Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
  • Diah
    • Feb 2013
    • 6565
    Originally posted by admxxx
    Here're more pictures with a full screen on dark and bright and a close up to show the horizontal lines.
    please dont take it in wrong way.. we want to know the reason.. thx you posted your success ..
    but you have feed back left and right on the T-CON ribbons socket.(( FB_L )). could you messure both while tv working with ref Chassis ?
    • KYBOSH
      • Oct 2011
      • 581
      • Unknown
      #102
      Thanks Diah for the reply. I managed to get picture and the TV is working now, I blocked pin number 13 on the the right side flex cable that feed the COF from the T-con, I first blocked all timing pins then narrow down to one pin. The TV is working but there's a faint horizontal lines on all right side of the TV that not very visible, add to that there's one strip of horizontal line that visible according to what viewing on the screen.
      Wow! Congratulations on the save!
      My TV is still on my bench in the same state as I left it in my last post.
      I was debating ordering a new T-Con as well but just decided to meditate on it rather than pull the trigger.
      Over the last week or two my suspicions grew that I was dealing with a panel issue but to verify I knew i would have to throw working parts at it to eliminate the mainboard and the T-Con.
      Amazing that yo you happen to have the same TV with the same issue at the same time and you showed up here!
      I know next to nothing about panel troubleshooting and repair. The best I have ever done was the tape off method.
      You mentioned you blocked all timing pins.... which ones are those?
      You blocked them off then exposed them one at a time until the picture came back? Or how does it work?
      Very interested in learning this method.
      Please dont think you are insulting me by explaining it as if you were talking to a child... bcos I am completely new to this part.
      Thank you in advance for sharing and I look forward to your response.
      • admxxx
        • Mar 2019
        • 12
        • uae
        #103
        If you look at the t-con left side socket output to the COF and read the pins you’ll find CKV1 up to CKV6 start by blocking all pins on the left side (from pin 1 to 16) then test, if you got a picture then you have to keep reducing the blocked pin count until you find the one causing the issue, when you find it block that pin only.
        • louis313
          • Dec 2024
          • New zealand
          #104
          i have the same sony 75 inch tv with exact issue,
          i have done all the test in this thread …. On Mb and t-con, and i am getting same test values as KYBOSH
          and lastly tried blocking the CKV pins but still no picture,
          Any other suggestions will be helpful
          thanks kindly
          • Diah
            • Feb 2013
            • 6565
            thanks kindly
            well i put my concern about the masking post appeared over here.. but the owner of solution take it in different way.. so i hated to complete..
            at this threat we did have followed as it should signal with user didn't have high end testing equipment, so from my side i did the best to make it easy..
            what we did .
            1- tried display built in self-test (BIST) patterns right after abnormal input detection.​. but it failed
            2- we did proved the FRC circuit on MB out of business at all
            what we can't testing here with home user (( V by One RX and a USI T TX interface )) to switch the Panels SPI to its high Freq such 120Hz or lower.
            what i do believe there are BGA issue under the FRC Chip on MB.. but its not most.. its just calculation to read results of testing not under my hand.
            • admxxx
              • Mar 2019
              • 12
              • uae
              #106
              thanks kindly
              If blocking the left side didn’t work, unblock it then block the right side and test again.
              on the tcon there’s Vone test point on the left side check if the 32v voltage comes up then goes off while turning on the TV, if that’s happening it means you have short on the LCD panel.
              • Diah
                • Feb 2013
                • 6565
                the most stupid things going on web who talking on VGH VGL VCOM VEVD..etc.
                T-CON VCC are 12V standard ... so where will be the T-CON PWM bring this Voltage over this supply?? its shown on yours DM as V high ... but its just Current Freq x resistances .. current Freq provided by Vido source which it come from Decoder or from FRC.
                so can some one tell me from which ass come this 32V.. stop please spreading sinnlose theory of some things you never went deep to understand how it work.
                • lotas
                  • Jan 2016
                  • 4859
                  • Russia
                  #108
                  The panel cannot be powered by 12 volts alone; it is supplied with many voltages, including VGH with oversupply + 25-32v (depending on the size of the panel) and this voltage is supplied by a DC/DC boost converter installed on the t-con.
                  • Diah
                    • Feb 2013
                    • 6565
                    wrong. ... read Timing Control boards function provided by Vestel., dont give here cut of crazy one posted over net
                    • lotas
                      • Jan 2016
                      • 4859
                      • Russia
                      #110
                      Well then, what else can we talk about if everyone is stupid and builds panel production engineers incorrectly....
                      Read at your leisure
                      https://tvrepairsolution.blogspot.co...lcd-panel.html
                      • Diah
                        • Feb 2013
                        • 6565
                        Well then, what else can we talk about if everyone is stupid and builds panel production engineers incorrectly....​
                        its not about Design.. we are talking on method of Electronic Mathematics and component , PWM alone can do DC to Dc step down.. over the limited VCC proider it need Current Freq. this is provided via LVDS from FRC or Decoder.
