philips ambilight tv faulty
  • Mikeyboy2007
    • Mar 2013
    • 745
    • Scotland
    Hi guys got a friend of a friend that has asked me to loom at his tv. He said the line used to be further down but as time as went on the fault has went further and further up the screen... is this a faulty panel ?
    I have put an old working tv beside the faulty one to show what picture should look like.
    Re: philips ambilight tv faulty
    That's a bad panel. Possibly it can be fixed by tab bond repair but probably not. Usually horizontal bars are the hardest to fix
    • Mikeyboy2007
      • Mar 2013
      • 745
      • Scotland
      Ok tom thanks will let him know cheers. Hes givin me 2 tvs so hopefully other one isnt the same.
        If you scrap this TV... I'm interested in the ambilight strips for building my own ambilight for my TV...
        • Mikeyboy2007
          • Mar 2013
          • 745
          • Scotland
          Tom sorry just got this reply. i did scrap it sorry but when i get hold of another i will let you know. i didnt realise you could build Ambilight, would RGB or dream-color strips from ebay not work ?
            I am using ones from China, but I have concerns for the overall reliability. I can get 3m of strip for about £45 which is 180 RGB LEDs.
            I then have to build some custom electronics to supply 5V @ 10A and control them to follow a video signal. I'll be putting a build log up soon on this.
            The ambilight bars seemed like a cheap way of getting RGB LEDs but most sellers wanted more than actual strips plus I'd need to decode an obscure communications protocol (TV to ambilight strips) without a usable TV, so it would have been difficult.
            This is a 180 channel ambilight design I'm working on, which basically means each light is independent and follows the video source directly.
              • 31199
              i'm sure i'v seen them much cheaper than that from china.
              5m roll costs less than that i'm sure.
                Yes, you are correct, but not with independently controllable LEDs. This design can have each of the 180 channels with a different colour.
                  • 31199
                  those ones are expensive that's true.
                  are you looking at the integrated ones or the cheapo microcontroller on the strip type?
                    WS2812B based ones, driven from twin SPI ports (90 LEDs/port)
                    Since the WS2812B can be driven up to about 360 Hz framerate, you can do sub-field multiplexing like a plasma display to get 10 bits of RGB information (at 60Hz real frame rate) which is sufficient for a good LED display. At 24fps (cinema) you can go up to 11 bits of RGB data.
                    Still a work in progress.
                      • 31199
                      http://www.aliexpress.com/store/grou...251310291.html
                        I'm buying them from Seeedstudio, it works out at $16.90/1m strip (with 60 LEDs/m, not standard 30 LEDs/m)
                        That's about $50 or £30 plus shipping cost.
                        But I am also buying some PCBs for the project from there. It samples VGA analog video and has a Tiva ARM CortexM4F on it for the control of the display.
                          • 31199
                          i was looking at this one to replace some ropelight actually.
                          http://www.aliexpress.com/store/prod...935645023.html
                          and maybe these for experiments.
                          http://www.aliexpress.com/store/prod...202415085.html
                          • dominik0801
                            Philips 55PFL6008K/12K Ambilight not working
                            by dominik0801
                            Hey,
                            I just got the TV mentioned in the title the other day.
                            Yes, I am well aware of it being a QFU chassis which is very hated - although I love QFUs (maybe for being this bad?), my main TV is a QFU too, and I bought this TV for this very reason.
                            It had the typical 2 blink error, which was fixed by a proper Fusion CPU reballing, with extra cooling mods. It works.
                            Everything is perfectly fine with it, but the Ambilight just won't do anything.
                            At all.
                            Won't work on Dynamic, won't work on Static. Not a single...
                            11-28-2022, 01:24 PM
                          • tony359
                            Faulty CRT AKF12/Philips CM8500: bad flyback?
                            by tony359
                            I have a CRT (Acorn AKF12, based on the 240V version of the Philips CM8500) which has stopped working. It's making a high pitched noise but not too high. I know this is symptom of a faulty flyback.
                            What happens when a flyback fails? I see that the main voltages out of the PSU are not reaching rated values, as if there is a short.
                            There are supposed to be 125V/26.5V/15.5V outputs but I am reading something like 48V, 10V and 8V. If I unplug the PSU from the rest of the PCB, I can measure the expected values.
                            Can it be a short somewhere...
                            08-22-2023, 04:39 PM
                          • kew1701
                            Philips taw6205 ambilight speaker STM32 mcu dead
                            by kew1701
                            Resolved dead cap which burned mcu(stm32f091rct6) ,between vss and vdd on desoldered mcu is short 5.8oh,is there a way to obtain firmware from it.i have firmware,but i thing this is for wifi/bt board phorus 5 which is on top of amp board(here lies dead mcu)...my stm32 flasher is on the way....
                            04-09-2025, 03:59 AM
                          • alro7779
                            Philips 32PFL4901/F8 BA4GF0F0102 2 Not getting standby led
                            by alro7779
                            Hello, guys!
                            The same 32" Philips TV I was having video issues, but now I don't have standby led at all. Someone here shared with me the schematic of the power supply, and checking the voltages, I see right after the resistor R604 I'm getting 1.6 v which is too low for enabling the Gate of the Q601 mosfet (the diagram says 4.2). On the R614 resistor I'm getting 181 V in and 117 V out, then through R603 I'm getting the same 117 V in and 59.9 V out, finally getting the latter voltage in the R604 BUT getting just 1.6 V out, which is the voltage that goes on to the Gate of the Q601...
                            09-14-2025, 12:25 AM
                          • G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo
                            by G33RT
                            Philips 8200 series 65PUS8204/12 stuck at Philips Logo, it does not reboot it just stays on the logo.
                            It does power up when pressing the power button.
                            I already try the power button while plugin the plug with no result.
                            Also put the latest firmware autorun-TPM191E_R.001.004.100.000.upg on a MBR/FAT32 USB stick at USB port2 with no result either.
                            Could this be an PSU or eMMC issue ?
                            07-19-2025, 03:43 AM
