Purple/Pink Lines / Postering on plasma LG 60PZ550
  • sause
    • Jan 2015
    • 4
    • usa
    #41
    Re: Purple/Pink Lines / Postering on plasma LG 60PZ550
    Don't think i was to clear on my last question-sorry Is it possible that another board may have caused the problem with the blown fuse on the z sus board- thank you
    • Tindal
      • May 2015
      Originally posted by tom66
      This is your Z-sustain board:
      https://www.badcaps.net/forum/attach...6&d=1401401845
      This is your Y-sustain board:
      https://www.badcaps.net/forum/attach...2&d=1401401774
      (the green boards attached are the buffer boards)
      Near the middle top of the Z-sustain you can see a few coil packs (technically called inductors) and that the board has discoloured significantly underneath them due to the heat produced. You can also see the same coil packs between the black and silver heatsinks on the Y-sustain board.
      You will need to remove both boards from the set and reflow the solder around both of these coil banks.
      Use leaded solder, for improved reliability.
      Just wanted to confirm that this worked for me as well on a LG 60PV400. After I reflowed the inductors as described above, the TV now works like new again! Thanks a million for the spot on advice!
      • MescaBug
        • Jul 2015
        • 3
        Bringing back an old thread.
        I have the same issue with my LG.
        Should I just heat the solder joints to reflow, or add flux and new solder? I have a hobby type soldering iron with leaded Kester solder. Would that be OK for a simple job like that?
          Just adding fresh solder to ensure the joints are good should be sufficient.
          • MescaBug
            • Jul 2015
            • 3
            Great, thanks for the quick reply Tom.
            • MescaBug
              • Jul 2015
              • 3
              I removed the 2 boards, inductors solder looks good to me... Anything else I can check? I have the exact same problem as the OP, I dont think I should start a new thread.
              Last picture, I circled in red one solder that looks different from the other.
              • Jerryk33
                • Sep 2015
                My 60PZ550 backed out in less that 4 years. I have 50 years experience in Consumer Products and TV'S generally last 8-12 years NOT less than 4!! Cost to repair not suitable. LG NO help in spite of this being a prolific problem for this series.
                • CraZed
                  • Dec 2015
                  I can confirm this worked for my LG 60PZ950. Purchased in 2011 and had a four year warranty and wouldn't you know it, the issue pops up exactly one month AFTER the warranty expired!
                  Our TV gets heavy usage as it is the only TV in the house and has PC/PS4/Cable hooked up to it and there are 4 people in the house and is on for a majority of the day. I'm just surprised with such heavy usage this issue didn't happen within the first two years.
                  Well, it is working now. I only had to solder half the points on the Z-sustain board. So, I'm now just waiting for the inevitable failure of the other points, the other board or my soldering hack job (never been very good at soldering tbh). Hopefully it'll last until we decide to get a newer UHD/HDR set.
                  Thanks Badcaps!
                  • Umbrella Corp
                    • Dec 2015
                    • 26
                    On Christmas Eve I was watching my LG 60PZ550. It was working fine, I never had any indication before this that anything was wrong.
                    I came back two hours later and turned it on and this is what it is now showing—sometimes it's green if I turn it off and on.
                    No menus, can't change input, but I can hear sound.
                    Does this look like the inducers would cause this as well? If not any ideas what it would be?
                    Thank you in advance.
                    (BTW there are two reflections on the picture that are not part of the problem. The image on screen is a perfect wallpaper look.)
                    • Umbrella Corp
                      • Dec 2015
                      • 26
                      I'm sorry I meant to say sometimes it's pink. But it alwyas has the same pattern in it. It is never a solid color.
                      • ReeceyBurger123
                        Never Give Up !
                        • May 2014
                        • 7325
                        • Britain
                        #51
                        Take the back off, you know how to run the test patterns ?
                        • Umbrella Corp
                          • Dec 2015
                          • 26
                          Are the test patterns built into the set?
                          If they are, I'll take it off and get back to you.
                          And just so you know my proficiency with electronics, I don't have any specialized TV equipment, but I do build all my own computers, and have spent a lot of time replacing Samsung capacitors on monitors boards. If that helps.
                          • Umbrella Corp
                            • Dec 2015
                            • 26
                            I don't have a service manual for this either.
                            • ReeceyBurger123
                              Never Give Up !
