Sony 40EX400 HDMI Input Problem
  • Regent
    Computer Tech
    • Dec 2011
    • 32
    Only my TV & HDMI 1 (DVD/BD) Input connector work.But when I plug my HD TV box into HDMI 1 (DVD/BD) it ony show up as 720 not 1080?
    If I access the menu only these two choose are highlighted. (as seen in the pic)
    Would anyone know if this is a hardware or a software problem?
  • selldoor
    Slow Learner
    • 7870
    Re: Sony 40EX400 HDMI Input Problem
    I have no idea but if you treat hdmi as plug and play you are likely to lose
    your last working input. Due to the number of problems seen on here I have been warning people to switch the tv off and preferably unplug it before
    plugging in an hdmi lead.
    • R_J
      • 9627
      Are you sure the hd tv box is outputing a 1080 signal and not a 720 signal, It can be changed in some tv boxes
      Also do you have the latest firmware from Sony for this model
      • Regent
        Computer Tech
        • Dec 2011
        • 32
        On my other TV it show up as 1080p so I have to assume it a 1080 signal. Also, I did update to the latest firmware. I also unplug the TV & plug in the HDMI into 2,3 & 4 and none of them work. I plug in the VGA cable from my computer and it don't work either!
        Am wondering if the main board is defective or if its a software problem?
        • Regent
          Computer Tech
          • Dec 2011
          • 32
          Would anyone have any idea if my Main board is defective or if I have software problem?
          • Regent
            Computer Tech
            • Dec 2011
            • 32
            No one has any suggestion on how to fix my input menu problem?
            • martino
              Not so "senior"
              • Aug 2013
              • 997
              • canada
              fairly common for inputs to "die",like mentioned here before,plug and play of inputs can kill a port.
              Only way to fix would be to replace the mainboard. To replace a HDMI chip is a high skilled soldering job IF you are able to get a replacement chip even.
              Proud owner of dozens of broken TV's and many,many,many boards.
              Our website and passion:http://hollenhundshepherds.com/
              • Regent
                Computer Tech
                • Dec 2011
                • 32
                Thanks for your suggestion Martino. I will see how much a new main board cost.
                • ecking767
                  • Oct 2009
                  • 492
                  reset the TV to factory setting, maybe there will be a discover /detection process.
                  • Regent
                    Computer Tech
                    • Dec 2011
                    • 32
                    Thanks for your reply ecking676. The manual says " Turn on the TV. While holding down V on the remote control, press POWER on the TV. (The TV will turn itself off, then back on again.) Release V"
                    But I tried that & nothing happens?
                    When I press Display, 5, V I get the following menu but I don't see the factory setting option??
                    • selldoor
                      Slow Learner
                      • 7870
                      What is the make/model of your HDV Box
                      Could always try contacting them and sony to ask if any compatibility issues
                      What are the other options on the menu that has "display" on it
                      • Regent
                        Computer Tech
                        • Dec 2011
                        • 32
                        Thanks ecking767 I reset the TV to factory setting and everything is working fine now!!!
                        • martino
                          Not so "senior"
                          • Aug 2013
                          • 997
                          • canada
                          That is very interesting. Plz let us know if ports keep working.
                          • Regent
                            Computer Tech
                            • Dec 2011
                            • 32
                            Yes all my ports works!! Must of been a corrupt file somewhere? But its just like new now!
                            • Regent
                              Computer Tech
                              • Dec 2011
                              • 32
                              • selldoor
                                Slow Learner
                                • 7870
                                That is great news - just for the record can you state the reset procedure you used - did you find another menu?
                                • Regent
                                  Computer Tech
                                  • Dec 2011
                                  • 32
                                  " Turn on the TV. While holding down (arrow up) on the remote control, press POWER on the TV. (The TV will turn itself off, then back on again.) Release (arrow up)"
                                  And Voila!
                                  • ecking767
                                    • Oct 2009
                                    • 492
                                    its one of the first things I do once I get a repaired TV back up an running, its clear out the previous owner setting. That good news!! glad to help !!
                                    • eltunisie
                                      Hdmi problem in dell insprion 3521
                                      by eltunisie
                                      i have dell insprion 3521
                                      hdmi port it can good work but now not disply alot of screen and i used convert hdmi to vga but not work
                                      i tray
                                      windows 7, windows 10, orginal vga drivers from dell, update bios
                                      i found 5v on th e socket
                                      what a problem?...
                                      11-06-2025, 06:24 AM
                                    • s_henya
                                      EPSON EB-X18 No HDMI input
                                      by s_henya
                                      Not my usual equipment repair, Projector works great but no HDMI input.
                                      motherboard: H550MA_R1
                                      HDMI socket was a bit chipped on the side, but no critical damage, i replaced it anyways but still no signal.
                                      Im assuming other damage in the mainboard.
                                      Can anyone give me some pointers on where to begin?...
                                      06-13-2025, 09:06 AM
                                    • shopy
                                      Lg55 led tv hdmi input problem need help
                                      by shopy
                                      i have a strange problem with my LG 55 led tv HDMI INPUTS.
                                      when i connect the cable tv HDMI to the HDMI input of the lg led tv .the tv says NO SIGNAL .but if i connect to the same inputs a china tv box all is working fine. all the HDMI inputs are the same. non of them work with cable tv but work well with the china tv box.
                                      this happens only on this specific tv another tv i have work fins with the cable tv and with the china tv box.
                                      i cant figure way it happens in this tv only.
                                      thanks, to the helpers?
                                      12-05-2020, 11:47 AM
                                    • Tarot Superstars
                                      Add Stereo Input To Hi-Fi (Sony SONY PMC 107L)
                                      by Tarot Superstars
                                      Hi.
                                      I bought a Cheap HIFI to use as my PC output and speakers and forgot to check if it had an input. It doesn't.
                                      Is there any way to add a stereo input. I have a bunch of Phono sockets I am not using.
                                      Where in the circuit is the best place to solder the 3 stereo input wires?
                                      This is the model and schematics:
                                      https://www.manualslib.com/manual/91...7l.html#manual
                                      10-31-2023, 03:23 AM
                                    • Chrissygizmo
                                      Sony KD-55XG9505 lines on screen problem
                                      by Chrissygizmo
                                      Hello again everyone,
                                      This is my latest mission, to try getting this Sony tv back to normal working order…
                                      I've only just got it today, when you power it up everything is as should be, in fact it works perfectly for a few minutes then the screen starts getting horizontal lines on & eventually the full screen goes back, I will upload photos of the problem & also some photos of the board etc. You might notice that I'm busy trying the tape method, I'm not sure exactly where the clock lines are so I'm just guessing & hoping for the best lol . I've already tried...
                                      02-19-2025, 11:31 AM
