Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • Diah
    • Feb 2013
    • 6427
    Originally posted by bohaboha
    i did but no answer the tv does not want to start allways on STBY
    only the point of service menu need to do it from STBY all other i wrote should the TV on.
    did the Tv response to RC ?
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      #62
      -the TV does not respond to RC
      • Diah
        • Feb 2013
        • 6427
        so you don't have 5V on the socket i mentioned before...... MB replacement or the chip i mentioned to change
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          #64
          please can you point out the socket CN1101 and can i dot it only on stand by?
          • Diah
            • Feb 2013
            • 6427
            PIn 7 at STB 5V ... LVDS 3 ,4 3.3V when Tv on
            Click image for larger version  Name:	20250105_132135.jpg Views:	0 Size:	1.37 MB ID:	3545110
            • Diah
              • Feb 2013
              • 6427
              check yours RC if it blink with yours mobile camera... easy method.. here are the diagram of the socket
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                #67
                on lvds 3 and 4 have 0.4v 0.8v
                Pin 7 seems to be short but there is 3.353 on1 and 3.15 on pin 4 then i have 5.191 on pin 12 3.381 on pin 13 then 3..313 on pin15
                • Diah
                  • Feb 2013
                  • 6427
                  3.3V will generate one time only it used also by TV RC of the wifi / BT module... as well the IR so any one have short will kill this rail
                  • Diah
                    • Feb 2013
                    • 6427
                    check the RC with mobile camera
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #70
                      The RC is responding
                      • bohaboha
                        • Nov 2012
                        • 1017
                        • sweden
                        #71
                        Click image for larger version  Name:	IR-WIFI-BT.jpg Views:	0 Size:	170.7 KB ID:	3545135
                        When I press on on the RC STBY goes out and returns directly in the same position as if it can't start the TV so the RC works.
                        I have managed to get rid of the black heatsink.
                        thanks for the chart but it's not exactly the same because on my kontact pin 6,16,19 and 20 are free(not used) plus I only have a start button
                        • Diah
                          • Feb 2013
                          • 6427
                          if it response to RC then try my post 54 56 ..... and check the LVDS socket which pin have 3.3V
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            #73
                            I have tried several codes there must be a specific code for this series of Samsung
                            • Diah
                              • Feb 2013
                              • 6427
                              they are all the same over this shit samy..... yours T.CON on boards didn't start and the issue at Dc DC converter
                              • apokalipto
                                • May 2011
                                • 4
                                #75
                                You can activate pmic voltages shorting trdy1&3 test points, for this test you must disconnect lvds cable.
                                • bohaboha
                                  • Nov 2012
                                  • 1017
                                  • sweden
                                  #76
                                  thank you i ll try if i find those test points quite difficult to se any inscription
                                  • lotas
                                    • Jan 2016
                                    • 4711
                                    • Russia
                                    #77
                                    There is nothing complicated here, they are here, install a jumper between them and disconnect the U-shaped cables on the panel strips one by one...
                                    • bohaboha
                                      • Nov 2012
                                      • 1017
                                      • sweden
                                      #78
                                      thank you so much lotas my eyes need to be renewed please do you have an idea why I am not able to reach Service Menue ? have tried with several codes but there might be something for this series very grateful if you can refer
                                      • Diah
                                        • Feb 2013
                                        • 6427
                                        did you got the screen displaying image ??? so you are asking on service menu code !!!
                                        • bohaboha
                                          • Nov 2012
                                          • 1017
                                          • sweden
                                          #80
                                          No Diah nothing displayed. yes am asking because none of the code is working it seems the TV freeze on STBY
                                          however the 12v,3.3v and 5 volt are present on the Tcon part of the board and that 5v you wanted on pin 7 is there on pin 12 instead of pin 7 but no 3.v on the lvds
                                          i do not understand why there is 180v and 190v on the cold side of the power supply
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • stinger
                                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                            by stinger
                                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                            04-17-2024, 03:06 PM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