                              • May 2014
                              • 7325
                              • Britain
                              #54
                              You will need to take the back off, remove the Lvds cable from the Contrl board and jumper the two open pins. Turning the Tv on test patterns will run, upload some images.
                              • Umbrella Corp
                                • Dec 2015
                                • 26
                                Okay, will get back to you.
                                • Umbrella Corp
                                  • Dec 2015
                                  • 26
                                  Okay first I get a pure full screen Red, Green, Blue, white then a bar moving right to left and bottom to top shoing gradients. Then finally a white bar moving across black bothe vertical and horizontal.
                                  All the colors are brilliant and pure. The gradients look pure, too.
                                  Sorry about the reflections.
                                  • Umbrella Corp
                                    • Dec 2015
                                    • 26
                                    BTW, those interfernce patterns are in the picture. The gradients are pure on screen.
                                    • ReeceyBurger123
                                      Never Give Up !
                                      • May 2014
                                      • 7325
                                      • Britain
                                      #58
                                      Ok that means your mainboard is at fault. Probably failed Bga solder and it will need to be reflowed, easier to just replace it.
                                      • Umbrella Corp
                                        • Dec 2015
                                        • 26
                                        So the mainboard is the same board that I jumpered on?
                                        BTW, thank you for all of your help, ReeceyBurger123. It's been tremendous.
                                        Guess my search will start in US. And can I use the same board that's on the 60PZ550-UA?
                                        • ReeceyBurger123
                                          Never Give Up !
                                          • May 2014
                                          • 7325
                                          • Britain
                                          #60
                                          Its ok mate, also the mainboard is the one with all the Hdmi and other ports on it not the one you jumped.
                                          • smartjohn
                                            lg 60pz550-ua erratic horizontal pink lines over image
                                            by smartjohn
                                            Hello again old friends! I am perplexed with this set. The mainboard was reballed to fix the known issue of HDMI port loss. When it came back from service I reinstalled it and now have the attached image. The image is there but it looks to be some type of Z-sus problem. I have checked and rechecked and replaced the LVDT cable between the logic and main board with no luck. And yes, the inductors on both the Y-sus and z-sus have been re-soldered with clean new 60/40 material. All voltages match the panel label Vs=202, Va =55, Vzb = 110 (it was at 115 and was adjusted down) Vy = 180, and Vsc =150....
                                            11-06-2022, 06:43 PM
                                          • Anonmis
                                            Samsung 55" UN55JS9000 - Pink vertical lines due to chipped LCD panel?
                                            by Anonmis
                                            Hello all, I was recently repairing my Samsung 55" UN55JS9000 tv from the common burnt backlight LED's and cracked light guide panel issue. After replacing the LED's and putting the TV back together, I tested the tv and all I was getting was sound but no image. Somewhere along the way (could be related to the next issue) the T-Con board became damaged and after replacing it I have made a little bit of progress but now have bright pink vertical lines and still no image.
                                            The bigger issue .... I took the TV apart again and realized that I likely didn't sit the LCD panel correctly...
                                            12-01-2023, 04:31 PM
                                          • jimjoe123
                                            LCD TV Green/Pink screen problem
                                            by jimjoe123
                                            I have a Dick Smith 37" LCD TV, Model GE6804. I am using it as PC extended monitor only.
                                            Problem is while watching tv, I hear a semi loud click(like a electrical breaker tripping due to overload, just sound like it but no actual electrical overload), then screen is covered with green or pink. I can still see the original picture image but overlayed by green or pink. See attached images. Pink.jpg is what I see, and Normal.jpg is before green or pink screen, What I captured was pink screen, but about 80% of time it's green and 20% of time it's pink.
                                            Then each time...
                                            02-23-2020, 01:29 AM
                                            Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook 3 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) boardview and Acer Swift 3 SF314-42 14 inch Laptop - (AMD Ryzen 5 4500U, 8GB, 512GB SSD, Full HD Display, Windows 10, Purple) schematic. Our users have donated over 1 million...
                                            09-07-2024, 12:40 AM
                                            Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook 1 Specification for Upgrade or Repair
                                            This specification for the Acer Swift Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) boardview and Swift 1 SF114-33 14 inch Laptop - (Intel Pentium N6000, 4GB RAM, 256GB SSD, Full HD Display, Windows 10 in S Mode, Pink) schematic. Our users...
                                            09-06-2024, 09:30 PM
