Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
  • KYBOSH
    • Oct 2011
    • 581
    • Unknown
    #61
    Originally posted by Diah
    from one point you want to learn... that's fine.... but did you know any attempt to work or fed V at wrong area, you will kill many other parts... so why we do spend.time to help you and we do read how you are going to kill the set ? better leave you and laugh !!! NO this no one serious man man will do it-
    you can read on the area i show you F and in general F are fuse .
    Thank you again!
    I checked all of the fuses in this section and indeed all the fuses on the board and they were all intact and read as continuous.
    I then proceeded to check each component around those 2 ICs. I checked for both continuity and measured their resistances.
    Here is what I found:
Name:	2024-12-01 14.08.44.jpg
    The there were several resistors (marked in red) around IC4002 reading as shorted (MM ringing tone) in circuit and their resistance were low (~47Ω).
    Seeing how none was completely shorted Im guessing there may or may not be a problem with that IC there (W25Q32JV).
    It may just need to be reflashed and not replaced. Either way i will need the dump for this chip if it is indeed the problem.
    Searching for it now!
    • Diah
      • Feb 2013
      • 6573
      dont play with these IC content...
      leave the heatsink out and put the MB back in TV....turn on then measure both IC Pins 8 V., and other pins with reference to TV chassis.... keep your eyes on the screen if it show any sign during your messurments
      • KYBOSH
        • Oct 2011
        • 581
        • Unknown
        #63
        Interesting results but maybe normal / to be expected.
Name:	Screenshot 2024-12-02 at 11.16.54 AM.png
        At certain pins (pin 2,3 and 5 of IC 4002) the voltage fluctuates as low as 0v to as high a 2V+.
        But more interestingly if you hold the test leads these pins form more than 5 seconds or so the TV shuts off and gives 8 Red Blinks.
        The panel itself never displayed anything on the screen though.
        • Diah
          • Feb 2013
          • 6573
          IC 4002 PiQ are fine and active to sync any change of currents... so the circuit of IQ 400 working
          but FRC one IC 4201 complete out of business .
          check the surface of the huge black IC which downside the MSTAR... see the surface under loop if it broken some where
          • lotas
            • Jan 2016
            • 4865
            • Russia
            #65
            The power fluctuates and data is being exchanged; such experiments can easily damage the firmware inside this chip (this is done using an oscilloscope, not a multimeter).
            • Diah
              • Feb 2013
              • 6573
              for once will not harm at all
              • Diah
                • Feb 2013
                • 6573
                nwxt dont touch IC 4002 PiQ again...
                all points marked with red measure volts from both side while TV on.... control too the temperature of the MSTAR SoC.. i do believe there are open circuit some where
Name:	2024-12-01 14.08.30_2024-12-01 14.08.44.jpg
                • KYBOSH
                  • Oct 2011
                  • 581
                  • Unknown
                  #68
                  No signs of damage here.
                  Click image for larger version  Name:	Screenshot 2024-12-02 at 12.48.23 PM.png Views:	0 Size:	6.91 MB ID:	3519920
                  Nothing out of the ordinary.
                  Voltage on both sides of all 0Ω resistors and fuses in the vicinity.
                  Note: Gotta thank you (and the rest of you guys) for taking the time to guide me here. Very much appreciated!
                  • KYBOSH
                    • Oct 2011
                    • 581
                    • Unknown
                    #69
                    Friend, in terms of probing and measuring what is the difference between a multimeter and an oscilloscope?
                    Does a multimeter send feedback/voltage or signal back into the thing being measured?
                    • lotas
                      • Jan 2016
                      • 4865
                      • Russia
                      #70
                      Internal resistance, internal capacitance, shielding...
                      • Diah
                        • Feb 2013
                        • 6573
                        you didn't report back on the MSTAR Temperature ?
