Tv Samsung qe65q800at not power on
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4555
    • Italy - Milan
    • Michele Romano
      • Nov 2024
      • 9
      • Italia
      It return to fail after 10 days.... i would buy a station Achi Ir pro sc to make a good reflow or a difficoltose reballing
      • Davi.p
        Hobbist Tech
        • Sep 2009
        • 4555
        • Italy - Milan
        Reflow is not ok because the balls are only oxyde, needs to be replaced and after succesful test , chip must be sealed around with hot glue..
        • Michele Romano
          • Nov 2024
          • 9
          • Italia
          Anyone whi make reball on this cpu , which stencil use?? You think its the oxyde the problem and not a ball not good solder....
          • Davi.p
            Hobbist Tech
            • Sep 2009
            • 4555
            • Italy - Milan
            yes the oxyde cause heating then detaching..
            • PantherDave
              by PantherDave
              Hi all!
              05-29-2024, 02:01 PM
            • lapfix
              HP OMEN NO power no light
              by lapfix
              HP OMEN : DAG35DMBAD0
              NO power ,no short ,no corrusion
              Consumption : when charger plg in = 0.004 amp
              Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
              when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
              No light at power button led
              All coils resistances :
              Pl 2001 =3v measured with kohm.
              pl 2004 = 5v measured with kohm
              pl 6001 = 49.7ohm
              pl 4012 = vccsa = 24.4 ohm
              pl 3001 =...
              11-03-2025, 07:48 AM
            • DXseekerMO
              Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
              by DXseekerMO
              Hello everyone!
              Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
              Symptoms:
              1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
              2) TV does not appear to turn on
              3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
              4) "Power on" terminal on Power Supply has 3.26v
              5) "A13V" terminals have 12.9v
              6) Stand-by test jumper on Power Supply has 12.9V
              7) Optical audio jack on Main Board illuminates
              8) With stand-by...
              06-09-2021, 12:19 AM
            • mkdj
              Acer TravelMate P214 - N19Q7 main power rail shorted to ground
              by mkdj
              Dear all,
              I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
              I have checked resistance across each of the 4 MOSFETS. I have the following readings:
              Both N-Channel Mosfets: nothing odd
              P-Channel MOSFET number 1:
              source - drain : 117 kOhm
              source - gate: 96 Ohm
              gate - drain: 117 kOhm
              P-Channel MOSFET...
              08-20-2025, 06:08 AM
