Tv Samsung qe65q800at not power on
  • Michele Romano
    • Nov 2024
    • 9
    • Italia
    Hello this tv samsung qe65q800at, stuck in stand by if press power led blink but not power at all no light no sound. If disconnettere the mainboard the retr display light is ok . I have also disconnettere the panel , t con etc but notilhing
    i have notice that also in standby i have 12,7 volt from psu and not 7.5 where is market on psu main....​
  • Davi.p
    Hobbist Tech
    • Sep 2009
    • 4535
    • Italy - Milan
    Maybe bad memory inside main board spi flash ic.. needs reprogramming, otherwise is the same old bad bga balls under one of the chips..
    make ritual check on the dc dc step down / main board.. no need of schematics if you know things.. bye.. (where are you from?)
    • Michele Romano
      • Nov 2024
      • 9
      • Italia
      Salerno Italy. Thanks.
      • Michele Romano
        • Nov 2024
        • 9
        • Italia
        I see that the cpu is hot also in stand by... maybe short.....
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4535
          • Italy - Milan
          Needs reballing, my bet..
          • lotas
            • Jan 2016
            • 4847
            • Russia
            Post removed by admin due to tone of the reply. User disagrees with reballing.
            • Diah
              • Feb 2013
              • 6556
              Originally posted by lotas
              removed
              Post removed by admin - user can disagree with post but not bully.
              • Davi.p
                Hobbist Tech
                • Sep 2009
                • 4535
                • Italy - Milan
                removed due to edits above. please everyone just keep it polite. You are allowed to disagree with someone technical analysis but just say so without snarky comments which I see as bullying
                • Davi.p
                  Hobbist Tech
                  • Sep 2009
                  • 4535
                  • Italy - Milan
                  Do you know the story of TV? If TV broken suddenly after bad weather it could be also shorted CPU via HDMI ports.. keep informations about tv..
                  anyway better to replace board..
                  • Diah
                    • Feb 2013
                    • 6556
                    What i want to know is if you are really interested or just searching the fight like the bad element under..
                    Hey no bad element over here... we are all human and could do mistake.... but technical forum not only badcaps-net, there are many older than this.we are member at them... . and the admin are high level with technician know how too.. so any one low level will fly out soon after 3 warning if he /she post nonsense diagnose or method
                    users over here are not technician one, they will believe anx things written over here... so if we are all a ware of not harm such user... we should clear to them the way by explanation to do some things they never did in their´r life.... technicolor who seek help here or own shop he knew where to ask.. just because the nonsense answers given over here..
                    when we will but end to this theater.. .. no one fighting with you.... we are against your brains.
                    • Davi.p
                      Hobbist Tech
                      • Sep 2009
                      • 4535
                      • Italy - Milan
                      • Michele Romano
                        • Nov 2024
                        • 9
                        • Italia
                        I know that tv while are power on shut off and restart after remove the ac alimentation for 5 minutes. This for two times after nothing only red led on that flash if press remote or local button
                        • Davi.p
                          Hobbist Tech
                          • Sep 2009
                          • 4535
                          • Italy - Milan
                          OK so this appears to me as the same common fault of these very very poor designed QLED Samsung (of the series "Once upon a time there was the glorious Samsung.. now down to the sewers!"), thus bad soldering under the processor, here it is worse than other "fresh" faults.. if you stay tuned here, i'm trying to buy another board for mine, the first i ordered is returned back due to a criminal behavior of a postman.. we are in Italy! :-((
                          • Diah
                            • Feb 2013
                            • 6556
                            Q800 had separated T-CON, unplug all 4 ribbon cable between T-CON and panel. try turn on... if remain on.... then try half screen test.
                            on other hand you have on the t_CON between the 2 LVDS socket 2 point FB1 FB3 this can jumper them in case the first test was OK
                            • Davi.p
                              Hobbist Tech
                              • Sep 2009
                              • 4535
                              • Italy - Milan
                              Post please an overview of back of tv with boards
                              • Davi.p
                                Hobbist Tech
                                • Sep 2009
                                • 4535
                                • Italy - Milan
                                well if tcon separated i don't think or remember Samsung sets falls into protection due to bad screen/tcon, plus the hot cpu makes me think also the already said last suspicion, to get a new board, keep in mind it have to be new or got from working set w/cracked panel.. bye..
