LG 55LF 5800 no video,no sound or backlight
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4451
    • Italy - Milan
    #61
    don't judge soon, often chip pins offers bad connection to probes, unpower the board, scrape pins a little with screwdriver, then test it again...
    • waybel
      • Nov 2014
      • 65
      • canada
      #62
      ok
        • 12268
        • U.S.
        #63
        Heating the bga with hairdryer doesn't always get test results so it's not greatly reliable. A diy reflow done PROPERLY shouldn't hurt at all, It's a different process and is not done with a hairdryer: A diy reflow, involves getting the solder under the chip melted so it can reattach to the chip. Pretty straight forward, there's some good how to videos on youtube. Must be careful not to overheat or it will kill the chip, not enough heat and nothing bad will happen, it just won't work is all. They recommend gradual heating then gradually take heat away so as not to thermal shock the chip. Using a temperature gauge would be advised. Need to be extra careful not to blow away or lose any of those little components nearby such as those pesky little mlc caps. Here's a rough idea of the procedure using minimal tools. If one must use a heatgun be very careful with the temps, a lot of them were not meant for the lower temps needed for this kind of work, hot air stations are a much better tool for the job.
          • 12268
          • U.S.
          #64
          Example here on a graphics chip, same principal: https://www.youtube.com/watch?v=FU84qGSdE-s
            • 12268
            • U.S.
            #65
            Basically a diy reflow done correctly does no harm, so I do it after doing all the usual
            mainboard tests for shorts and voltage etc. and if find no other obvious problems with the board.
            • Storyteller12
              • Jun 2020
              • 625
              A reflow on this chip will not work. These boards need the processor replaced.
              I believe Nicks TV has done a yt video on these models and the processor problems.
              • waybel
                • Nov 2014
                • 65
                • canada
                #67
                I used a hot air station but no luck
                • waybel
                  • Nov 2014
                  • 65
                  • canada
                  #68
                  Could someone tell me what main board will fit this tv.The one that is in it reads EAX65610207 EBT63774501 .The LG site says it should be EBT63838802 .Another site said EAX65610206 Some of these boards are dirt cheap but i don't want to buy one then it doesn't work.Why do i have to keep putting the image verification every time i ask a question on here?
                  • lotas
                    • Jan 2016
                    • 4743
                    • Russia
                    #69
                    EAXxxxxxx is the PCB number, different models are assembled on it, look for a paper tag with the number EBTxxxxxx, this will be for your model.​
                    • waybel
                      • Nov 2014
                      • 65
                      • canada
                      #70
                      Ok well then i guess LG changed the number from the old board or someone changed this board.This board is a EBT63838801 and the LG site says the correct board is a EBT63838802.Is it possible that more than 1 board will work?
                      • lotas
                        • Jan 2016
                        • 4743
                        • Russia
                        #71
                        Most likely a new modification (improvement, modification, with new software...), since the old ones are no longer produced, the difference is one, this is also yours...
                        https://www.shopjimmy.com/lg-ebt6383...fdGG9wttWjRHAU
                          • 12268
                          • U.S.
                          #72
                          Well that's a new one on me but if Nick said so then I don't doubt it at all.
                          • waybel
                            • Nov 2014
                            • 65
                            • canada
                            #73
                            Originally posted by Diah
                            yes, but if you follow the pin 4 rail you will finnd easy point to separated the pin. post clear photo on the area of the PIN 4 rail.. we dont want you harm the MICOM chip
                            Are we still going to try this?
                            • Diah
                              • Feb 2013
                              • 6435
                              ob to you... but you need to read all posts from my '#54 to #57.. MICOM DIY an easy matter as its intended circuit in -- out regards it firmware.. disconnection rail from Chip we can fed it alternative.
                              • waybel
                                • Nov 2014
                                • 65
                                • canada
                                #75
                                ok
                                Where would be a good spot to disconnect pin 4 on the pictures i sent and then where do i get 3.5 volt feed?
                                • Diah
                                  • Feb 2013
                                  • 6435
                                  PIN 4 follow the rail it will goes to the top of the boards and there will be R this R lift one side of it.. 3.3V you have on MB the first DC to DC circuit close to socket which it connect to PSU
                                    • 12268
                                    • U.S.
                                    #77
                                    This one may take a while, with a week in between tests.
                                    • waybel
                                      • Nov 2014
                                      • 65
                                      • canada
                                      #78
                                      You are correct.With the risk of doing more damage than good after installing new LED lights i bought a $40 board and installed it and the tv works fine.Thanks to all
                                        • 12268
                                        • U.S.
                                        #79
                                        Thanks for the update.
                                        • Davi.p
                                          Hobbist Tech
                                          • Sep 2009
                                          • 4451
                                          • Italy - Milan
                                          #80
                                          You mean main board?
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
