As19-h1g ic
  • kevinm34232
    • May 2012
    • 1884
    As19-h1g ic
    I have a T-Con with a bad AS19-H1G IC. Similar to the AS15, however the body of the chip is glued or soldered to the board. I am trying not to destroy the board, has anyone found a good way to remove this chip?
    Re: As19-h1g ic
    Hot air will probably be the best technique.
    • kevinm34232
      • May 2012
      • 1884
      Re: As19-h1g ic
      Im trying with no luck, the rest of the board is getting very hot and may be starting to melt the nearby tiny resistors
      • bammbammfran
        • Apr 2014
        • 476
        Re: As19-h1g ic
        cover the board with a couple layers of tin foil.
        I use high heat foil tape
        Use flux around all edges of the chip
        • kevinm34232
          • May 2012
          • 1884
          Re: As19-h1g ic
          I got it off but not easily and not pretty. Most traces remain but have pulled up from the board close to the chip.
          I think next time I will try cutting the IC pins with a razor blade when cold, then apply heat from the bottom of the board to loosen the main body.
          • mmartell
            • Oct 2013
            • 3189
            Re: As19-h1g ic
            Man you are not kidding. I'm trying to remove one from a V520H1-C06 tcon board and this will not budge. I've already sent a smt resistor sliding sideways and broken a few corners of the ic by putting gentle upward pressure there. I've added solder to the pins and that melts but the ground pad must be held on by military grade krypton.
            My Imitation Station came with a replacement heater for the wand so I'm going to install it and see if that makes a difference. Failing that the paint stripper is coming out so I can do some real damage, lol.
            • zomi
              • Nov 2011
              • 505
              Re: As19-h1g ic
              Try to dremel the chip off
              cut legs off then you can even grind the chip away
              and desolder the legs
              • mmartell
                • Oct 2013
                • 3189
                Re: As19-h1g ic
                I would have laughed at that idea until I saw a custom jig to do exactly that for chip removal on iPhone logic boards.
                I will keep that one in my back pocket for now. Seems easy enough to slip and cut through board traces when doing it by hand.
                • chrismurphy
                  • May 2014
                  • 251
                  • australia
                  Re: As19-h1g ic
                  This is the best way to remove the chip
                  Done this many times with this chip and also with buffer board chips works well with no damage
                  • popeye
                    • May 2011
                    • 155
                    Re: As19-h1g ic
                    Why not use chip quick?
                    • CapLeaker
                      Leaking Member
                      • Dec 2014
                      • 8066
                      Re: As19-h1g ic
                      With a hot air soldering station no problems taking ic's off. Other than that cut the legs off with an exact opposite knife or dremel, what ever suits you.
                      • zomi
                        • Nov 2011
                        • 505
                        Re: As19-h1g ic
                        Problem is when ic is glued sometimes with hot air you can have problems
                        best method in this cases is to grind.
                        look at the phone repairs
                        most of them now grind chips away
                        then replace using hot air
                        just depends what tools you have access too and good you are using them.
                        • mmartell
                          • Oct 2013
                          • 3189
                          Re: As19-h1g ic
                          I have no problem removing buffer ic's and smd mosfets and voltage regulators and such with my station. This setup appears to be a different animal.
                          • Tynan Dill
                            by Tynan Dill
                            Assuming...
                            11-22-2024, 01:46 PM
                          • m1ch43lzm
                            by m1ch43lzm
                            05-12-2025, 08:37 PM
                          • howardc64
                            by howardc64
                            Problem
                            08-04-2024, 10:36 PM
                          • Hakuu
                            by Hakuu
                            Hi There,
                            More Details
                            TV Model - LG OLED77G1PUA
                            07-12-2023, 02:37 PM
                          • jb_Bak
                            by jb_Bak
                            CN6401
                            Pin 01 NC
                            Pin 02 NC
                            Pin 03 "BL_ON": 0V
                            Pin 04 "N/C"
                            Pin 05 "STBY 3.3V": 3.5V
                            Pin 06 "GND": N/C
                            Pin 07 "AC_OFF"...
                            09-27-2021, 04:52 PM