                                • Michele Romano
                                  • Nov 2024
                                  • 9
                                  • Italia
                                  It s CPU soldering after reflow start ok.
                                  • Davi.p
                                    Hobbist Tech
                                    • Sep 2009
                                    • 4535
                                    • Italy - Milan
                                    ok thanks for the reply, keep in mind that reflow is not a real repair, the cpu will return to fail, to keep it going farther you can take an hot glue gun and carefully seal all around the border every BGA chip, but reballing and glue sealing is the best for me.. bye..
                                    • Storyteller12
                                      • Jun 2020
                                      • 625
                                      Never heard of using hot glue around BGA chips. How does that help? Seems like it would cause more problems as the chip wouldn’t get any air flow and dissipate the heat. Which seems to be the reason these chips fail in the first place.
                                      Seems like a proper reballing with lead solder would be enough
                                      • Davi.p
                                        Hobbist Tech
                                        • Sep 2009
                                        • 4535
                                        • Italy - Milan
                                        The sealing would prevent oxidation that it is the cause for me of the chip overheating/detaching..
                                        • PantherDave
                                          by PantherDave
                                          Hi all!
                                          05-29-2024, 02:01 PM
                                        • lapfix
                                          HP OMEN NO power no light
                                          by lapfix
                                          HP OMEN : DAG35DMBAD0
                                          NO power ,no short ,no corrusion
                                          Consumption : when charger plg in = 0.004 amp
                                          Only 3/5 vl are present when charger connected..when i put my red probe at the coils of 3/5volts and power on with my power suplly it try to rise than 0v.
                                          when try to power on using power button i note this starnge value : 3v then 0.300v then 3v !
                                          No light at power button led
                                          All coils resistances :
                                          Pl 2001 =3v measured with kohm.
                                          pl 2004 = 5v measured with kohm
                                          pl 6001 = 49.7ohm
                                          pl 4012 = vccsa = 24.4 ohm
                                          pl 3001 =...
                                          11-03-2025, 07:48 AM
                                        • Tynan Dill
                                          by Tynan Dill
                                          Assuming...
                                          11-22-2024, 01:46 PM
                                        • DXseekerMO
                                          Samsung UN65NU6900FXZA Stand-by light on but voltages on PS indicate TV should be on
                                          by DXseekerMO
                                          Hello everyone!
                                          Tonight I picked up a Samsung UN65NU6900FXZA with a curious issue.
                                          Symptoms:
                                          1) Plug TV in to AC outlet, stand-by light illuminates briefly and goes out.
                                          2) TV does not appear to turn on
                                          3) Backlights do not illuminate, voltages associated with backlights on Power Supply are not present
                                          4) "Power on" terminal on Power Supply has 3.26v
                                          5) "A13V" terminals have 12.9v
                                          6) Stand-by test jumper on Power Supply has 12.9V
                                          7) Optical audio jack on Main Board illuminates
                                          8) With stand-by...
                                          06-09-2021, 12:19 AM
                                        • mkdj
                                          Acer TravelMate P214 - N19Q7 main power rail shorted to ground
                                          by mkdj
                                          Dear all,
                                          I have taken out the motherboard of a Acer TravelMate P214. There is a short to ground on the main power rail (19V). I don't have the schematics or boardview for this board (DAZ8IMB1AA0 REVA). But I have found 4 MOSFETS close to the main power rail : 2 N-Channel and 2 P-Channel.
                                          I have checked resistance across each of the 4 MOSFETS. I have the following readings:
                                          Both N-Channel Mosfets: nothing odd
                                          P-Channel MOSFET number 1:
                                          source - drain : 117 kOhm
                                          source - gate: 96 Ohm
                                          gate - drain: 117 kOhm
                                          P-Channel MOSFET...
                                          08-20-2025, 06:08 AM
