Diah mentioned that no self test was needed as we sort of established that the T-CON does not start up at all even when both LVDS cables disconnected. When i diconnected the LVDS cables the Mainboard was still connected to everything else (including the power supply board) and the TV still acted like nothing was wrong (no error blinks, LED came on, and I got melody from the Android setup screen). Only thing missing was display. Or acknowledgement that there was something wrong somhwhere (LED error blinks or failure to start at all).
Trying to Save - SONY BRAVIA KD-75X780F - No Picture BUT there’s sound
This topic has been answered.
Well, the next steps, you have many control points on the t-con with the indicated voltages, so you need to check them, find more points VGH, VGL,... and check if there are voltages on them. This Samsung t-con and disconnecting the light or right cable will not work here, you need to connect it (put a feedback jumper FB_ Panel - T-con).
I should be able to remote back on the 6 spots you pointed out above.
Thank you!Comment
AVDD1 = 0.0V
AVDD2 = 0.0V
AVDD1.8 = 1.8V
BVDD1.8 = 1.8V
HVIN_12V = 0.0V
PAVDC(?) = 0.0V
VOFFE_.11 = 0.109V
Can you share what you understand from these readings?1 PhotoComment
It doesn't matter what says Diah.. at least for me.. but seeing what you wrote on last post the tcon is indeed not fully working, check also the restpoint VDD_1.05.. This tv is from Sony but screen is from Samsung..
plus.. the self test as you reported is not performed well, you detached first one input cable, then another one.. no, you have to detach both then apply current input on power board, otherwise the tcon will not initialize..Last edited by Davi.p; 11-24-2024, 10:44 PM.Comment
As you instructed I went back and tried to do the self-test exactly as you described.
With the TV powered off I removed BOTH LVDS cables.
Then I powered the TV on with the remote.
I got proper backlight, an accompanying melody from the setup page and the LED status light was solid white (not blinking or showing anything out of the ordinary).
After powering off the TV and reconnecting both LVDS cables I tested the LDD_1.05 voltage and it read as good (1.085V against the chassis).
I noticed another testpoint below the other LVDS cable called VCC_F_3.3V (which seemed to be the sister of LDD_1.05 though maybe unrelated) so I tested it and it also showed as good (3.3.07V against the chassis).
Im looking to actually learn how to repair this T-Con rather than a simple swap out.
The replacement isnt particularly expensive but I figure i would give it a shot as I rarely come across an opportunity like this.
Eager for all of you guy's guidance!
Also on the buffer boards of the display no SMDs get warm at all (inspected with FLIR camera). Also there is no change when I remove either U-cables (which connects the buffer boards on either the left or right side).
I have not established if the panel itself is good but we have pretty much established that the T-Con doesnt seem to be activating nor is it throughing an error code as the mainboard seems oblivious to what the T-Con is or isnt doing.Comment
Sorry.. hard work days these days.. i hope i can help the same.. i'm suspecting the two spi flash on the tcon, it's solder, it's data, or both.. i notice on the main board there are two processors, the main one and the video preprocessor, i don't know if the preprocessor has a built in or connected software that handles tcon communication, in that case a preprocessor bad balls could produce all the present defect, my bet is on the second scenario.. bye..
Sorry.. hard work days these days.. i hope i can help the same.. i'm suspecting the two spi flash on the tcon, it's solder, it's data, or both.. i notice on the main board there are two processors, the main one and the video preprocessor, i don't know if the processor has a built in or connected software that handles tcon communication, in that case a preprocessor bad balls could produce all the present defect, my bet is on the second scenario.. bye..
If you comeback and can answer this question that would be great... its also an open question for anyone else who might care to offer an opinion: If the issue might be related to a failed processor chip then why do we not get anything when we do the T-Con self test? Meaning to say the mainboard is completely disconnected so any issues with it would not stop the T-CON from sending a test pattern to the display.
The way I see it now is I might have to just start throwing parts at it to see what's what. Which would be a shame as I would like to think myself a better detective that than!
Which chip should I read the dump from?Comment
Pardon me but I am not really familiar with how to take these readings as you described so if the measurements I present to you dont make any sense ....FB_VRB and FB 332 are on the right side of the T-Con board while the other two are on the left.Both FCCs On Right FCC Off Only Left FCC Off Only Both FCCs Off FB_VRB + FB 332 2MΩ↑ 51.3KΩ 4.18KΩ 2.4MΩ FB_1 + FB 331 6.13KΩ 11.81KΩ 2.58KΩ 3.1MΩ
I dont know what to make of these numbers but one thing stood out.
