Tv Samsung qe65q800at not power on
by PantherDaveHi all!
https://www.badcaps.net/forum/troubl...-hardware-devi... -
Assuming...7 Photos -
by DXseekerMOHello everyone!
Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
Symptoms:
1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
2) TV does not appear to turn on
3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
4) "Power on" terminal on Power Supply has 3.26v
5) "A13V" terminals have 12.9v
6) Stand-by test jumper on Power Supply has 12.9V
7) Optical audio jack on Main Board illuminates
8) With stand-by... -
by mkdjDear all,
I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
I have checked resistance across each of the 4 MOSFETS. I have the following readings:
Both N-Channel Mosfets: nothing odd
P-Channel MOSFET number 1:
source - drain : 117 kOhm
source - gate: 96 Ohm
gate - drain: 117 kOhm
P-Channel MOSFET... -
by ipatchhello, �� i have been sitting on some microsoft surface pro 4 tablets for a while now. i was originally tasked with replacing the battery in one of the tablets, and ended breaking the screen and logic board in the process. decided to buy another tablet with the same specs. got that screen off successfully of the second tablet. the logic board appeared good, but i guess i shorted something out in the installation process of the logic which i've read is a common issue if there is no barrier between the logic board and battery pins. all that said, i ate costs of the repair and have...
- Loading...
