LG 55LF 5800 no video,no sound or backlight
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4501
    • Italy - Milan
    #41
    My bet is as usual some of the BGA that are bad to resolder, especially with LG is an old habit, does the s.b. led glow two times short and then stays lit long? Why did you changed the b.l. led? what's the story of this set? is it been left sitting for long in a moist ambient? bye..
    • waybel
      • Nov 2014
      • 65
      • canada
      #42
      Got it from a guy that bought it new .No the standby light powers on .Hit remote it blinks 3 times and goes out as it should.Changed the leds because some of the reflectors had fallen off so replaced strips while i had it apart .Looks like i need to find another main board
      • lotas
        • Jan 2016
        • 4787
        • Russia
        #43
        Have you tried warming up the processor or is your hair dryer not working?
        • waybel
          • Nov 2014
          • 65
          • canada
          #44
          I warmed it up 3 times with my hot air but no change
          • lotas
            • Jan 2016
            • 4787
            • Russia
            #45
            If you have nothing to lose, warm it up for more time, 3 minutes...
            • waybel
              • Nov 2014
              • 65
              • canada
              #46
              tried that also.If the processor wasn't working shouldn't it be cold?When the tv is turned on it is warm to the touch.Or could it be that some of it is not contacting but still works?
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4501
                • Italy - Milan
                #47
                No good for me at this point to insist, a bad made reflow cannot resolve the case, maybe worsen, better to decide if making a reballing (of what? CPU, ram , emmc/nand, what? witch price?) or buy a main board tha could work but not last long.. mad technology of fool greed manufacturers
                • lotas
                  • Jan 2016
                  • 4787
                  • Russia
                  #48
                  It should be hot when it is fully operational, which is why a radiator is installed...
                  • lotas
                    • Jan 2016
                    • 4787
                    • Russia
                    #49
                    Originally posted by waybel
                    Just looking quickly on various places on main board found 1.2 V 3.3V 3.5v 5v 12v and 24v
                    Are 1.8V and 2.5V power supply present or not?
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4501
                      • Italy - Milan
                      #50
                      easy to check: check every choke inductor resp. to gnd, except the 4 around the audio ic..
                      • Diah
                        • Feb 2013
                        • 6470
                        check the MICOM !C3000 pin 4 did exist >3.3V ?
                        • waybel
                          • Nov 2014
                          • 65
                          • canada
                          #52
                          pin 4 is 2.1 volts
                          • lotas
                            • Jan 2016
                            • 4787
                            • Russia
                            #53
                            It will be there, since there is 12V on the T-con.
                            • Diah
                              • Feb 2013
                              • 6470
                              its remain low.. no juice enough
                              try to disconecct this rail from IC and other side of the rail fed it with 3.3V
                              • Diah
                                • Feb 2013
                                • 6470
                                this is DRV_ON another rail switching T-CON 12V
                                • lotas
                                  • Jan 2016
                                  • 4787
                                  • Russia
                                  #56
                                  Why blow something, there is 12V on the T-con!
                                  • Diah
                                    • Feb 2013
                                    • 6470
                                    1- PANEL_CTL 3,4 Normal... he have 2..1 i wrote no more juice more
                                    2- i wrote disconnect Pin 4 from the rail... read again... the other side of the rail will be provided with 3.3V
                                    MICOM will never hurt at all
                                    • Diah
                                      • Feb 2013
                                      • 6470
                                      if the rail of 3.3V we are going to use will drop down again to 2.1V we will have ours hand on the reason
                                      • waybel
                                        • Nov 2014
                                        • 65
                                        • canada
                                        #59
                                        So you want me to unsolder pin 4 ?
                                        • Diah
                                          • Feb 2013
                                          • 6470
                                          yes, but if you follow the pin 4 rail you will finnd easy point to separated the pin. post clear photo on the area of the PIN 4 rail.. we dont want you harm the MICOM chip
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • LEECH666
                                            Grundig Vision 9 37 9880 T USB (Chassis SR) TV Repair Help - Distorted Subwoofer Sound and overall weird sound waveforms
                                            by LEECH666
                                            Good day ladies and gentleman!
                                            I am currently trying to repair a Grundig Vision 9 37 9880 T USB LCD TV for a friend that has a weird audio problem. Basically everything works fine except for the heavily distorted sound when the Subwoofer module is connected and there is a buzzing sound coming from the PSU PCB.
                                            This seems to be a rather rare TV so there is not much prior on topic help to be found however a service manual is available at the usual sources (Electro Tanya i.e.).
                                            I think the PSU buzzing comes from one of the coils near the bridge rectifier but...
                                            01-19-2024, 05:46 PM
                                          • Christos Tsiligiannis
                                            Marian Trace Alpha sound card repair help
                                            by Christos Tsiligiannis
                                            Hello to the forum.
                                            My name is Christos, I am new to the forum here and i am posting from Greece.
                                            So i have this old German sound card from Marian, called Trace Alpha. To be exact i have 2 of them and i use them professionally for my small FM radio station here. The first one works like a charm, but the second one does not work at all.
                                            To be more specific in the same exact pc with windows 7 (i even tried 32bit) the one works while the other doesn't.
                                            So i tried asking for a schematic from the company and they would not give me one. Instead they...
                                            11-18-2024, 05:26 AM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i7-9700 Specification for Upgrade or Repair
                                            This specification for the HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar boardview and ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                                            09-12-2024, 02:30 PM
                                            HP ProDesk 600 G5 + LG SJ2 Bluetooth Sound Bar ProDesk 600 i5-9500T Specification for Upgrade or Repair
