Toshiba 26hl47 White screen
  • Shinju
    • Mar 2014
    • 1239
    Re: Toshiba 26hl47 White screen
    Check the tab bond board at the top of the screen, the 37hl i had the board that the tcon outputs attached to was warped pretty bad, I didn't have any issues with that screen but I did see it putting a lot of stress on those bonds.
    I used high temp rubber shims between the top of the frame and board and it flattened them out straight again to avoid any damage.
    Seems to be a common problem with these older toshiba panels the heat warps those thin boards pretty badly.
    • bammbammfran
      • Apr 2014
      • 476
      a tab bond issue won't make the entire screen go white like this one does.
        It can actually - I've had a Chimei 26" panel cause it.
        • Shinju
          • Mar 2014
          • 1239
          I only mentioned this since he said he flexed the frame and the picture became unfrozen.
            I did not notice that, exactly the same symptoms I had with Chimei 26". And unlike most tab bond repairs I have done it seems to be long-term reliable, I haven't had one fail (done 4 now, I think)
            • CraigR
              • Dec 2013
              • 959
              It was the upper right ribbon cable. I put on some padding on that cable and works good now.
              • harp
                White screen repairs
                by harp
                To ask here... I have few devices with white screen problem, actualy nokia 2220 and some fuji? camera, and try to understand what is common problem to cause that issue.
                Yes, both devices work everything else probably ok, I mean, I hear intro melody and keypress click sound, DTMF tone, power on off... all ok.
                On desk is nokia 2220 slide, and I check all screen connectors and components arround it, measure voltage drop, but all looks ok. I suspect on slide flex cable, but it look ok and white screen is not interupt while flexing board, pushing conectors, and sliding up down. In attachment...
                05-13-2024, 03:43 AM
              • Ryan.man
                by Ryan.man
                02-04-2025, 12:23 PM
              • EazyBone
                Sharp LC-65Q620U White Screen
                by EazyBone
                Another TV topic!!
                I got this sharp TV that when I first plugged it in it showed the sharp logo and then went to the input screen. This was about 30 seconds and then it showed white screen. Now I can't see anything but white screen. This has a separate TCON and Main.
                The TCON is getting 12V and several parts are as well but the VGH line is only .5Volts which I thought is totally incorrect.
                Am I on the correct assumption that the TCON is bad somehow if I'm only getting that voltage or is there something else I should check?...
                08-21-2024, 12:56 PM
                09-06-2024, 05:27 AM
              • hcinne
                Dell G15 ryzen edition black screen 2 amber 1 white
                by hcinne
                I have a Dell G15 ryzen edition (ryzen 5) that turns on but won't post, black screen, keyboard lights on, caps lock led on, fans turns and the battery indicating light is showing 2amber and 1 white according to dell website it's a cpu failure, but i tried few basic things before i open it up i tested the screen by pressing the d button before powering it up but it didn't show anything i tried the ctrl+esc for bios recovery but still black screen i tried refreshing the screen, i plugged it on an external monitor but same thing. Next step i unplugged the battery and kept pressing the...
                07-23-2024, 07:56 AM