                        let go back shortly to the T-CON... let see why there are no sync from MB SoC to it... we start with PMIC measure all this 5 points while set on , always yours eyes on the screen to see if there any sign
                        Click image for larger version  Name:	IMG_0071.jpg Views:	0 Size:	110.1 KB ID:	3519945
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4540
                          • Italy - Milan
                          #72
                          OK watch this pic, on top of the connector there are 6 test points, the third and the fourth one are FB_VRD and VRD (pay attention not VRB), i think thery are a control loop for the integrity of the gate drivers, VRD is the loop start, FB_VRD is the end, so check both in voltage, for the FB331/332 check also the voltage
                          • KYBOSH
                            • Oct 2011
                            • 581
                            • Unknown
                            #73
                            Thank you very much for this. I have an old scope in need of repair what I have been delaying for months.
                            You just gave me motivation to get it back ON my workbench from UNDER my workbench!
                            As Requested. Eyes on the screen. No signs of display life.
                            And the voltages for both 331 & 332 is 3.3V.
                            • Diah
                              • Feb 2013
                              • 6573
                              As Requested. Eyes on the screen. No signs of display life..
                              where are the reset of yours measurements off the 5 points i asked?
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4540
                                • Italy - Milan
                                #75
                                For your information, "Legend" is an automated tag that the new forum gave to all user with a.certain amount of posts, including me, but i prefer not to use that term, there are users that are far far from a legend, one can be a poor obsessed that do nothing useful in life and his name his legend.. !! :+/
                                For the rest of that certain user, are also delirium, i will not also report it to the staff that has full the low parts of these stories.. let's go on, and decide yourself who deserves attention..
                                • KYBOSH
                                  • Oct 2011
                                  • 581
                                  • Unknown
                                  #76
                                  I added the voltages to your pic. Just click. On the picture above my response.
                                  Also regarding the temperature of the ofchip I felt it with my finger and it was not hot and i kept checking it every minute or so. it stayed cool for about five minutes. it started to get warm/hot at around the 5 minute mark.But by then I was done so I just unplugged the tv set.
                                  • Diah
                                    • Feb 2013
                                    • 6573
                                    nothings here or there dont make it complex other wise i will never ask
                                    • Davi.p
                                      Hobbist Tech
                                      • Sep 2009
                                      • 4540
                                      • Italy - Milan
                                      #78
                                      but the other two points?
                                      • lotas
                                        • Jan 2016
                                        • 4865
                                        • Russia
                                        #79
                                        Also check the resistance relative to gnd t-con of these points (CKV1- 6 (there are 12 points in total)) with the panel connected (two cables connected), then with one cable disconnected and with the second cable disconnected.
                                        • Diah
                                          • Feb 2013
                                          • 6573
                                          are you sick or you realty think you are David.P the criminal we do know... are you planning to turn this user T-CON a part for yours previous experiment with yours land man when you drive him to make his PSU like hot air fried crispy kitchen machine...
ID:	3520086 Click image for larger version
                                          • alegatorul
                                            sony bravia kdl-43w756c, no power, no sound
                                            by alegatorul
                                            the charger brick has 19,2-19,3 vcc
                                            changed the inverter board same result.
                                            where should i start?
                                            cheers
                                            11-15-2025, 10:00 AM
                                          • x_orange90_x
                                            Sony Bravia KD-50X690E NO SOUND
                                            by x_orange90_x
                                            Finally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
                                            Has anyone else had this happen to their tv?
                                            10-05-2024, 05:01 AM
                                          • JUCaESAl
                                            Sony bravia KD-65AF9
                                            by JUCaESAl
                                            Hola a todos, necesito el esquema electronico de la placa 1-983-356-11 de un televisor sony bravia KD-65AF9.
                                            Hello everyone, I need the electronic diagram for the 1-983-356-11 board of a Sony Bravia KD-65AF9 television.
                                            10-20-2025, 04:03 AM
                                          • ChaosLegionnaire
                                            by ChaosLegionnaire
                                            09-13-2022, 09:02 AM
                                          • iglitare
                                            by iglitare
                                            09-04-2025, 07:13 AM
