Hey how are you all replacing the as15 chip. Do you use hot air or soldering iron. I'm trying to use my hot air station but for some reason it's not melting the solder paste. It melts it slightly but not into liquid solder. I tried using my iron but kept getting one or two bridges on each side that I couldn't get rid of.
Replacing as15-f chip
Tags: None
Re: Replacing as15-f chip
I've not done one of these yet but have replaced the buffer ic on a Samsung buffer board must be sorta similar.
I would use your iron with lots of flux and drag solder after you tack the corners. Any bridges can be cleaned up with a little braid. Good luck. -
Ok thanks for the tip. I changed the temp to 600f just out of anger and it finally melted it into solder and went on the legs but had a lot of bridges so I'm using my iron now to try and remove them.Comment
Ok. Yea I need to up grade my soldering iron too. I think that also might be part of the problem. I'm just using a craftsman plug in. I'm gonna see if I can snag a hakko soldering station from work.Comment
I just pulled the chip off again. I might try to reflow it again since before I was at like 450f.Comment
There wasn't much solder left on the pads. I did that and it did stick but there wasn't much solder on ther to the point that it didn't even flow ontop of the edges of the feetComment
It was on there. But I was afraid to leave it that way incase the chip got warm and possibility of melting the solder and it either coming off or one of the legs loosing contact.Comment
Ok I think I will add solder to the pads and then put the chip on and reheat the solder on the pads.Comment
it is a P.I.T.A. i have tried this 3 times using both soldering irons and rework station hot air and still had to buy another board taking it off is easy but getting it back on where there are no false contacts after it warms up is incredibly hard. if u figure out the secret please update i would love to know cuz YouTube makes it look so easy and it most definitely isn'tComment
there are a few tricks.
i wouldnt call them secrets.
take the old chip off,
put flux on the board & re-melt the solder so it's all nice & flat.
clean burned flux off.
take "new" chip.
if it's not really new, put flux on the legs and put it down upsidedown.
use the air to flow and flatten any old solder on the legs.
clean the flux after with a soft brush and IPA
now you have a clean chip & pcb.
put the chip on the board and make sure it's straight.
then melt the solder on one of the end pins wih an iron just to hold it in position.
check you got it right and then repeat on the oposite corner.
now paint all around it with flux,
and heat 2 joined sides while gently pressing on the corner with a long thin metal thing with a thermally insulated handle - unless you like burns on your hand!
when the solder melts, the chip should drop onto the pads on that edge.
now get your magnifier and check it's still inline and didnt go off-center.
if it's good then repeat on the other 2 linked sides.
it should now be 100% down and alighned.
if your unhappy with the look of any of the soldering, re-flux it and reflow it in one go using a swirling motion with the air.
like our resident DJ recently said - it's all in the wrist!
now 2 other things.
1: if the chip is large it helps to warm he underside of the board first.
2: clean off the flux once your done - flux absorbs moisture and becomes conductive.
also if the flux uses a thermally activated corrosive agent - some do, then it's gonna stay corrosive after it cools.Comment
by DynaxSCHi
I have then desoldered the chip, backupped the contents, and tried to earease the chip in order to program stock image, but the chip is locked by status registers SREG2 (TB) and SREG6... -
by acedogblastThis is a guide that I am writing for helping others to replace their MEC1503 EC chip if it breaks (or to get around an inconvenient prompt to the BIOS). This forum has been extremely helpful to me so I would like to contribute to help others. I will tell you right now that this task is very difficult to do. You MUST have experience and tools to do precision micro-soldering, BGA reballing, trace repair, and general laptop repair skills.
There are some specialty tools needed to do this task. The replacement MEC1503 chips can be acquired from Aliexpress. Do not buy the bare chips as... -
by SMDFleaCommon SPI bios chip programming Questions and Answers
Bad...-
Channel: BIOS Requests ONLY!
09-02-2021, 04:40 PM -
Long story short:
- dad converted Asus Chromebox CN62 into Windows compatible, with mrchromebox BIOS, years and years ago
- gave the computer to his son a couple years later
- son now decided to revert it to Chrome OS, to sell it as original (re-writing BIOS with the backup one created by his dad)
- too lazy to remove the board from the case, thought a voltage regulator was the BIOS chip (you know... it has 8 legs)
(seems like the story was not that short)
He used alligator clips to read the chip. No luck reading it. Removed chip and placed on a SOC-8... -
by barbasHi. In the process of troubleshooting an MSI GE78HX laptop that does turn on (on its own), turns on the backlight on and off in infinite cycle, turns on RGB keyboard backlight and light bar. The CPU gets hot, and its fan spins.
The laptop charges the battery, turns on charging lights, which leads me to think the EC (ITE5571E) is ok. Laptop has no shorts, apparently. Memory is ok, tried it in another machine. Tried 5 different sticks in this machine as well, does the same. Memory connector seems ok, no pins bent.
First, I am going to try to backup and reflash its BIOS,... - Loading...
