
                                • May 2014
                                • 1747
                                ughhh you meant the one on the underside of the board??? so sorry i thought u wanted the 4 legged one in the 12v/24 section on the front side!
                                i am just not familiar enough with the terms yet i guess. SMPS IC is supposed to mean something to me. and well..now it does.
                                the numbering is so tiny i dont think i can even read it. plus its kind of dirty. would it be safe to use a little rubbing alcohol to clean it? that wont take off the numbers will it?
                                • triplefour
                                  • May 2014
                                  • 1747
                                  dangit why didnt i look at that second picture more closely???
                                  • selldoor
                                    Slow Learner
                                    • Dec 2010
                                    • 7870
                                    #57
                                    Yes it might clean with IPA gentle though perhaps with a Qtip
                                    Suggest you dont post "Thoughts" the thread is going to be long enough without.
                                    You could have used "edit
                                    Sometimes a close up picture enlarged is easier than reading even with a magnifier
                                    Try from different sides
                                    • triplefour
                                      • May 2014
                                      • 1747
                                      LD7258 is kinda what it looks like... but it could be 107258 or something like that...
                                      • triplefour
                                        • May 2014
                                        • 1747
                                        well it was more than a thought...it was part of an apology for not paying attention more closely to what budm was saying way back in post 11 but yes, you make a good point. keep it simple when possible. but sometimes, threads are gonna go long when you make mistakes and start naming numbers off the wrong chips! DOH
                                        • triplefour
                                          • May 2014
                                          • 1747
                                          LD7523AG i think now, after the alcohol bath
                                          • Daveleone
                                            Vizio VO42L, white logo, no backlight, no picture
                                            by Daveleone
                                            Hi all! I've got a Vizio VO42L. Plug it in, and logo flashes orange/white for a bit, then solid orange. Press power, and logo changes to white. There is no backlight.
                                            From reading some of the posts here I thought the inverter could have been the problem, but I've replaced it and still have the same issue. I noted that shining a flashlight on the screen shows nothing, so now I'm thinking main board?
                                            I took the following readings with the TV powered on. I also tried taking the readings with the CFL connectors unplugged - no change.
                                            Main board:
                                            Continuity across...
                                            02-20-2021, 04:52 PM
                                          • Super360
                                            Vizio E701i-A3 Vizio logo flashing then turns off
                                            by Super360
                                            Ok so here's the story. I was watching tv one day when all of a sudden I heard a pop from the back of the tv set and rushed to unplug the set. By this time the tv already had smoke coming out the back. It was not storming or inclement weather that day to cause a power surge to the best of my abilities. When I opened the tv up, I found that the three capacitors on the psu (highlighted in red) were all bulging and looked they had exploded. I replaced all of them right away and when I went to start up the tv after the "fix" it started just showing the flashing vizio logo as soon as power...
                                            07-25-2024, 07:06 PM
                                          • JaquesPratt
                                            Vizio D32f-E1 Powers on, has backlight, won't boot/no logo, no menu or video
                                            by JaquesPratt
                                            I have a Vizio D32f-E1 LCD TV that does NOT have a TCON board.
                                            This TV recently went through some 'death throes' and now won't boot. The first problem that began to manifest was while watching tv, the screen would 'freeze', and the image would dim over a few seconds until it was very dark. HOWEVER, the audio of the show would continue as normal. I could power off the TV for 5-20 seconds, power back on, and the video would be normal. This would occur 1-3 times when the TV was first started, and would not happen again after the TV was 'warmed up'. Not ideal, but this glitch was manageable....
                                            07-16-2024, 01:04 AM
                                            MSI Prestige P65 8RF-456NL Creator White Notebook P Specification for Upgrade or Repair
                                            This specification for the MSI Prestige P65 8RF-456NL Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-456NL Creator White boardview and P65 8RF-456NL Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties...
                                            09-06-2024, 07:46 AM
                                            MSI Prestige P65 8RF-442 Creator White Notebook P Specification for Upgrade or Repair
                                            This specification for the MSI Prestige P65 8RF-442 Creator White Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the P65 8RF-442 Creator White boardview and P65 8RF-442 Creator White schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any...
                                            09-06-2024, 07:29 AM
