LG 55LF 5800 no video,no sound or backlight
  • waybel
    • Nov 2014
    • 65
    • canada
    Picked up this 55 inch LG 55LF5800 . It has standby light but that's it .Blinks 3 times .No picture,no sound.Could hear rattling inside.Changed all led strips as half of the reflectors were broken.Put back together still no go .Checked output from power supply to LED connector .Only getting 89 volts on each .Suppose to be 215 V and 145 V . power board number is EAX65423801 .Yes i know screws are not on power board .I just put back on for pics.
  • EazyBone
    • Jun 2023
    • 1360
    • United states
    3 red light means TV is turning on. Lgs do this, not an error code.
    Do you see a picture with flashlight? Turn screen on and look for picture. May take a minute or so before you see the no signal or the smart bar. Also check 12v on each side of TCON fuse.
    Sometimes the main board is bad and doesn't send signal to turn on BL so test that first. Also give voltage readout on the PSU for each pin going to main board.
    • Storyteller12
      • Jun 2020
      • 625
      If I’m not mistaken these LG TVs “LF” series had problems with main boards. In particular the cpu overheats and goes bad. I don’t recall anyone reflowing one to fix it either. Have to replace it unfortunately.
      • waybel
        • Nov 2014
        • 65
        • canada
        No picture with flashlight that i could see.12 volts on T-con fuse.All voltages are good going to main board
        • waybel
          • Nov 2014
          • 65
          • canada
          Saw someone mention possibly BLO202B led driver on power board .Hoping it's not main board.Probably worth more than tv
          • lotas
            • Jan 2016
            • 4803
            • Russia
            EAX65423801 schematic
            • waybel
              • Nov 2014
              • 65
              • canada
              Thanks to everyone and for the schematic .I am just learning and not great with schematics.I see the 89 volts i have going to both LED + .Obviously something is not turning them on to create the 215 and 145 volts needs to turn on the led strips.Any help appreciated on what to test/look for next
              • lotas
                • Jan 2016
                • 4803
                • Russia
                To start the backlight, the motherboard must supply these voltages to turn on the backlight driver, are they available?​
                • waybel
                  • Nov 2014
                  • 65
                  • canada
                  no they are not.Top row are 3.5 12 24 volt
                  • waybel
                    • Nov 2014
                    • 65
                    • canada
                    Has 3.5 12 and 24 volts but has no voltage on Pdim1, p-dim2 or drive on.
                    • lotas
                      • Jan 2016
                      • 4803
                      • Russia
                      Well, here’s the problem - motherboard, check the usb and hdmi ports for low or short resistance (signal lines), if they are ok, then heat the processor with a hairdryer (if possible, remove the radiator from it) and warm it up thoroughly without fanaticism for diagnostics.. .
                      • waybel
                        • Nov 2014
                        • 65
                        • canada
                        Yes i crossed the standby 3.5 volts to drive on and power on and got the backlights working
                        • waybel
                          • Nov 2014
                          • 65
                          • canada
                          I removed the heat sink .I have a hot air/soldering station .How long should i leave hot air on at 385 degrees on the processor?
                          • lotas
                            • Jan 2016
                            • 4803
                            • Russia
                            Have you checked the usb and hdmi ports before heating the processor? If there is a short or low resistance on even one line, then the processor is no longer working properly. You can heat for 30-60 seconds.
                            • waybel
                              • Nov 2014
                              • 65
                              • canada
                              I am not sure how or where to check the resistance
                              • lotas
                                • Jan 2016
                                • 4803
                                • Russia
                                Then take a high-quality close-up photo of where these ports are located.​
                                • waybel
                                  • Nov 2014
                                  • 65
                                  • canada
                                  • lotas
                                    • Jan 2016
                                    • 4803
                                    • Russia
                                    These are, from the processor side, relative to gnd.
                                    • waybel
                                      • Nov 2014
                                      • 65
                                      • canada
                                      the USB are all 1.8 the HDMI are 2.8
                                      • lotas
                                        • Jan 2016
                                        • 4803
                                        • Russia
                                        What are 1.8 and 2.8 Om, kOm, MOm?
                                        • ChaosLegionnaire
                                          by ChaosLegionnaire
                                          09-13-2022, 09:02 AM
                                        • LEECH666
                                          Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                          by LEECH666
                                          Good day ladies and gentleman!
                                          I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                          This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                          I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                          01-19-2024, 05:46 PM
                                        • Christos Tsiligiannis
                                          Marian Trace Alpha sound card repair help
                                          by Christos Tsiligiannis
                                          Hello to the forum.
                                          My name is Christos, I am new to the forum here and i am posting from Greece.
                                          So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                          To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                          So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                          11-18-2024, 05:26 AM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                          This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                          09-12-2024, 02:30 PM
                                          HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
