Technika LCD37-909
  • viduka
    • Mar 2014
    • 64
    • Scotland
    Technika LCD37-909
    Any advise. Got a Technika LCD37-909 which does not display a picture for about the first 5-10 minutes its switched on. After that it works great but occasionally 2/3rds of the picture goes then comes back.
    Looks like something needs time to heat up. Any ideas ?
  • sordids999
    • May 2013
    • 2152
    Re: Technika LCD37-909
    it would be a good idea to take the back off and post some pictures of the boards
    • viduka
      • Mar 2014
      • 64
      • Scotland
      Not sure which Board to Photo so did them all. Any help would be great.
        Backlight on or not?
        • viduka
          • Mar 2014
          • 64
          • Scotland
          Backlight is working fine the whole time
          • viduka
            • Mar 2014
            • 64
            • Scotland
            Anyone any ideas ?
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              Hair dryer and a can of air upside down can be your friend here.
              From cold you can turn tv on and blast hot air on a board to see if you can speed up your warm up time.
              Once you found which board reacts to the heat you can then concentrate on that board.
              Take the can of air,hold it upside down and spray the freon on parts of that board to see if you get a reaction,great way to "zoom" in at the problem area.
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • Goldieoldie
                • Jul 2014
                • 15
                • England
                Hi tom
                Do you know please the service code for UHc tvs please ?
                It's a 19 inch LCD DVD combi badged technika model number m19n11n02g 801 or lcd19dvdid307 but I think it's got UHc boards and not vestel as none of their codes seem to work.however the umc code 9735 to hack the DVD works
                I want to start the first set up installation as there is no option in the normal menu to do this.Problem is it does not allow tuning in digital mode ( aerial symbol is greyed out ) ,analogue is ok
                Be really grateful if you know !
                Cheers Pete
                • vinceroger69
                  • Mar 2012
                  • 6714
                  Originally posted by Goldieoldie
                  Hi tom
                  Cheers Pete
                  http://forums.digitalspy.co.uk/showthread.php?t=1983294
                  • Goldieoldie
                    • Jul 2014
                    • 15
                    • England
                    Hi
                    Thanks for the link
                    I've tried those codes mentioned but none work!
                    I think because the code 9735 ( a unc code I think ) works as a hack to change regions for the DVD I gather it's a unc code I need rather than vestel
                    Anybody out there know what the unc service codes are please ?
                    Cheers Pete
                    • vinceroger69
                      • Mar 2012
                      • 6714
                      have you tried to email unc there emails in the link they might help you have you got the original remote control?
                      • Goldieoldie
                        • Jul 2014
                        • 15
                        • England
                        Sorted !
                        Thanks to everyone for there help
                        Cure is to use a one for all remote
                        I used the Urc 6440 which is a good one to have as it is upgrade able
                        Use one for all code 2426
                        On this particular remote the key marked text becomes the digital tv menu !
                        There you can do a first time install to find any new digital channels
                        Cheers Pete
                        • vinceroger69
                          • Mar 2012
                          • 6714
                          cool glad you manged to sort it thanks for posting the fix but i guess if you have a original remote control which has the digital tv button you wouldnt have this issue?.
                          • Goldieoldie
                            • Jul 2014
                            • 15
                            • England
                            Yes you are right!
                            There again I've not come across before a tv which has a separate menu button for the digital Tuning !!
                            • Tr0ll
                              by Tr0ll
                              Original T-con:
                              First replacement T-con:
                              10-07-2023, 07:48 PM
                            • JJAAMM
                              by JJAAMM
                              Problem
                              07-06-2023, 06:01 AM
                            • TR103
                              by TR103
                              - it keeps rebooting
                              01-22-2025, 04:12 PM
                            • Mgiffune
                              by Mgiffune
                              06-09-2024, 10:28 AM
                            • CyberPhoenix
                              Issue with picture quality of Sony bravia TV
                              by CyberPhoenix
                              Hello, Last week I bought the 50" Sony X80j tv everything was working fine, untill I plugged the tv in a ups power supply 650va the tv remote control became unresponsive and the TV became laggy after a while the picture quality isn't the same as before the tv seems less brighter and the picture is somehow blurry, people's faces don't look as natural as before, there is a mini orange-pink tint to the edge of people's faces especially in NETFLIX Dolby Vision like in One Piece ep1 Alvida skin tone, my intention was to protect the tv but something went wrong I checked the ups with a multimeter,...
                              01-22-2024, 02:08 AM
