LG 55EG910V - no power and no standby light
  • Diah
    • Feb 2013
    • 6557
    OLED T-CON driver boards are not as LCD t-CON. it work with 2 rails.. 1- 24 V EVDD to handle OLED cells and second one 12V VCC to the t_CON signal process
    at yours set 24V rail come from PSU direct but the 12VCC t-CON come from MB.VIA LVDS this why we disconnect the MB LVDS to T-CON and take the 12 V direct from PSU to T-CON fuse at time we want TESTING psu + T-con + module AS STAND ALONE:
    • AleMonti
      • Nov 2024
      • 15
      • Italy
      Yes that’s what I did in my latest tests. I got it wrong initially and figured it out afterwards.
      • Diah
        • Feb 2013
        • 6557
        Originally posted by AleMonti
        Diah I don't see your point,
        then no need for this comment at time you know you were in wrong.and who advice you over here
        • Davi.p
          Hobbist Tech
          • Sep 2009
          • 4536
          • Italy - Milan
          But wouldn't a new one show artefacts because of the mismatched panel calibration?
          I've expressed many times my theories here in other threads, i don't want repeat myself, the only requisites i have expressed in previous post, it's up to you, i'm not here to let users lost money, the counterwise..
          • AleMonti
            • Nov 2024
            • 15
            • Italy
            Nothing against you, I'm grateful for everyone's help here. I was just confused by your post #19 because at that point in the thread I was already doing the test correctly as you describe.
            Davi.p, I simply wanted to set my expectations right. I'll do some more research and tests today.
            • ygorsan
              by ygorsan
              🧩 Problem Summary:
              • I
              07-28-2025, 08:34 AM
            • JDC
              by JDC
              ONN 100012588
              Long answer:
              07-15-2022, 07:39 AM
            • m1ch43lzm
              by m1ch43lzm
              05-12-2025, 08:37 PM
            • cheeky2
              by cheeky2
              05-25-2024, 03:27 AM
            • howardc64
              by howardc64
              Problem
              08-04-2024, 10:36 PM