                        • Diah
                          • Feb 2013
                          • 6565
                          by the way lotas i do find Vestel service manual or parts documentation are trusted source over all other brands
                          • Davi.p
                            Hobbist Tech
                            • Sep 2009
                            • 4539
                            • Italy - Milan
                            #113
                            there is some problems i think Lotas list, 3,3v for my memory is called usually Vcc, or when Vcc are split in two there is V3D3 / Vcc33.. and V1D8/Vcc18 (for 1,8v)... AVdd is usually in the range of 15-17, from what i seen, but i mean usually.. for the rest i don't speak, it's basic lcd info..
                            • admxxx
                              • Mar 2019
                              • 12
                              • uae
                              #114
                              At least in my TV the dc-dc converter was on the tcon, there’s puck converters and there’s power manamgent IC (two of them one for each half of the panel that responsible for sub voltages (generated from the 12v main rail) those IC have short current detection that will cut the sub voltages in case a short detected that’s why as soon as you power up the TV the Vone spikes to 32v then cut off. I do a lot of electronics repairs but this is my first attempt on LCD panels. There’s no service manual for the tcon of the TV I have but I was able to theoretically figure it out. If you check any LVDS Pinot out you’ll notice that there’s no PWM (except for back light on smaller panels) and that’s definitely means that all sub voltages generated on the TCON from the main 12v feed via on board dc-dc converter and power management IC.
                              • Diah
                                • Feb 2013
                                • 6565
                                At least in my TV the dc-dc converter was on the tcon, there's puck converters and there's power manamgent IC (two of them one for each half of the panel that responsible for sub voltages (generated from the 12v main rail) those IC have short current detection that will cut the sub voltages in case a short detected that's why as soon as you power up the TV the Vone spikes to 32v then cut off. I do a lot of electronics repairs but this is my first attempt on LCD panels. There's no service manual for the tcon of the TV I have but I was able to theoretically figure it out. If you check any LVDS Pinot out you'll notice that there's no PWM (except for back light on smaller panels) and that's definitely means that all sub voltages generated on the TCON from the main 12v feed via on board dc-dc converter and power management IC.
                                any short will make spike at V then down in the protection circuit .... at other hand we do know the T-CON have PWM. but you still talking on VDC nothings about Freq or Currents. what you see on yours DM in V DC mode its not correct when the subject at T_CON.
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  #116
                                  Thank you for coming back to explain this.
                                  My apologies as I have been swamped as its the end of the year.
                                  So I tried blocking off PINS 1-16 as instructed but I did not see any change on the screen.
                                  I then tried the opposite side with the same results.
                                  I checked the voltage of VONE but it never registered any voltage other than 0.015v.
                                  It never jumped to 32 when I turned the TV on.
                                  • admxxx
                                    • Mar 2019
                                    • 12
                                    • uae
                                    #117
                                    Hi, the other side must be also from left not right. Also, the count on right side should be start from the test points (check the label on the tcon pins to understand where are the CKV and CKVB lines
                                    • KYBOSH
                                      • Oct 2011
                                      • 581
                                      • Unknown
                                      #118
                                      Than you for this.
                                      Just to clarify:
                                      On the LEFT side I am to block off PINS 12-26?
                                      Those pins correspond to:
                                      CKV1 = PIN 12
                                      CKV2 = PIN 13
                                      CKV3 = PIN 14
                                      CKV4 = PIN 15
                                      CKVB1 = PIN 16
                                      CKVB2 = PIN 17
                                      CKVB3 = PIN 18
                                      CKVB4 = PIN 19
                                      STVP = PIN 20
                                      CKV6 = PIN 21
                                      CKVB6 = PIN 22
                                      CKV5 = PIN 23
                                      CKVB5 = PIN 24​
                                      Then if that doesn't work I should block off PINS 12-26 on the RIGHT side?
                                      There are no markings on the RIGHT side denoting which pins are CKV or CKVB.
Name:	Screenshot 2025-01-05 at 5.40.00 PM.png
                                      • lotas
                                        • Jan 2016
                                        • 4859
                                        • Russia
                                        #119
                                        No, they are in this part...
                                        • KYBOSH
                                          • Oct 2011
                                          • 581
                                          • Unknown
                                          #120
                                          lotas
                                          admxxx
                                          No joy....
                                          Tried covering both sides and no change in the screen whatsoever.
                                          I could hear the OCD music playing and the TV was responsive to remote.
                                          Just no visual sign of life on the Display.
                                          Click image for larger version  Name:	Screenshot 2025-01-05 at 10.20.10 PM.png Views:	0 Size:	1.84 MB ID:	3542047
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
