Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
somehow it have to be some difference it is a board for 58inch and mine is a 70 inches as you know but i follow your recommendations you said any even number should work i know it is not a guaranty but do you think it will work ?.Comment
Sorry Diah i do not understand what do you mean with "start the TV with out any socket of WIFI and front IR," take away the wifi connection and the jumper it is ok but the other ????Comment
Left U ribbon disconnected loop with lite Screen then black every start is with lite screen.
same with the right U ribbon disconnected
but with only the middle connected without the left and right side that part is steady no more loop you can se the picture in post 104Comment
and i do have a board for 65 inches that have only one LVDS to the Screen it looks identical to the 70 inches
i ll post some pictures of them all to se the differences
Yes, there were never any problems with them, here in the photo there are control points, check the resistance with a multimeter between them (between 1 and 2, between 1 and 3,...., between 2 and 3, between 2 and 4, and so on) and between the ground, there should not be low resistance.Comment
Hi again here the pictures of the 3 Mainboards they are almost identical only the 65 inches which differs with the others with socket on the upper left corner and it is active but probably they are not compatible as the 58 inches dealt with in this thread does not correspond to this Screen and neither for the remote control maybe it needs to be reprogrammed (region issue )Comment
from start before you missed with 70MB, you have the issue on Panel,
70, and the one you said 65 they have only T-C Tuner, the 58 have T-C-S Tuner, i i did wrote before its had different at function, could be the wiring of IR socket different too this why no RC function.
you can try 65 with out jumpers bur disconnect the left and right U ribbon., to avoid Panel short effected the MBComment
I think I have to find the right values for them to be sure, maybe someone here who has the same board that can enlighten us about itComment
i have an other idea : i have the power supply for that 65 inches if i swap both Mainboard and Power Supply and give it a try hopefully i have the STB contact you know i sell TV parts on E-Bay so i have some parts i use to take all the parts from the set i find.
i hope it does not hurt the screen what do you suggest for thisComment
by MgiffuneI have a 60 inch Samsung UN60EH6000F flatscreen TV. The screen went black a few months ago Sound is good, backlight is good, no menu. I replaced the TCon board with a used board purchased from Ebay. It worked fine for a 3-4 months, then the screen started ‘fading' back. Once again, sound is good, backlight is good, no menu. However, this time the picture looks fine for about 10-15 minutes, then fades back. If I power cycle the TV, the display reappears, for another 10-15 minutes, then fades black again. Repeatable ever time.
I ordered a supposedly ‘new' Tcon board this time, and... -
by mrtekHi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...6 Photos
by mecha1166KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
by stingerWhen I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
by mar1inHi everyone,
I've got this Samsung here that would be stuck in a boot loop.
After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
Thanks in advance - Loading...