When both cables were connected the resistance between the points FB_VRB and FB 332 was very high and increasing quickly (denoted with a red arrow).
If I took these readings wrong please let me know and how it should be properly done so I can go back and sort it out.
I could not find anything online describing how these feedback points were supposed to be tested.
The inner connector test points are tied together on the tcon board so you have to always measure 0ohm from 1 to the other.. when both FFC are connected you have to read 0ohm every measure combination.. so i guess you have faulty FFC ribbons or faulty multimeter cables.. if you have FFC in to the side of FB_1 then FB_1--> FB331 must check 0hm.. similar the other connector..
PS: check very often multimeter crossed probes in ohm, a good DMM and good cables must check around 0,1-0,0 ohms, post a picture of you meter, if you didn't already..Last edited by Davi.p; 11-29-2024, 05:53 AM.Comment
Note: This is with the TV off, disconnected from the mains and both LVDS cables connected (if this makes a difference).Both FCCs On Right FCC Off Only Left FCC Off Only Both FCCs Off FB_VRB + FB_332 2MΩ↑ 51.3KΩ 4.18KΩ 2.4MΩ FB_1 + FB_331 6.13KΩ 11.81KΩ 2.58KΩ 3.1MΩ FB_331 + FB_332 14.4Ω 5.6kΩ 5.6kΩ 9.5kΩ FB_1 + FB-VRB 2MΩ↑ 2MΩ↑ 2MΩ↑ 13MΩ↑ Last edited by KYBOSH; 11-29-2024, 06:28 AM.Comment
by x_orange90_xFinally got my KD-50X690E up and running after replacing the power supply. Upon testing it I noticed the lack of sound from the speakers. At first I just ignored it thinking it was set to external speakers or some other kind of audio setting. However, after actually going into settings and looking around I see nothing of this sort. I looked it up on Google and apparently a lot of people have disappearing audio on a variety of Sony TVs 🙄. I'm going to see if a firmware or software update will resolve it, if available.
Has anyone else had this happen to their tv?
10-05-2024, 05:01 AM -
so i took out one of my spare gigabyte ep35-ds3r mobos from storage for use to do some cpu, ram and video card testing of stuff i bought from ebay and got for free from momaka. he bought 50 e8400 cpus for cheap from ebay some years ago and i decided to help him relieve him of some of his supply since he had waaaay too many!!
what did we say about hoarding too much stuff and depriving others of them?! *cough* socialism *cough* lol!
i had to blow some dust off the board and heatsinks with the datavac as i didnt clean it up before putting it in storage. after finishing...-
by ryandesignHello! I would like to repair my father's Sony Bravia KDL-40v4100 LCD TV. It was in perfect working order the last time I used it before the pandemic. Then it sat plugged in but unused for a year or more. And now everything still works except that there is no picture on the screen. A relay can be heard to click when the power cable is connected. When the power button is pressed there is a green power LED and then the backlight turns on. If I connect an HDMI cable and play something with audio I can hear it through the speakers. The remote control buttons are recognized. There is just never anything...
by x_orange90_xI just got an XBR3 that does not appear to be turning on. As soon as you plug it in the SONY logo and the green power light come on but the screen stays dark. Pressing the power button once gives a single blink of the power light and it remains on. Holding the button in for about 4 seconds causes the logo and the power light to turn off, but as soon as I let go of the button they come right back on.
I have an XBR4 that if I recall correctly has a very distinct relay click when you turn it on, however I'm not hearing that from the XBR3. I just got it yesterday and haven't had a... -
by justin35Hello,
i have this sony bravia kdl-43w755c which boot loops. After sony logo, it shows the android animation loading then it restarts…
from what i read online it looks to be an emmc issue…
i’m not familiar with this kind of tv repairs… i’m repairing laptops and gpu’s…
i took out the board and say an samsung 16gb emmc
i don’t have an exact replacement, but i have a few 32 and 64gb emms’s from laptops…
i could try to put one instead of the 16gb one, but will it work?
where do i get the software from?
any help will be much appreciated!...03-06-2024, 12:26 PM - Loading...
