Samsung ua40es6200 TV no display
  • AdrenalinTL
    • Apr 2024
    • 57
    • test
    Got a Samsung TV that has no display. Did a bit of troubleshooting.
    When I first got the TV, it worked, about 2 years ago. Left it in the garage, and now it has 5 blinks of the power light.
    I unplugged the main board from the power board and the display blinks for less than a second constantly. Almost as if it's trying to power up but can't.
    Anyway I tested the fuse and there was 0 displaying on the multi meter.
    Now the 5 lights have suddenly vanished. No idea why.
    Here are the boards (Bit of an odd model I think?)
    I see no visible damage to anything.
  • lotas
    • Jan 2016
    • 4752
    • Russia
    First, you need to indicate the TV model, motherboard and power supply numbers.
    Secondly, where will you get five blinks of the standby LED if you disconnected the motherboard from the power supply?​
    • AdrenalinTL
      • Apr 2024
      • 57
      • test
      It's a Samsung ua40es6200
      Power supply is a BN44-00518C
      The 5 blinks happened when I plugged power in initially. The standby light blinked 5 times. Other posts seem to suggest that is just a power on light and doesn't mean anything specific.
      • cheeky2
        • Dec 2012
        • 337
        A bit of common sense would be to download the service manual for the TV! A quick google will show a free download for it here https://elektrotanya.com/samsung_un4.../download.html
        Then start reading and checking for voltages on your power supply, ensuring that you are fully aware of the risks when working with mains voltages! If you are not then leave it to someone who does.​
        • AdrenalinTL
          • Apr 2024
          • 57
          • test
          Thanks. I am still very new to all this and have been shocked before by DC voltages and in general just don't like electricity.
          That being said, I am trying to learn electronics.
          Can this be narrowed down to the power supply though or could it also be something else? I could replace the whole board if I find another one?
          • fez
            • Oct 2009
            • 11
            IM not a tv repair engineer but if you have a service manual as said you could test the voltages. This link satells you samsung error codes: https://9meters.com/technology/tv/sa...-and-solutions
            • Davi.p
              Hobbist Tech
              • Sep 2009
              • 4461
              • Italy - Milan
              What's that incomplete guide? OMG..
              • AdrenalinTL
                • Apr 2024
                • 57
                • test
                Ok cool thanks, will investigate a bit further. Not keen on testing voltages but have an electrician friend who can maybe do it and teach me at the same time
                  • 12276
                  • U.S.
                  Need to start someplace, try testing the diodes and resistors on top of the board, can also check the soldering on underside of board, search for images of bad solder joints if needed. Youtube is your friend for how to videos, also some troubleshooting voltages here. Heed the HIGH VOLTAGE warnings the /primary/hot side can be deadly: https://www.youtube.com/watch?v=fbcCVv_ahBo
                  • AdrenalinTL
                    • Apr 2024
                    • 57
                    • test
                    Thank you. Nice video.
                    • PantherDave
                      by PantherDave
                      Hi all!
                      05-29-2024, 02:01 PM
                    • GLISIT
                      by GLISIT
                      01-16-2025, 02:29 PM
                    • Bonaventure Vigil
                      ACER ASPIRE A515-52G CAN ON BUT NO DISPLAY, NO POWER AT VCC_GT
                      by Bonaventure Vigil
                      Dear All,
                      Please really2 need Help on this Acer A515-52G Motherboard Compal EH5AW LA-G521P Rev: 1A.
                      At first this laptop can on, keyboard light on but no display. Open the motherboard, found out the PQZ3 Mosfet and PUZ3 ic near it burn. Refer picture below. Then I replaced both. All the power rail 3.3,5,1.2, 1.35, 0.8V have power back after i turn on the laptop except for the VCC_GT rail. Voltage at Power Supply showing 0.000A before turn on, after turn on it became 0.5 0.6A. Seem cannot boot and still no display. Then I replaced the PUG1 and mosfet, but the VCC_GT still no power....
                      12-12-2024, 10:22 AM
                    • mrtek
                      Samsung UN43NU6950FXZA No power
                      by mrtek
                      Hi
                      Picked up another TV. Samsung UN43NU6950FXZA. No power and no standBy led on. Removed back cover and:
                      Main fuse = OK
                      Back light LED = OK. Power them with aux power source
                      LED output = OK 156V
                      I do get 12 V DC out of the power supply going to the digital section but no 5V or 3.3V. PS_on voltage is only 1.8V. I have looked everywhere on the PCB , I could not find i reference for 5V output.
                      Also removed connections to panel, speakers and remote but no luck. One strange thing is that even with the LED power supply working, backlight LED do not turn on...
                      07-20-2025, 08:06 PM
