don't judge soon, often chip pins offers bad connection to probes, unpower the board, scrape pins a little with screwdriver, then test it again...
					LG 55LF 5800 no video,no sound or backlight
 Heating the bga with hairdryer doesn't always get test results so it's not greatly reliable. A diy reflow done PROPERLY shouldn't hurt at all, It's a different process and is not done with a hairdryer: A diy reflow, involves getting the solder under the chip melted so it can reattach to the chip. Pretty straight forward, there's some good how to videos on youtube. Must be careful not to overheat or it will kill the chip, not enough heat and nothing bad will happen, it just won't work is all. They recommend gradual heating then gradually take heat away so as not to thermal shock the chip. Using a temperature gauge would be advised. Need to be extra careful not to blow away or lose any of those little components nearby such as those pesky little mlc caps. Here's a rough idea of the procedure using minimal tools. If one must use a heatgun be very careful with the temps, a lot of them were not meant for the lower temps needed for this kind of work, hot air stations are a much better tool for the job.Comment
 Basically a diy reflow done correctly does no harm, so I do it after doing all the usual
 mainboard tests for shorts and voltage etc. and if find no other obvious problems with the board.Comment
 A reflow on this chip will not work. These boards need the processor replaced.
 I believe Nicks TV has done a yt video on these models and the processor problems.Comment
 I used a hot air station but no luckHeating the bga with hairdryer doesn't always get test results so it's not greatly reliable. A diy reflow done PROPERLY shouldn't hurt at all, It's a different process and is not done with a hairdryer: A diy reflow, involves getting the solder under the chip melted so it can reattach to the chip. Pretty straight forward, there's some good how to videos on youtube. Must be careful not to overheat or it will kill the chip, not enough heat and nothing bad will happen, it just won't work is all. They recommend gradual heating then gradually take heat away so as not to thermal shock the chip. Using a temperature gauge would be advised. Need to be extra careful not to blow away or lose any of those little components nearby such as those pesky little mlc caps. Here's a rough idea of the procedure using minimal tools. If one must use a heatgun be very careful with the temps, a lot of them were not meant for the lower temps needed for this kind of work, hot air stations are a much better tool for the job.Comment
 Could someone tell me what main board will fit this tv.The one that is in it reads EAX65610207 EBT63774501 .The LG site says it should be EBT63838802 .Another site said EAX65610206 Some of these boards are dirt cheap but i don't want to buy one then it doesn't work.Why do i have to keep putting the image verification every time i ask a question on here?Comment
 EAXxxxxxx is the PCB number, different models are assembled on it, look for a paper tag with the number EBTxxxxxx, this will be for your model.​Comment
 Ok well then i guess LG changed the number from the old board or someone changed this board.This board is a EBT63838801 and the LG site says the correct board is a EBT63838802.Is it possible that more than 1 board will work?Comment
 Most likely a new modification (improvement, modification, with new software...), since the old ones are no longer produced, the difference is one, this is also yours...
 https://www.shopjimmy.com/lg-ebt6383...fdGG9wttWjRHAUComment
			so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!! what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol! what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
 i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
			by LEECH666Good day ladies and gentleman!
 I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
 This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
 I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
			Hello to the forum.
 My name is Christos, I am new to the forum here and i am posting from Greece.
 So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
 To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
 So i tried asking for a schematic from the company and they would not give me one. Instead they...-
			This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...09-12-2024, 02:30 PM
- Loading...
