I have a T-Con with a bad AS19-H1G IC. Similar to the AS15, however the body of the chip is glued or soldered to the board. I am trying not to destroy the board, has anyone found a good way to remove this chip?
As19-h1g ic
Tags: None
Re: As19-h1g ic
Im trying with no luck, the rest of the board is getting very hot and may be starting to melt the nearby tiny resistorsComment
Re: As19-h1g ic
cover the board with a couple layers of tin foil.
I use high heat foil tape
Use flux around all edges of the chipComment
Re: As19-h1g ic
I got it off but not easily and not pretty. Most traces remain but have pulled up from the board close to the chip.
I think next time I will try cutting the IC pins with a razor blade when cold, then apply heat from the bottom of the board to loosen the main body.Comment
Re: As19-h1g ic
Man you are not kidding. I'm trying to remove one from a V520H1-C06 tcon board and this will not budge. I've already sent a smt resistor sliding sideways and broken a few corners of the ic by putting gentle upward pressure there. I've added solder to the pins and that melts but the ground pad must be held on by military grade krypton.
My Imitation Station came with a replacement heater for the wand so I'm going to install it and see if that makes a difference. Failing that the paint stripper is coming out so I can do some real damage, lol.Comment
Re: As19-h1g ic
I would have laughed at that idea until I saw a custom jig to do exactly that for chip removal on iPhone logic boards.
I will keep that one in my back pocket for now. Seems easy enough to slip and cut through board traces when doing it by hand.Comment
Re: As19-h1g ic
Problem is when ic is glued sometimes with hot air you can have problems
best method in this cases is to grind.
look at the phone repairs
most of them now grind chips away
then replace using hot air
just depends what tools you have access too and good you are using them.Comment
Assuming...7 Photos -
by m1ch43lzmHi, this is my personal laptop, which the original board (lets call it Board A) blew up PU8700 (TPS51486), making a hole on the board, i had left the laptop at my desk one day with the battery fully charged and didn't touch it for a week, but when i tried to turn it on it didn't
Thought the battery was dead, so i plugged in the charger then tried to power on, the power LED blinked once, charged LED still orange, unplugged the charger, plugged in again and I noticed the "magic smoke" smell, so i unplugged the charger, removed the back cover and saw the blown IC (the "magic... -
by howardc64All left and right refers to looking from rear of TV (or looking from front with TV upside down)
- TV came with vertical bars and no image. Found faulty TVS on left buffer board. Also replaced T-Con (may have damaged the original while hot air removing components, board has slight warp) and have full image but few horizontal lines on the screen. Some of the lines appears to be 2 pixel tall while others are 1 pixel tall.
- Disconnecting left and right buffer board potentially reveals problems on both sides with different signals (unless this T-Con require jumper like Samsung FB_TRDY1&3) Fault
by howardc64Problem
This is an LG edge LED lit LCD Display. The LEDs are on the bottom edge of the display. There are 2 bars (left and right) Each bar has many LEDs and a 6 pin connector. Each pin drive several LEDs thus is the highest current flow / heat junction. The weak lead free solder gradually fails with thermal expansion/contraction cycling and increases resistance. PSU will compensate up to a point, then when the current is too high, PSU just shut down the backlight causing a dark display. I have even seen one which the connector just fell off as solder points became completely detached....-
by HakuuHi There,
More Details
TV Model - LG OLED77G1PUA
Got the same exact TCON board from TVPartsToday and replaced it. But didnt transfer the EPPROM data (didnt... - Loading...
