Samsung UE70TU6905 BACKLIGHTS AND SOUND ON NO PICTURES BUT SCREEN NOT DARK
This topic has been answered.
  • Diah
    • Feb 2013
    • 6422
    also put back the cable ANA_DIM in the socket.,
    the feed back points are marked by lotas post#77
    • bohaboha
      • Nov 2012
      • 1017
      • sweden
      #102
      I made the test with jumper on those point market By Lotas and Pin2 unhooked . what do you think that result i get in my last post ?
      • Diah
        • Feb 2013
        • 6422
        the part of panel at yours last test which didnt show picture are shorted.... you need to show here the buffer boards of this part if there any esd diode installed on it
        • bohaboha
          • Nov 2012
          • 1017
          • sweden
          #104
          Hello new day new attempts. I have done new tests with ANA_DIM pin 2 disconnected and with jumper on feed back points.
          looking to the screen
          1) The left buffer board removed = no picture backlight on the TV goes in start loop and STB flash 3 times 3 flash.
          2)the middle and the left buffer board connected start with the logo for two to 3 seconds, then no picture but backlight on, then goes in the start loop with STB flash 3 times 3 flash.
          3)only middle buffer board attached = see attached picture no loop and no STB flash​ .
          Diah here some pictures of the buffer board as you asked
          pictures order from left to right 135133,135122,13508,134759,134708,134551 and 134502
          • Diah
            • Feb 2013
            • 6422
            we said put back ANA_DIM. and connect the left and middle side only.. see if there loop or not
            • bohaboha
              • Nov 2012
              • 1017
              • sweden
              #106
              ok sorry and with or without the jumper on feed back points? did you find that esd Diode on buffert board
              • Diah
                • Feb 2013
                • 6422
                all work now with jumper.. later after the issue cleared u can remove it
                2 esd
                • bohaboha
                  • Nov 2012
                  • 1017
                  • sweden
                  #108
                  2 esd
                  with ANA_DIM pin in place and the jumper and the left and middle side connected the TVn shows the logo then start loop
                  • Diah
                    • Feb 2013
                    • 6422
                    remove the jumper and do same test.. see if the screen show ... keep it in loop so you can check the esd diode if one of them got warm
                    • bohaboha
                      • Nov 2012
                      • 1017
                      • sweden
                      #110
                      with jumper and a smal tape on the left U ribcon it shows a picture on all the Screen for 3 second then loop. the esd diode never get warm in any situation with or with out a Jumper but maybe that IC near it or a capacitor are bad but no heat on them.
                      I am having problem to get into the Forum site from home i am answering from Bibliotek att home i get "connection not private " and not secure site ,
                      hope i will fix it soon.
                      i realy do not know what to do next maybe i ll go on with tape trying .but is ist problem with jumper and tape or i have to remouve the jumper to try the tape ?
                      thank you very much for your help
                      • bohaboha
                        • Nov 2012
                        • 1017
                        • sweden
                        #111
                        Hi without a jumber the backlight is on black (bleue) screen no pictures but no loop anymore and no components get hot on the screen ribbon even the esd diodes . the set do not respond to the RC yet..
                        • lotas
                          • Jan 2016
                          • 4708
                          • Russia
                          #112
                          Because without the LVDS cable the motherboard does not see the panel and blocks all output voltages to the panel, that is why the jumper is installed (panel - motherboard feedback (T-CON)).
                          • bohaboha
                            • Nov 2012
                            • 1017
                            • sweden
                            #113
                            yes now i understand thank you. now how to test those 2 esd diod Diah " 5R2P " pointed in the pics and no component get warm all over the buffer boards
                            • lotas
                              • Jan 2016
                              • 4708
                              • Russia
                              #114
                              Yes, there were never any problems with them, here in the photo there are control points, check the resistance with a multimeter between them (between 1 and 2, between 1 and 3,...., between 2 and 3, between 2 and 4, and so on) and between the ground, there should not be low resistance.
                              • bohaboha
                                • Nov 2012
                                • 1017
                                • sweden
                                #115
                                Hi Lotas if I have understood correctly i should measure the points between them, that is, 1 against 2,3,4 to number 14
                                Then all the points in the same way.
                                test the points to the GND from left to right:
                                266.5k ohms most points except 2 which is 3325.6k ohms
                                The points in between are quite mixed very hard to report everything here from: 09895mH, 1.755m ohms this for the first point against the others.
                                If you want me to report everything I'll find to record values without typing one by one and then write here
                                Or maybe a few points are enough. thank you
                                • Diah
                                  • Feb 2013
                                  • 6422
                                  post photos with remark on yours original MB and the replacement only on LVDS socket and front IR-LED indicator socket and WIFI socket
                                  • bohaboha
                                    • Nov 2012
                                    • 1017
                                    • sweden
                                    #117
                                    Hi Diah here some pictures of both boards the native one has hand written notes on it
                                    the first row of pictures is the old one
                                    • Diah
                                      • Feb 2013
                                      • 6422
                                      did you soldered out part from the original boards close to the LAN port? its look huge short caused at it which effected the IR boards..
                                      by the way yours jumpers don't let with chassis in contact
                                      • Diah
                                        • Feb 2013
                                        • 6422
                                        Jumpers should solder in 90° of points not from side.
                                        • bohaboha
                                          • Nov 2012
                                          • 1017
                                          • sweden
                                          #120
                                          no i dit not solder anything on the board and the jumper i desoldered one side of it but leave it there for further test if it needs.
                                          is the pictures good for your request?
                                          • Mgiffune
                                            by Mgiffune
                                            06-09-2024, 10:28 AM
                                          • mrtek
                                            Samsung UN65js8500F, no sound, blank screen and T-Con board with one LED on
                                            by mrtek
                                            Hi I am new to this kind of repairs but I want to learn..I have a Samsung UN65JS8500F. the TV used to work and I tried to fix darker areas in the middle only ( img 1,2,3). I thought the led strip were bad..not the case. I did not research in advance what kind and where the LED were located. In this model they are located vertically on right and left side. Took the TV apart and put it back together. Now the tv shows no welcome screen and no sound is available thru the speakers. ..just a black screen..Backlight LED do turn on...also noticed a 5 blink code , not sure if that was there before. I can...
                                            11-26-2024, 09:58 AM
                                          • mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen.
                                            by mecha1166
                                            KDL-60EX500. Comes on fine, sound is fine, backlights come on. Blank screen. Already tried reset POWER/VOL-. Anyone else have this problem? Possibly bad T-Con RUNTK4244ZZ or panel? Could main or power supply cause this? There were 2 blown 560u 35v on power going to backlights but they were still working fine. Thanks for your help.
                                            11-25-2024, 05:22 PM
                                          • stinger
                                            Samsung UN70TU6980FXZA no sound no picture but does have backlights
                                            by stinger
                                            When I turn tv on, the backlights come on but there is no sound or picture. I have read that these tv's have problems with the panels going bad but the "no sound" has me questioning if the main board is bad. Is there a way to troubleshoot the main board to determine if that is the problem?
                                            04-17-2024, 03:06 PM
                                          • mar1in
                                            Samsung TU8000, backlight and sound on, stuck in blue screen
                                            by mar1in
                                            I've got this Samsung here that would be stuck in a boot loop.
                                            After opening up and doing the tape block method, I was able to get it to turn on and play sound from the HDMI input, but with a blue screen.
                                            Does that mean there is another combination of pins that I need to block in order to get a picture, or is there something more serious, faulty mainboard or faulty panel?
                                            Thanks in advance
                                            11-08-2023, 05:43 PM
