Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 1009
    • sweden
    #141
    Hi since this replacement mainboard is not compatible with this TV I think I'll try to transfer the parts to the original mainboard
    • bohaboha
      • Nov 2012
      • 1009
      • sweden
      #142
      Hi wondering if someone can tell me what Volt value is missing on the Mainboard for this to work, see the picture
      thanks​
      • bohaboha
        • Nov 2012
        • 1009
        • sweden
        #143
        Hi no one knows about it?
        • Diah
          • Feb 2013
          • 6396
          Volts had nothings to do if one SoC defect or BGA.issue
          • bohaboha
            • Nov 2012
            • 1009
            • sweden
            #145
            thank you Diah i found a Mainboard for 70 inches with LVDS and STBY connection for a very fear price hope it will be ok
            • Diah
              • Feb 2013
              • 6396
              i know how much you would like to help yours friends , but this will not help if the panel defect
              • bohaboha
                • Nov 2012
                • 1009
                • sweden
                #147
                it's my neighbor it's for the kids' sake .hope it's not the screen otherwise last try
                • bohaboha
                  • Nov 2012
                  • 1009
                  • sweden
                  #148
                  Hello again now I have received the probably compatible Mainboard BN41-02751B from a TV:UE70TU7100KXXU As I hope it will be compatible for my set but yes all the time there is one but the Mainboard comes from Albania and it might be a Regions issue some reprogramming is there any of you guys who know I am very grateful for all answers and suggestions
                  • bohaboha
                    • Nov 2012
                    • 1009
                    • sweden
                    #149
                    Hi the Mainboard is from a different Region what is possible to do to make it compatible to my Region ? do there is some process to follow or there is no way to fix it? please if you can tell me
                    • Diah
                      • Feb 2013
                      • 6396
                      go back any try my posts #53 and 56
                      • bohaboha
                        • Nov 2012
                        • 1009
                        • sweden
                        #151
                        ok i ll do thank you
                        • bohaboha
                          • Nov 2012
                          • 1009
                          • sweden
                          #152
                          Hi i did the test as in post 53 and 56 and i se the TV is trying to show a picture but no nothing in the end i did also shorting trdy1&3 test points but the tv does not show which part is defect . it seems like i am about to find it but no. today i got the new DC to DC VPMS chips and i am thinking to try it but first i desoldered the old one and put in place the tin bolls without stencil but i did not solder them yet before i get some advice about it i ll try with the old one first
                          • bohaboha
                            • Nov 2012
                            • 1009
                            • sweden
                            #153
                            any advices or suggestions
                            • bohaboha
                              • Nov 2012
                              • 1009
                              • sweden
                              #154
                              no one to give an direction? very sorry but i really need your help
                              • Mgiffune
                                by Mgiffune
                                06-09-2024, 10:28 AM
                              • mrtek
                                Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                by mrtek
                                Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                11-26-2024, 09:58 AM
                              • mecha1166
                                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                by mecha1166
                                KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                11-25-2024, 05:22 PM
                              • stinger
                                Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                by stinger
                                When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                04-17-2024, 03:06 PM
                              • mar1in
                                Samsung TU8000, backlight and sound on, stuck in blue screen
                                by mar1in
                                I've got this Samsung here that would be stuck in a boot loop.
                                After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                Thanks in advance
                                11-08-2023, 05:43 PM
