Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • bohaboha
    • Nov 2012
    • 1017
    • sweden
    Originally posted by Diah
    you have U ribbon cable one on each side at the middle of the panel buffer boards.. try disconnect one a time.
    Hi I have done new tests on the diodes and they give completely different readings from right to left 3.5, NR , 4.1, NR ,1.2 , NR .1.5, NR a bit strange but nomoresonys they should not be discharged before testing them because it is written there Discharge
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      Hi Diah no change when removing U ribbon it's like you haven't touched anything
      • bohaboha
        • Nov 2012
        • 1017
        • sweden
        Seems like an odd reading, I would lift/unsolder one leg of the one reading 1.7 and retest out of circuit.
        • Diah
          • Feb 2013
          • 6422
          then the issue as expected at MB... the Video source switching on but no data deliver of video so the screen lighting with no image.
          try use set Top box set it to low resolution then use it at this set at HDMI ARC port.. beside it plug USB stick on the root of it media Photo , movies... when you turn on try always the source on RC pressing once atime every 30 second
          if there are no effect on screen then you have issue at the SoC ... look at the downside of MB where the SoC installed if there burn of heating.
          • bohaboha
            • Nov 2012
            • 1017
            • sweden
            I do not have or can not se the menu to handle the set Top box or do there is a way to do it without seeing the Menu?
            on the backside of the MB there is no trace of burning yet even i felt it was a bit hot for the rest can you please explain it step by step if possible
              • 12220
              • U.S.
              #26
              Those are odd readings, not sure what's wrong but that's not what a diode should read, simple diode testing there: https://www.youtube.com/watch?v=qhPZD9avoac
              • bohaboha
                • Nov 2012
                • 1017
                • sweden
                #27
                Sorry all of them are reading 0.439 stupid me using badly my multimeter because i get cold
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  #28
                  now I have tested the main board and found short on R82 2051 and the 4 capacitor around and on the backside a few more
                    • 12220
                    • U.S.
                    #29
                    Can you post a good clear photo of this area?
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #30
                      here 2 pictures with the position of the short the black cover is a bit hard to remove maybe i need to warm it a bit
                      • bohaboha
                        • Nov 2012
                        • 1017
                        • sweden
                        #31
                        here some pics do you have any idea how i can remove the black cover it seems to be glued or i do not know because it is a bit hot there
                          • 12220
                          • U.S.
                          #32
                          The picture isn't very clear, is there little plastic bits poking thru the rear of board? If there is you need to squeeze them together a little to let them thru the board.
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            #33
                            all of them are loose but the heatsink seems to be glowed in the middle. how shall i proceed with the short to eliminate
                            • Diah
                              • Feb 2013
                              • 6422
                              yours photo... the area and parts you marked no short at them... they related to the TV SoC as filter installed outside the SoC.
                              inside the Soc there are Coils and connection need to have filter no place inside the Soc for them.
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                #35
                                then please Diah tell me what to do to solve the problem
                                • Diah
                                  • Feb 2013
                                  • 6422
                                  well for me all Panels with sizes Even Numbers such 50 60, 70 are rubbish,
                                  as i wrote before the one i solved was 75.. and the issue was at the chip DC-DC Converter as you have on boards VPMS2GMB
                                  • EazyBone
                                    • Jun 2023
                                    • 1351
                                    • United states
                                    #37
                                    I have this same experience. 50/60/70 are shit. They short and die too much, 60 is the best of the 3 but they suck!
                                    • bohaboha
                                      • Nov 2012
                                      • 1017
                                      • sweden
                                      #38
                                      ok sure all the panels are what they are and that's what we get from people but your answer is not of sore help thought you would give me a more thorough guide on how you have fixed yours even though it was a 75 very grateful for all the info thanks or maybe a link
                                      • the Benninger
                                        • Nov 2022
                                        • 189
                                        • venezulan
                                        #39
                                        Discard the tcon, and the main board, because power supply is not your case
                                        • Diah
                                          • Feb 2013
                                          • 6422
                                          what kind of guide you are looking for ? i wrote the issue was VPMS2GMB ... if you don't have the ability and instrument to approve yours converter work and provide all V DC to the chips and T-CON On boards and SoC..!!!
                                          what i should write.. search after data sheet to learn where and how it converted V DC to T-con on MB and SoC. are you waiting from me to deep my head and instruments at yours room via web ?? funny.
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • stinger
                                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                            by stinger
                                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                            04-17-2024, 03:06 PM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
