When first switching on, the left half of the screen is black. Over the next half hour it changes to vertical stripes, then flickering. Even after an hour, the left half shows occasional artefacts. The behaviour is sensitive to mechanical shock. A judicious 'thump' on the top right area of the bezel can change the patterning and occasionally will clear all flickering. After a couple of hours, the picture is stable. Switching off, and then on again after 10 minutes causes the flickering to restart.
I have opened it up and have tried nudging each connector and each wire in each harness and cable, flexing each PCB, local cooling (spray), without any clear result. I have removed and cleaned every visible connector. I have replaced the T-CON board.
Any suggestions?
Thanks!
Any suggestions?
Thanks!
