Samsung UE46C6530 Bright patches on screen
  • DemonBG
    • Mar 2012
    • 143
    Im currently working on this Samsung 46" LED tv which has two bright patches on either side of the screen (roughly where the speakers are mounted under the frame).
    Originally this TV had a faulty main board (which i have now replaced) but this particular symptom remains between the old and new main boards.
    Any suggestions on what to check please?
    Thank you,
    Demon
    Re: Samsung UE46C6530 Bright patches on screen
    My first guess would be something related to the LEDs on the bottom of the panel. Have they perhaps moved out of alignment while you were working on the set, or perhaps the diffuser film near them has? Alternatively, it is possible that those LEDs are stuck on 100% bright for some reason (whereas the others are on something like, say, 50% brightness.)
    • tibimakai
      • Jan 2012
      • 3680
      ..or maybe the middle ones are off.
        • 31187
        2 very distinct points,
        maybe it's a group of 3 in series and the center one is shorted.
        • DemonBG
          • Mar 2012
          • 143
          Thanks for the replies all.
          Could this be a T-con issue? The reason i ask is that today i unplugged the LVDS cable and the backlight alone came on and the screen was fairly uniformly lit...
          I then connected only 1 side at a time on the T-con to test each half of the screen and had the same result - the side with the image had a bright patch (red circle) and the side without an image was uniformly lit. (pictures attached)
          I noticed that on darker images as well that the contrast gradient was very poor - The transition between colors was very "blocky" (see pic for example... it is not as smooth as i would expect). would this suggest it is a T-con problem? Is there any way to test?
          Thanks again all,
          Demon
          Thanks all,
          Demon
            That's very odd, I have never seen a bad LCD panel do that (overbright in corners) so I don't know why it disappears with the ribbons out. Would you say the effect is completely gone? The image being solarised with one ribbon out isn't entirely unusual.
            • DemonBG
              • Mar 2012
              • 143
              Hi Tom,
              Yes on the side with the ribbon cable out the backlight is completely normal and on the side with the ribbon cable in it is still overbright.
              I am thinking this may have something to do with the fact that it is an LED tv and i read somewhere that they are able to dynamically adjust the brightness in different areas based on the image.... which would explain why the T-Con may also control an element of the LED circuitry?
              Take care all,
              Demon
              • DemonBG
                • Mar 2012
                • 143
                Just found this with reference to LED blocks on LG LED tv's which may explain it:
                "An individual block is manipulated by the T-CON board. These blocks are manipulated Global (All at once) and in accordance with the video intensity at the specific location of the block of LEDs for that video content (Local). In other words, if the video is dark in the area of the screen"
                Source: http://electro-medical.blogspot.co.u...backlight.html
                What do you think?
                Thanks,
                Demon
                  Some LED TVs called "Full LED TV" can dim individual parts of the image, but AFAIK that is not used any more on Samsung TVs. Sometimes they can dim the edges of the image though. Can you supply a picture of your T-con board? Any LED backlight control is usually on a separate PCB and will not be through the T-con panel ribbon but through the main board and PSU (usually) or sometimes T-con to PSU.
                  • DemonBG
                    • Mar 2012
                    • 143
                    Correct you are sir! I just did a bit more reading and it seems that although on the LG tv's this is done through the T-con there are wires going directly to the LED drivers.
                    Pictures attached all the same.
                    Also - Just to confim, with 1 ribbon cable unplugged, the half of the screen with the image does still have the overbright section (the picture i posted before does not show it well...)
                    • tibimakai
                      • Jan 2012
                      • 3680
                      I would take the panel apart and see what is going on.
                      • DemonBG
                        • Mar 2012
                        • 143
                        Tibimakai - because of the issue with the funny colors and whatnot i am leaning toward thinking this is a T-con issue... (or both?) I have another of these TV's at my brothers place so over the coming weeks i will take the full set of boards over to his place and see if i get the same results...
                        I will post back when i have an update.
                        In the meantime - Is there any way i can probe / test the T-con board?
                        Thanks,
                        Demon
                        • DemonBG
                          • Mar 2012
                          • 143
                          Update-Fixed!
                          Ok so as i had guessed, this one turned out to be a faulty T-con board...
                          I must admit, i had no idea a faulty T-Con could result in the bright patches, but what game me the idea was the funny colors on the screen!
                          Either way, i hope this solution helps someone else out there as well!
                          All the best,
                          Demon
                          • Chrissygizmo
                            by Chrissygizmo
                            02-10-2025, 12:33 AM
                          • Chrissygizmo
                            samsung galaxy ao2s very temperamental after screen replaced
                            by Chrissygizmo
                            Hi , I've recently replaced the screen in my Samsung galaxy ao2s, at first it wouldn't even turn on, it had the charging symbol on the screen when plugged in but the green circle wasn't going around to show it charging....
                            Ive eventually managed to get it on and working but it's very temperamental...
                            The battery icon always reads as 50% , when the phone goes into lock screen mode i sometimes can't get the screen back on unless I plug the charger in to get it to light up, also it keeps putting the camera app on.. u think it could be something to do with the side buttons. ...
                            05-26-2024, 12:05 AM
                          • JunkmanJimbo
                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and won't turn off
                            by JunkmanJimbo
                            Samsung UN55J6200AFXZA Splash Screen Comes up, goes out, screen flashes one time and then tv won't turn off.
                            No picture. No sound that I can tell. Backlights are on and have been checked. Flashlight test no image on screen. I replaced the Eprom chip hoping that was the problem but nothing changed.
                            Please help. Thanks in advance!
                            08-12-2025, 11:45 AM
                          • Kiberge
                            Samsung LH82QENELGC/EN Help needed - Static line on screen
                            by Kiberge
                            HI guys!
                            I've got a Samsung LH82QENELGC/EN with a problem and need some advice and I hope this is the forum to use?
                            I'm from Norway so I'd like to apology in advance if my description of the fault is kind of simple or the names on the components are way off. 😊
                            the TV is powering up, working as normally and picture is all good, except a 1.5-inch-wide vertical line of snow/static across the screen.
                            This TV is a Signage Display/Public Display version and it's been used at my work for 4-5 years showing commercials 24/7. The fault occurred when...
                            04-22-2024, 11:28 AM
                          • Ryan.man
                            by Ryan.man
                            02-04-2025, 12:23 PM
