Sceptre x322bv-hd powers up w/sound-but no picture
  • vinceroger69
    • Mar 2012
    • 6714
    • uk
    #41
    Re: Sceptre x322bv-hd powers up w/sound-but no picture
    is there a part number on this transformer?
    • cbr6861
      • Jun 2014
      • 32
      yup-
      MIP320FL-T3 .... I can get one on ebay coming in from china.
      Does this appear to be faulty?
      • cbr6861
        • Jun 2014
        • 32
        seems to me the coiling has been compromised somewhere in the winding
          That is the high voltage winding, I expect to hear some arcing sound before it goes into shutdown mode. BTW, you need to use 2K Ohm range to check the resistance. It does look like it has been arcing.
          • cbr6861
            • Jun 2014
            • 32
            in the 2k range i get .000 on the secondary and nothing on the primary. on the 200 range i get 1.5 on the secondary and nothing on the primary.
            • cbr6861
              • Jun 2014
              • 32
              Just wanted to shoot an update this post. I went ahead and replaced the entire power board as a unit, although I'm pretty sure the high voltage winding as Budm mentioned was the culprit. Once installed...walla! I got backlight coming on, and once all put back together the set has been working since. I wanted to thank this awesome forum and specifically Budm & DGtech for jumping in to assist, couldn't have done it without you guys.
                Thanks for the good news.
                • androidmikey
                  • Jul 2014
                  Maybe an old thread, but I have a similar issue with a Sceptre I'm working on for a friend. Is anybody still there? I followed this thread and measured voltage output on the board and it's very close to what was in the pic here. The picture is so dark you can't see it unless you hold a flashlight up to the screen, but when you do the picture is fine (where you can actually see the light from the flashlight that is). Any ideas? New to this forum btw. Please be nice. ;-) I've gone to school to work on medical equipment, but I'm a little rusty and haven't worked on these types of units. Thanks in advance! The model is x322bv-hd.
                  • huckster24h
                    • Mar 2015
                    • 6
                    Anyone know the values for EC10 and EC14 in MIP320FL-2
                    • huckster24h
                      • Mar 2015
                      • 6
                      For future reference... Glued down caps in MIP320FL-2:
                      EC10 - 220uf, 35V
                      EC14 - 10uf, 50V
                      • csmith
                        Vizio D50u-D1 Powers up no picture
                        by csmith
                        I replaced the backlights all good. Two months later set was dead, had a shorted D9100, replaced all good again.
                        Now months later set powers up,backlights light ok,no picture. 12volts missing from fuse on tcon. 12VA on power
                        supply is 19 volts. Changed D9100 again, same, 12 volts measures 19. Am I looking at a power supply or mainboard
                        issue. Set will power up with remote but not power off....
                        07-11-2025, 11:52 AM
                      • sergio_av
                        Acer Aspire E5-571G-52NH powers on, no picture. PCH_ENVDD goes off and on.
                        by sergio_av
                        Hi, I'm unexperienced with troubleshooting and I'm not sure how to proceed with this laptop.
                        Motherboard is A5WAH LA-B991P I think, i5-5200U and nvidia 820m.
                        When I received the laptop, CMOS battery had 0V. I took it out and all the testing has been done without a CMOS battery and without the main battery plugged in, I haven't been able to see physical damage, burnt or missing components with a quick visual inspection, and no shorts were found.
                        Laptop charges the battery, powers on when ON button is pressed when powered from charger and when powered from the battery, but...
                        01-01-2025, 05:27 PM
                      • KYBOSH
                        Trying to Save - LG 60PH6700 60-inch plasma HDTV - Powers ON but no picture
                        by KYBOSH
                        Saved this beast from the landfill this weekend.
                        Manfactured July 2013 in Mexico.
                        I love working on plasma TVs.
                        Its been a while but I was lucky enough to find 2 this week.
                        The TV powers on and stays on but no picture. Havent checked for sound yet.
                        No bulging caps although the insides are pretty dusty and the boards are discolored from many years of high heat.
                        Will start troubleshooting tonight.
                        10-17-2024, 01:17 PM
                      • Tr0ll
                        by Tr0ll
                        Original T-con:
                        First replacement T-con:
                        10-07-2023, 07:48 PM
                      • JJAAMM
                        by JJAAMM
                        Problem
                        07-06-2023, 06:01 AM
